mikromedia 7 for STM32 Shield
PID: MIKROE-2812
mikromedia 7 for STM32 Shield is the perfect way to expand the functionalities of
your mikromedia 7 for STM32F4 and mikromedia 7 for STM32F7 with five mikroBUS™
sockets - add any functionality from our ever-growing range of click boards™. We are fully
stocked with everything from sensors and wifi transceivers to motor control and audio
amplifiers.
Click here to learn more about the mikromedia 7 for STM32F4 and mikromedia 7 for STM32F7.
What's on the board
Take a look at the video, and find out what the mikromedia 7 for STM32 Shield has to offer.
The board features a UART select jumper, 5 mikroBUS™ sockets, connection pads, FTDI USBUART converter and an external power supply screw terminal.
click board™ range
As you already know, our click board™ range is constantly growing - hundreds of different
functionalities are available in our store. From sensors and wireless transceivers to motor control
and LED displays.
UART interfaces
There are 2 UART interfaces available on the shield, routed from the mikromedia 7 for STM32.
One of the mikroBUS™ slots - mikroBUS 5 - can have either one of the two UART lines routed
to the mikromedia 7 for STM32, selectable by the mikroBUS™ 5 UART jumper selector. Other
4 mikroBUS™ slots are hardwired to one UART only.
The shield also has the FT232 USB to UART circuit on board. Its RX and TX lines can also be
routed to any of the two UART interface lines of the mikromedia 7 for STM32, by using the
UART SELECT jumper selectors. The integrated USB to UART interface is very handy for
connecting the shield to the computer and reading UART data on any UART terminal - it is
recommended to use the UART terminals, found in every MikroElektronika compiler since those
terminals are easy to use and are optimized for working in embedded development environment.
Note: If the WiFi SMD jumper is set to enable the WiFi on the mikromedia for STM32, one of
the UART lines won't be available on the shield.
Specifications
Type
Shield
Applications
The Shield provides the most convenient way for connecting click boards™ to your
mikromedia 7 for STM32F7 and mikromedia 7 for STM32F4
On‐board
modules
5 mikroBUS™ sockets, external power supply screw terminal, UART selection, FTDI USB‐
UART converter, micro USB connector, two 1x26 headers ‐ mikromedia standard pinout
Compatibility
mikromedia
https://www.mikroe.com/mikromedia‐7‐for‐stm32‐shield 12‐5‐17
很抱歉,暂时无法提供与“MIKROE-2812”相匹配的价格&库存,您可以联系我们找货
