THERMOSTAT 3 CLICK
PID: MIKROE-3724
Weight: 26 g
Thermostat 3 Click is a general-purpose thermostat Click board™ designed to be used with any
temperature sensor based on the MAX31855 sensor design. The Click board™ is equipped with a 2pin female socket for thermocouple connection. The K-type thermocouple can be connected directly
into the socket, allowing the MAX31855 to take care of the signal-conditioning and output the
absolute temperature value. The Click board™ also contains a high-quality relay from Omron, that
can be used to open or close an electric circuit. Despite its small size, it can be used with voltage up
to 30VDC/220AC and current up to 5A.
Thermostat 3 click is supported by a mikroSDK compliant library, which includes functions that
simplify software development. This Click board™ comes as a fully tested product, ready to be used
on a system equipped with the mikroBUS™ socket.
The Click board™ is equipped with all the necessary elements, required to provide a
reliable operation: it has a varistor across the relay output contacts, preventing
excessive voltage transients, it has a flyback diode for the backEMF generated within
the relay coil, and a durable mechanical relay, that can withstand up to 20,000,000
mechanical cycles (no load connected). These features allow Thermostat 3 click to be
used for a wide range of applications that have to be thermally controlled: various home
appliances, air conditioners, cooling fans, small heaters, etc.
HOW DOES IT WORK?
Thermostat 3 click board™ is designed around the MAX31855, as the main IC - a
sophisticated thermocouple-to-digital converter with a built-in 14-bit analog-to-digital
converter (ADC), from Maxim Integrated. The device also contains cold-junction
compensation sensing and correction, a digital controller, a SPI compatible interface,
and associated control logic. The Thermostat 3 click is designed to be used with
externally connected K-type thermocouple sensor. The communication with the host
MCU is performed over the SPI interface, using the dedicated pins of the mikroBUS™.
Depending on the temperature information obtained over the SPI interface, the host
MCU can take the necessary action: it can either open or close contacts of the relay.
The Click board™ uses the G6D series PCB power relay, from Omron. This quality
relay can withstand an amazingly large number of mechanical cycles, with no load
connected. However, when there is a significant load connected at its output, microelectric arcs cause the contacts to wear over time. With the maximum load current of
5A, it can sustain up to 70,000 cycles. Its contacts are made of silver alloy, yielding
exceptional ON resistance of only 100mΩ (max).
The relay is activated by the host MCU. The voltage for the coil activation is 5V, while
the current through the coil is 40mA. The MCU is not able to drive the coil directly,
therefore an NPN transistor had to be added. Its base is controlled by the host MCU,
allowing the coil to drain enough current from the 5V mikroBUS™ power rail. The base
of the transistor is routed to the CS pin of the Click board™. The transistor packs two
biasing resistors in the same casing, so it can be directly used on the MCU pin, without
external biasing resistors. A red color LED, labeled as ACTIVE is used to indicate that
the transistor is in an open state and that the current is running through the relay coil.
When the current through a coil (or any other inductor) is suddenly changed, the
backEMF will be generated, opposing the changes of the current. This can sometimes
lead to damage to the control circuit: in this case, the transistor will become inversely
polarized. To prevent this from happening, a flyback diode is added across the coil.
During the normal operation, this diode does not conduct any current. However, when
the coil is switched OFF, the inverse polarization will cause the current to pass through
this diode with minimum resistance. This prevents inverse (flyback) voltage from
building up, so the transistor remains safe.
Contacts at the output may be connected to a higher voltage and larger current may run
through. To prevent high voltage transients in this case, a flyback diode is not a viable
option. Therefore, Thermostat 3 click uses a varistor (VDR). This component rapidly
drops its resistance as the voltage rises above its rated clamping voltage. The
excessive voltage transient will pass through the VDR since it will become a current
path with the least resistance. During the normal operation, while the voltage stays
below the rated clamping voltage, VDR has a very high resistance, so the current runs
through the electrical circuit, instead.
The operating voltage of the Click board™ can be selected by the VCC SEL jumper.
This jumper allows selecting either 3.3V or 5V from the mikroBUS™. The selected
voltage will be applied to the VCC pin of the connected MAX31855 sensor.
SPECIFICATIONS
Type
Temperature & humidity
Applications
Thermostat 3 click can be used for a wide range of applications that have
to be thermally controlled: various home appliances, air conditioners,
On-board
modules
MAX31855, a sophisticated thermocouple-to-digital converter with a builtin 14-bit analog-to-digital converter (ADC), from Maxim Integrated G6D
series PCB power relay, by Omron.
Key Features
Built-in 14-bit analog-to-digital converter (ADC), cold-junction
compensation sensing and correction, a digital controller, SPI interface,
Interface
SPI,GPIO
Compatibility
mikroBUS
Click board
size
L (57.15 x 25.4 mm)
Input Voltage
3.3V,5V
PINOUT DIAGRAM
This table shows how the pinout on Thermostat 3 click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
NC
1
AN
PWM
16
RLY
NC
2
RST
INT
15
NC
CS
3
CS
RX
14
NC
SPI Clock
SCK
4
SCK
TX
13
NC
SPI Data Out
SDO
5
MISO
SCL
12
NC
NC
6
MOSI
SDA
11
NC
3.3V
7
3.3V
5V
10
5V
Chip Select
Power Supply
Notes
Relay Control
Power Supply
Ground
GND
8
GND
GND
GND
9
Ground
ONBOARD SETTINGS AND INDICATORS
Label
Name
Default
Description
LD1
ACTIVE
Relay status LED, lights up when the relay is CLOSED
LD2
PWR
Power LED indicator
CN1
Relay output connector
CN2
External thermocouple connector
JP1
VCC SEL
Left
Power supply voltage selection: left position 3.3V, right
position 5V
SOFTWARE SUPPORT
We provide a library for the Thermostat 3 click on our LibStock page, as well as a demo
application (example), developed using MikroElektronika compilers. The demo can run
on all the main MikroElektronika development boards.
Library Description
The library initializes and defines the SPI bus driver and drivers that offer a choice for
read data form SPI lines. With functions from the library it is possible to read Internal or
Thermocouple temperature data in Celsius, Kelvin or Fahrenheit. The library provides
full relay control and reads fault error status.
Key functions:
float thermostat3_getInternalTemperature(uint8_t TempIn) - Junction (Internal) Temperature
float thermostat3_getThermocoupleTemperature(uint8_t TempIn) - Thermocouple Temperature (K
probe)
void thermostat3_relayControl(uint8_t relayPos) - Relay Control
Examples description
The application is composed of three sections :
System Initialization - Initialzes SPI module and all the necessary GPIO pins
Application Initialization - Initialization driver init
Application Task - Waits for valid user input and executes functions based on set of valid commands
Commands : 'e' - Display Thermocouple temperature 'i' - Display Internal temperature 'r' - Relay
control (Relay ON / OFF) 'f' - Fault flag (Active ON / OFF) '+' - Change fault flage and display fault
status(ERROR / OK)
void applicationTask()
uint8_t dataReady_;
char receivedData_;
thermostat3_process();
dataReady_ = UART_Rdy_Ptr();
if (dataReady_ != 0)
receivedData_ = UART_Rd_Ptr();
switch (receivedData_)
case 'i' :
InternalTemp = thermostat3_getInternalTemperature(_THERMOSTAT3_TEMP_IN_CELSIUS
FloatToStr(InternalTemp, demoText);
mikrobus_logWrite("# Internal Temperature: ", _LOG_TEXT);
mikrobus_logWrite(demoText, _LOG_LINE);
break;
case 'e' :
ThermocoupleTemp = thermostat3_getThermocoupleTemperature(_THERMOSTAT3_TEMP_IN
_CELSIUS);
FloatToStr(ThermocoupleTemp, demoText);
mikrobus_logWrite("# Thermocouple Temperature: ", _LOG_TEXT);
break;
case 'r' :
if(_relayFlag == 1)
_relayFlag = 0;
thermostat3_relayControl(_THERMOSTAT3_RELAY_OFF);
mikrobus_logWrite("# Relay OFF", _LOG_LINE);
else
_relayFlag = 1;
thermostat3_relayControl(_THERMOSTAT3_RELAY_ON);
mikrobus_logWrite("# Relay ON", _LOG_LINE);
break;
case 'f' :
if(_faultFlag == 1)
_faultFlag = 0;
mikrobus_logWrite("# Fault status ‐‐ OFF", _LOG_LINE);
else
_faultFlag = 1;
mikrobus_logWrite("# Fault status ‐‐ ON", _LOG_LINE);
break;
case '+' :
if(_faultFlag == 1)
_fError++;
if(_fError > 3)
_fError = 0;
_displayFault(_fError);
_faultStatus = thermostat3_getFaultData(0x01
