mikromedia HMI Breakout Board
PID: MIKROE-2300
Weight: 49 g
The mikromedia HMI breakout board is a simple accessory that conveniently enables developers
to access pins from any of the 18 mikromedia HMI smart display boards. Each mikromedia
HMI is powered by an FT900Q 32-bit MCU, and this board directly interfaces to it, which
simplifies development in the prototyping phase (mikromedia HMI boards are intended for use
as OEM parts). The breakout board also contains a micro USB port, an RJ-45 ethernet connector,
as well as an external programmer connector (ideally used with mikroProg for FT90x). Two 24pin flat cables are included in the packaging, enabling the use of both mikromedia HMI
connectors at the same time (MAIN, CAMERA).
https://shop.mikroe.com/smart-displays/mikromedia-hmi/mikromedia-hmi-breakout 6-13-17
很抱歉,暂时无法提供与“MIKROE-2300”相匹配的价格&库存,您可以联系我们找货
