Thermo 7 click
PID: MIKROE-2979
Weight: 30 g
Thermo 7 click is a Click board™ equipped with the sensor IC, which can
digitize temperature measurements between -55°C and +125°C so that the temperature
measurement data can be processed by the host MCU. Thermo 7 click provides an accuracy
of ±1°C in the range from -10°C to +85°C. The sensor used on this Click board™ has a great
combination of features that make it a perfect choice for any temperature measurement
application: low power consumption, selectable sampling resolution, programmable
interrupt engine, compact sensor size, alert output pin, and more. The sensor itself requires
almost no external components, which simplifies the design, reducing the cost and cutting
the time to market.
The Click board™ is specially designed so it retains the specified characteristics of the
sensor IC. Equipped with this sophisticated, accurate and simple to use sensor IC, it can be
used for measuring and monitoring the temperature in a whole range of applications, such
as the PC case and other internal components temperature monitoring, office
equipment and entertainment systems thermal monitoring, general purpose thermal
measurement, and similar digital thermal measurement applications, that require a precise
thermal measurement and an overtemperature alert.
How does it work?
The active temperature sensing component on Thermo 7 click is the MCP9800, a high
accuracy temperature sensor IC with the 2-Wire interface, from Microchip. The Click
board™ itself has a reasonably small number of components because most of the
measurement circuitry is already integrated on the MCP9800 sensor. The I2C / SMBus
compatible serial interface lines, along with the ALERT pin, which also works in the open
drain configuration, are pulled up by the onboard resistors. The 2-Wire lines are routed to
the respective I2C lines of the mikroBUS™ (SCK and SDA), while the ALERT pin is routed to
the INT pin of the mikroBUS™.
The sensor IC uses the I2C/SMBus compatible communication interface. There are four
registers, used to set the temperature limit, temperature hysteresis for the interrupt
events, configuration register used to store all the working parameters, and the read-only
register which holds the sampled temperature data. More information about all the
registers can be found in the MCP9800 datasheet. However, provided library contains
functions that simplify the use of the Thermo 7 click. The included application example
demonstrates their functionality and it can be used as a reference for custom design.
An analog signal from the thermal sensor is sampled by the sigma-delta ADC converter,
with the selectable resolution of 9, 10, 11 and 12 bits. The sampling resolution affects the
temperature step sizes, as well as the time required to complete the conversion. The step
sizes vary between the 0.5°C with 30ms of conversion time for 9bit sampling, and 0.0625°C
with 240ms of conversion time for 12bit resolution. The selectable resolution allows a
compromise to be made between the resolution and the conversion time, depending on the
application requirements.
The ALERT pin is used to trigger an interrupt event on the host MCU. This pin has a
programmable polarity: it can be set to be asserted either to a HIGH logic level or to a LOW
logic level. Since the Click board™ features a pull-up resistor, it is advised to set the polarity
so that the asserted state drives the pin to a LOW logic level. A special mechanism is
employed to reduce false ALERT triggering. This mechanism includes queueing of the
cycles in which the temperature limit is exceeded. As already described, the ALERT pin is
routed to the INT pin of the mikroBUS™.
The ALERT pin can be set to work in two different modes: Comparator mode and Interrupt
mode.
When working in the Comparator mode, this pin will be triggered whenever a temperature
limit is exceeded. The ALERT pin stays asserted until the temperature drops below the
hysteresis level. Both values are set in the respective temperature registers (limit and
hysteresis). This mode is useful for thermostat-like applications: it can be used to power
down a system in case of overheating or turn off the cooling fan if the temperature is low
enough.
If set to work in the Interrupt mode, the ALERT pin will stay asserted after exceeding the
temperature limit, until any internal register is read. When the temperature drops below
the hysteresis level, the ALERT pin will be asserted again, waiting for the internal registers
to be read once again. This mode is used to trigger an interrupt on the host MCU, which is
supposed to read the sensor when the interrupt event is generated.
The device can be set to work in several different power modes. It can be set to
continuously sample the temperature measurements, it can be set to work in the one-shot
mode, and it can be set to stay in the shutdown mode. The shutdown mode consumes the
least power, keeping all the internal sections but the communication section,
unpowered. The one-shot mode allows the device to stay in the shutdown mode, run a
single conversion cycle on demand, and the revert back to the shutdown mode. This allows
for a lower power consumption.
The design of the Click board™ itself is such that the thermal radiation from other
components, which might affect the environmental temperature readings of the sensor, is
reduced. The onboard SMD jumper labeled as VCC SEL allows voltage selection for
interfacing with both 3.3V and 5V MCUs.
Specifications
Type
Temperature / Humidity
Applications
It can be used for the PC case temperature monitoring,
office equipment, and entertainment systems thermal
monitoring, general purpose thermal measurement, etc.
On-board
modules
MCP9800, a high accuracy temperature sensor IC with
Key Features
Low power consumption, selectable sampling resolution,
programmable interrupt engine, compact sensor size,
alert output pin, low components count, PCB design
which retains sensor specifications, etc.
Interface
I2C
Input
Voltage
3.3V or 5V
Click board
size
M (42.9 x 25.4 mm)
Pinout diagram
This table shows how the pinout on Thermo 7 click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Notes
NC
1
AN
PWM
16
NC
NC
2
RST
INT
15
INT
NC
3
CS
RX
14
NC
NC
4
SCK
TX
13
NC
NC
5
MISO
SCL
12
SCL
I2C Clock
NC
6
MOSI
SDA
11
SDA
I2C Data
Power Supply
+3V3
7
3.3V
5V
10
+5V
Power Supply
Ground
GND
8
GND
GND
9
GND
Ground
Interrupt output
Thermo 7 click maximum ratings
Description
Min
Typ
Max
Unit
Temperature Range (accuracy ±3˚C)
-55
+125
°C
Temperature Range (accuracy ±1˚C)
-10
85
˚C
kHz
30
600
ms
Communication speed
Conversion time (min 9bit, max 12bit)
Onboard settings and indicators
Label
Name
Default
Description
JP1
VCC SEL
Left
Power supply voltage selection: left position
3V3, right position 5V
LD1
PWR
Power LED indicator
Software support
We provide a library for Thermo 7 click on our Libstock page, as well as a demo application
(example), developed using MikroElektronika compilers and mikroSDK. The provided click
library is mikroSDK standard compliant. The demo application can run on all the main
MikroElektronika development boards.
Library Description
The library initializes and defines I2C bus drivers and driver functions that offer a choice
for writing data in registers and reading data from registers. The library offers the
possibility of setting the upper and lower temperature limits, and the main thing is reading
the ambient temperature.ADC resolution can be set to 9bit, 10bit, 11bit or 12bit, with an
accuracy of 0.5 C, 0.25 C, 0.125 C or 0.0625 C. The user can adjust the state and behavior of
interrupt pins in the set modes. Modes that can be set are Interrupt mode and Comparator
mode..
Key functions:
float thermo7_readAmbientTemperature() - Function reads ambient temperature
void thermo7_setConfiguration(uint8_t configuration) - Function for configuration
chip and measurement
void thermo7_setResolution(uint8_t resolution) - Function sets ADC resolution
measurement
Examples Description
The application is composed of three sections:
System Initialization - Initializes I2C module and sets INT pin as INPUT.
Application Initialization - Initializes driver init and configuration chip and measurement
resolutions.
Application Task - (code snippet) - Reads ambient temperature and logs to USBUART every 1
second.
void applicationTask()
AmbientTemperature = thermo7_readAmbientTemperature();
FloatToStr( AmbientTemperature, tempText );
mikrobus_logWrite( " Ambient temperature : ", _LOG_TEXT );
mikrobus_logWrite( tempText, _LOG_TEXT );
mikrobus_logWrite( " °C", _LOG_LINE );
Delay_ms( 1000 );
The full application code, and ready to use projects can be found on our Libstock page.
Other mikroE Libraries used in the example:
I2C
UART
Conversions
Additional notes and information
Depending on the development board you are using, you may need USB UART click, USB
UART 2 click or RS232 click to connect to your PC, for development systems with no UART
to USB interface available on the board. The terminal available in all
MikroElektronika compilers, or any other terminal application of your choice, can be used
to read the message.
mikroSDK
This Click board™ is supported with mikroSDK - MikroElektronika Software Development
Kit. To ensure proper operation of mikroSDK compliant Click board™ demo applications,
mikroSDK should be downloaded from the LibStock and installed for the compiler you are
using.
For more information about mikroSDK, visit the official page.
Downloads
mikroBUS™ Standard specification
LibStock: mikroSDK
Thermo 7 click - 2d and 3d files
Thermo 7 click schematic
Libstock: Thermo 7 click library
MCP9800 datasheet
https://www.mikroe.com/thermo-7-click 4-17-18
