WiFi 6 click - MikroElektonika Documentation
Page 1 of 2
WiFi 6 click
From MikroElektonika Documentation
WiFi 6 click is a mikroBUS™ add-on board with Bluegiga's WF121-A self-contained Wi-Fi module.
With a fully integrated radio and 32-bit microcontroller, this module is ideal for embedded applications.
WiFi 6 click
The module's 2.4GHz band radio is fully compliant with IEEE 802.11b/g/n and offers excellent radio
performance. Allows end user applications to be embedded onto the integrated PIC32MX695H, a 32-bit
80MHz microcontroller with 128KB RAM and 512KB Flash memory, for development of lower-cost
and smaller sized products. Also integrated on-board is a single power supply.
WiFi 6 click communicates with the target MCU through the mikroBUS™ UART (TX, RX), SPI, or
IC2, with additional functionality provided by CTS pin (in place of default mikroBUS™ INT pin); a
mikroProg connector allows to update the firmware of the internal PIC32. SPI interface can be accessed
by jumpers on the click board. The board is designed to use a 3.3 power supply only.
Features and usage notes
The integrated firmware provides Wi-Fi and
networking stack services (TCP/IP, UDP, DHCP,
DNS).
BGAPI host protocol for modem like usage.
BGScript scripting language or native
C-development for self-contained applications.
On-board 32-bit embedded PIC32MX695H 80MHz,
128kB RAM and 512kB Flash memory MCU.
TX Power: +17dBm
RX Sensitivity: -97 dBm
Automatically powers on RF circuitry only when
needed for power saving functionality.
Schematic
also available in PDF
PIC32-series 32-bit MCU on module can reach a
(http://docs.mikroe.com/File:WiFi_6_click_schematic performance of 125 DMIPS while keeping low
power consumption.
◾ Bluetooth coexistence system allows co-located WiFi and Bluetooth devices to be aware of each
other, WF121-A supports sharing the integrated antenna or antenna connector with a Bluetooth
device through the BT_RF pad.
◾ I2C, SPI and UART interfaces.
◾ mikroProg connections for updating firmware for the on-board PIC32.
WiFi 6 click
IC/Module WF121-A (http://www.silabs.com/Support%
20Documents/RegisteredDocs/WF121DataSheet.pdf)
Interface
UART (TX, RX), I2C (SCK, SDA), SPI
(SCK,CS,MISO,MOSI), CTS
Power
supply
3.3V
Website
www.mikroe.com/click/wifi-6
(http://www.mikroe.com/click/wifi-6)
Programming
This snippet shows how easy it is to connect to the WiFi 6 click and begin communication.
1 void main ()
2 {
3
4
//TFT display output initialization.
5
init_TFT();
6
7
//USB UART initialization.
8
UART1_Init(115200);
9
show_status("\r\n**************************",1);
show_status("UART1 initialized",1);
10
11
//WF121 UART initialization.
12
init_WF121_UART();
13
14
//Initialize BGLIB with our output function for sending messages.
15
BGLIB_INITIALIZE(uart_output);
16
17
//Send a Hello command to verify the serial port is working.
18
goto_state(wlan_state_hello);
19
20 }
Code examples that demonstrate the usage of WiFi 6 click with MikroElektronika hardware, written for mikroC for ARM is available on Libstock
(http://libstock.mikroe.com/projects/view/1910/wifi-6-click-library).
Resources
- WF121-A datasheet (http://www.silabs.com/Support%20Documents/RegisteredDocs/WF121-DataSheet.pdf)
- WiFi 6 click code examples on Libstock (http://libstock.mikroe.com/projects/view/1910/wifi-6-click-library)
- mikroBUS standard specifications (http://download.mikroe.com/documents/standards/mikrobus/mikrobus-standard-specification-v200.pdf)
http://docs.mikroe.com/index.php?title=WiFi_6_click&printable=yes
11/2/2016
Page 2 of 2
Retrieved from "http://docs.mikroe.com/index.php?title=WiFi_6_click&oldid=937"
◾ This page was last modified on 17 September 2016, at 08:08.
◾ Content is available under Creative Commons Attribution unless otherwise noted.
11/2/2016
很抱歉,暂时无法提供与“MIKROE-2043”相匹配的价格&库存,您可以联系我们找货
