Accel 8 Click
PID: MIKROE‐3341
Weight: 23 g
Accel 8 click is an advanced 6-axis motion tracking Click board™, which
utilizes the MPU6050, a very popular motion sensor IC, equipped with a 3axis gyroscope and 3-axis accelerometer. It also features Digital Motion
Processor™, a very powerful processing engine, which reduces the firmware
complexity and the processing load of the host MCU. The output of each axis
is digitized by a separate 16-bit ADC and processed by the DMP engine,
offering motion data over the I2C Interface. Packed with a set of very
powerful options, this Click board™ represents an ideal solution for the
development of MotionInterface™ based applications.
Accel 8 click is supported by a mikroSDK compliant library, which includes
functions that simplify software development. This Click board™ comes as a
fully tested product, ready to be used on a system equipped with the
mikroBUS™ socket.
MPU6050 is produced utilizing the innovative Nasiri Fabrication platform,
specialized in MEMS production and its integration with accompanying logic
sections, on a wafer level. This allows very high integration and very small
dimensions, at an affordable cost. Besides the size, features such as low
power consumption, high precision of motion detection, high shock
tolerance, and programming capabilities, make it a MotionInterface™
enabled device, which can be used for development of different types of
motion detection based applications, including gesture command,
augmented reality, vehicle navigation, image stabilization in photography,
and other similar applications.
How does it work?
Accel 8 click is based around the MPU6050, a motion tracking sensor IC,
from TDK Invensense. It is an advanced, integrated microelectromechanical
gyroscope and accelerometer sensor (MEMS), combined with the powerful
data processing engine. There is a respective accelerometer or gyroscope
MEMS on each axis. The output of each MEMS is processed and digitized by
a separate sigma-delta 16-bit A/D converter (ADC). The outputs can be
processed by a programmable low-pass filter, while their sample rate can be
selected by the user.
Three-axis gyroscope MEMS can be programmed to measure the rotation
about each axis, in four different ranges of rotational speed (degrees per
angle, DPS): ±250, ±500, ±1000, and ±2000. Three-axis accelerometer
MEMS can be programmed to measure the acceleration along each axis, in
four different acceleration ranges: ±2g, ±4g, ±8g, and ±16g. The user can
select an optimal range for both properties, depending on the application
requirements.
The embedded Digital Motion Processor™ can process complex 6-axis motion
detection and gesture recognition algorithms without taking up processing
cycles of the host microcontroller (MCU), making it perfectly suited for
different kinds of low-power applications. The DMP engine offers a high
output data rate (ODR), improving measurement accuracy. Due to DMP
hardware-accelerated motion detection algorithms, MPU60x0 are very
popular motion tracking ICs and there are many different designs using both
MPU6050 and MPU6000 (e.g. MPU IMU click). Unlike the MPU6000, the
MPU6050 uses the I2C communication interface.
MPU6050 incorporates a powerful programmable interrupt engine. The
interrupt engine can generate a signal on the interrupt pin for several
interrupt sources, including FIFO Buffer overflow, Data Ready, I2C Master
Error, and I2C Slave Error. The interrupt is routed to the INT pin of the
mikroBUS™.
A FIFO buffer helps to further reduce the processing load, offering temporary
storage for the output data. The MPU6050 features a FIFO buffer with the
capacity of 1024 bytes. The user can select which data will be stored in the
FIFO buffer: gyro data, accel data, temperature readings, and auxiliary
sensor readings. Once the FIFO buffer is full, it will start discarding the
oldest data, allowing new data to be written. The FIFO buffer overflow
condition can be used to trigger an interrupt, alerting the host MCU about its
status.
Another powerful feature of the MPU6050 is its ability to be interfaced with
an additional sensor, such as the 3-axis compass. By utilizing the
MotionFusion™ firmware on the chip, along with the run-time calibration, it
offers the complete 9-axis motion sensing solution. This sensor can be
connected to the auxiliary I2C pins, routed to the mikroBUS™. Aux I2C clock
pin is routed to the RST pin of the mikroBUS™ and it is labeled as CL, while
the Aux I2C data pin is routed to the AN pin of the mikroBUS™, labeled as
DA. Besides the compass sensor, other general-purpose sensors that use
I2C interface can be connected, too. An interrupt can be generated if there is
an error in the communication between the MPU6050 and the auxiliary
sensor.
The I2C address of the MPU6050 can be selected by the ADD SEL jumper.
This SMD jumper is used to select the least significant bit (LSB) of the 7-bit
I2C address. The value of the LSB is decided by the position of this jumper.
Accel 8 click uses the I2C communication interface. It has pull-up resistors
connected to the mikroBUS™ 3.3V rail. Proper conversion of logic voltage
levels should be applied before the Click board™ is used with MCUs operated
with 5V.
Specifications
Type
Motion
Applications
It is a perfect solution for development of different types of
motion detection-based applications, including gesture
command, augmented reality, vehicle navigation, image
stabilization in photography, and other similar applications.
On-board
modules
MPU6050, a six-axis (gyro + accelerometer) MEMS
MotionTracking™ IC, from TDK Invensense.
Key Features
Digital Motion Processor™ engine with motion processing and
gesture recognition algorithms, 6 independent MEMS, one on
each axis, sampled by a separate 16-bit ADC, AUX I2C interface
for additional sensor supported by the MotionFusion™ engine,
output data filtering, selectable accel and gyro ranges…
Interface
I2C
Input
Voltage
3.3V
Click board
size
M (42.9 x 25.4 mm)
Pinout diagram
This table shows how the pinout on Accel 8 Click corresponds to the pinout on
the mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Aux I2C Data
Pin
DA
Pin
1
AN
PWM
16
NC
Notes
Aux I2C Clock
CL
2
RST
INT
15
INT
Interrupt
NC
3
CS
RX
14
NC
NC
4
SCK
TX
13
NC
NC
5
MISO
SCL
12
SCL
I2C Clock
NC
6
MOSI
SDA
11
SDA
I2C Data
Power Supply
+3V3
7
3.3V
5V
10
NC
Ground
GND
8
GND
GND
9
GND
Ground
Onboard settings and indicators
Label
Name
Default
LD1
PWR
JP1
ADD SEL
Left
Description
Power LED indicator
I2C slave address LSB selection: left position 1,
right position 0
Software support
We provide a library for the Accel 8 Click on our LibStock page, as well as a
demo application (example), developed using MikroElektronika compilers. The
demo can run on all the main MikroElektronika development boards.
Library Description
The library initializes and defines the I2C bus driver and drivers that offer a
choice for writing data in register and reads data form register. The library
includes function for read Accel X/Y/Z axis data, Gyro X/Y/Z axis data and
device Temperature data. The user also has the function for configuration
Accel and Gyro and function for read interrupt state.
Key functions:
void accel8_getAccelAxis(int16_t *x_axis, int16_t *y_axis, int16_t *z_axis) -
void accel8_getGyroAxis(int16_t *x_axis, int16_t *y_axis, int16_t *z_axis) - Functions
float accel8_getTemperature() - Functions for read Temperature data in C.
Functions for read Accel axis data.
for read Gyro axis data.
Examples description
The application is composed of the three sections :
System Initialization - Initializes I2C module and sets INT pin as INPUT.
Application Initialization - Initialization driver init, reset chip and start configuration chip for
measurement.
Application Task - (code snippet) - Reads Accel X/Y/Z axis, Gyro X/Y/Z axis and device
Temperature. All data logs on the USBUART every 2 sec.
void applicationTask()
accel8_getAccelAxis(&X_accelAxis, &Y_accelAxis, &Z_accelAxis);
accel8_getGyroAxis(&X_gyroAxis, &Y_gyroAxis, &Z_gyroAxis);
Temperature = accel8_getTemperature();
// LOGS DATA
mikrobus_logWrite("________________ Accel 8 click _________________", _LOG_LINE);
mikrobus_logWrite("| Data | X axis | Y axis | Z axis | Range |", _LOG_LINE);
mikrobus_logWrite("|_________|________|________|________|_________|", _LOG_LINE);
mikrobus_logWrite("| Accel |", _LOG_TEXT);
IntToStr(X_accelAxis, demoText);
mikrobus_logWrite(demoText, _LOG_TEXT);
mikrobus_logWrite(" |", _LOG_TEXT);
IntToStr(Y_accelAxis, demoText);
IntToStr(Z_accelAxis, demoText);
IntToStr(accelRange, demoText);
mikrobus_logWrite(" g |", _LOG_LINE);
mikrobus_logWrite("| Gyro |", _LOG_TEXT);
IntToStr(X_gyroAxis, demoText);
IntToStr(Y_gyroAxis, demoText);
IntToStr(Z_gyroAxis, demoText);
IntToStr(gyroRange, demoText);
mikrobus_logWrite("dps|", _LOG_LINE);
FloatToStr(Temperature, demoText);
demoText[ 5 ] = 0;
mikrobus_logWrite("| Temp |", _LOG_TEXT);
mikrobus_logWrite(" C |", _LOG_LINE);
mikrobus_logWrite("|_________|_________________|", _LOG_LINE);
mikrobus_logWrite(" ", _LOG_LINE);
Delay_ms( 2000 );
The full application code, and ready to use projects can be found on
our LibStock page.
Other mikroE Libraries used in the example:
I2C
Additional notes and informations
Depending on the development board you are using, you may need USB UART
click, USB UART 2 click or RS232 click to connect to your PC, for development
systems with no UART to USB interface available on the board. The terminal
available in all MikroElektronika compilers, or any other terminal application
of your choice, can be used to read the message.
https://www.mikroe.com/accel‐8‐click2‐13‐19
