ANALOG KEY CLICK
PID: MIKROE‐3409
Weight: 28 g
Analog Key Click is an analog keyboard on a Click board™. It contains six tactile pushbuttons, used to
select one of six different voltage levels. The idea behind this click is very simple: six resistors form a
voltage divider. The resistors are connected in series between the VCC and the GND. Each button selects
one of the six middle taps, allowing six different voltage levels to be selected. The voltage is available at
the AN pin of the mikroBUS™, which is additionally protected by an operational amplifier, configured as
a buffer. This allows both protection and a proper impedance at the analog input pin of the
microcontroller.
Featuring six high‐quality pushbuttons, a simple debouncing circuit, and the output op‐amp
buffer, this Click board™ is an ideal solution for different applications controlled by discrete
voltage levels, but also for applications which have restricted number of free pins. This type
of keyboard can be used as password terminals for small alarm systems, for selecting an
option in various embedded applications, and for all kinds of small DIY projects where low
pin count is a big concern.
HOW DOES IT WORK?
As already mentioned, the working principle of this Click board™ is very simple: it contains
a voltage divider, formed by six 1 kΩ resistors. Those resistors are connected in series, and
each connection point is routed to one pin of the SPST pushbutton. The KMR2
series KMR221 tactile buttons are high‐quality SPST switches produced by CKSwitches, a
company specialized in production of various types of quality switches. These buttons are
rated to endure up to 300,000 switching cycles and have very low ON resistance of less
than 100 mΩ. The buttons are rubberized and have a pleasant tactile feel when pressed.
By pressing a button, the respective connection point becomes redirected to the input of
the OPA344, a low‐power operational amplifier from Texas Instruments, which is
configured to work with the unity gain, forming a buffer for the input of the microcontroller
(MCU). This prevents changes of the impedance at the MCU input pin, as well as a limited
amount of ESD protection.
By substituting the voltage divider resistors with two equivalent resistances (RE1 for the
upper set of resistors, and RE2 for the lower set of resistors) the principle can be
understood even better: when the top button is pressed (T1), the equivalent RE1 resistance
will be 0 Ω, so regardless of the RE2 resistance, the voltage at the AN pin will be equal to
VCC. When the second button (T2) is pressed, the equivalent RE1 resistance will be 1 kΩ,
while the RE2 resistance will be 5K. The voltage at the AN pin can now be easily calculated
by using the simple voltage divider formula:
VOUT VCC ∙ RE2 / RE1 RE2
RE1 will be 2 kΩ, and RE2 will be 4 kΩ when the third (T3) button is pressed, and so on.
Following this principle, the discrete voltage level for each button can be easily calculated,
depending on the value of the VCC.
The VCC voltage for the voltage divider can be selected using the SMD jumper on the Click
board™, labeled as VSEL. This jumper selects either a 3.3V or 5V mikroBUS™ power rail as
the VCC source. Since there are many MCUs that cannot tolerate 5V on their pins, the VSEL
position is set to 3.3V by default. However, if the 5V operation is required for specific
application, it is enough to move the position of the VSEL jumper to the 5V position.
The selected output voltage appears at the AN pin of the mikroBUS™, labeled as VO on
Analog Key click. It can be then sampled by the A/D converter of the MCU and used to
control a device. Since Analog Key click requires just a single pin for its operation, it is
perfectly suited for applications where the pin count restriction is a big problem.
SPECIFICATIONS
Type
Button
Applications
It is an ideal solution for different applications controlled by discrete voltage
including password terminals for small alarm systems, for selecting an option in
low pin count is a big concern.
On‐board
modules
KMR221, a tactile push‐button by CKSwitches; OPA344, a low‐power
operational amplifier from Texas Instruments.
Key Features
Analog keyboard requires a single MCU pin, high quality buffer op‐amp,
rubberized tactile pushbuttons with very high endurance and low ON resistance,
and more.
Interface
Analog
Input Voltage
3.3V,5V
Click board
size
L (57.15 x 25.4 mm)
PINOUT DIAGRAM
This table shows how the pinout on Analog Key Click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Notes
Key Voltage OUT
VO
1
AN
PWM
16
NC
NC
2
RST
INT
15
NC
NC
3
CS
RX
14
NC
NC
4
SCK
TX
13
NC
NC
5
MISO
SCL
12
NC
NC
6
MOSI
SDA
11
NC
Power Supply
+3V3
7
3.3V
5V
10
+5V
Power Supply
Ground
GND
8
GND
GND
9
GND
Ground
ONBOARD SETTINGS AND INDICATORS
Label
Name
Default
LD1
PWR
JP1
VSEL
Left
Description
Power LED indicator
Power supply voltage selection: left position 3.3V, right
position 5V
SOFTWARE SUPPORT
We provide a library for the Analog Key Click on our LibStock page, as well as a demo
application (example), developed using MikroElektronika compilers. The demo can run on
all the main MikroElektronika development boards.
Library Description
The library contains a function which, based on the ADC value, detects which button is
pressed.
Key functions:
uint8_t analogkey_getKey(uint16_t adcValue) ‐ Detects which button is pressed.
Examples description
The application is composed of the three sections :
System Initialization ‐ LOG initialization for displaying data on USB UART.
Application Initialization ‐ Initializes ADC init.
Application Task ‐ (code snippet) ‐ Reads ADC value and detects which button is pressed based on that
value.
void applicationTask()
uint16_t ADC_value;
uint8_t isKey;
char demoText[ 50 ];
uint8_t cnt;
uint16_t sumValue = 0;
for(cnt = 0; cnt
