DTN-G103H3H-DGS102H
DTN-G103H3H-DGS102H
    MMUS(三菱材料)
    环形焊片
    NTC 热敏电阻器 10k 环形焊片
DTN-G103H3H-DGS102H 数据手册
Thermistor Sensor Specification Type Drawing № PW-AP-3610E(1st Edition) Date November DTN-G103H3H-DGS102H 20, Page 2019 1.Usage range This specification is applied to thermistor sensor〔 DTN-G103H3H-DGS102H 〕. RoHS directive pass. 2.Thermistor characteristics Item Particular Specification 2-1 Resistance Resistance at 25℃. R 25 = 10kΩ ±3% 2-2 B-value B-value between t1℃ and t2 ℃ Rt1 1 1 Bt1/t2 = ln Rt2 t1+273.15 t2+273.15 B 25/50 = 3465K ±3% (B 25/85 = 3502K) 2-3 Thermal time constant (ambient temp. change) Where the sensor is screwed up on aluminum block(120L*20W*20T), the block except sensor attached surface is put into 25℃ water. From this state when the block is moved into 50℃ water, the time required for the temperature of the sensor to change by 63.2% of the difference of temperature. τ ≦ 22 sec. 2-4 Dissipation constant The electric power to increase 1 degree in temperature of sensor at 25℃ in still air. δ ≒ 2.8 mW/℃ 2-5 Operating temperature range Tw = -40~+150℃ 2-6 Rated power The electric power which is necessary to make the thermistor self heating up to maximum operating temperature at the ambient temperature 25℃. Pmax. = 2-7 Withstanding voltage A.C.500V-1 minute or A.C.600V-1 second. (between terminal and lead wire) No abnormal found 2-8 Insulation resistance D.C.500V megger. (between terminal and lead wire) I.R. ≧ 100MΩ Mitsubishi Materials Corporation 350 mW 1/4 Thermistor Sensor Specification Drawing № PW-AP-3610E(1st Edition) Page 2/4 3.Reliability characteristics Testing item Testing requirement Changing ratio after test 3-1 Heat resistance test 150℃ in air placed for 1000 hours △R 25 ≦ ±3% △B 25/50 ≦ ±2% Satisfy 2-7,2-8 items. 3-2 Cold resistance test -40℃ in air placed for 1000 hours △R 25 ≦ ±3% △B 25/50 ≦ ±2% Satisfy 2-7,2-8 items. 3-3 High temperature humidity test 60℃,95% R.H. 3-4 P.C.T. 121℃ 3-5 Heat cycle test -40℃〔in air〕⇔ 85℃〔in air〕 each 1 hours. 1000 cycles 2 atm placed for 1000 hours placed for 1000 hours △R 25 ≦ ±3% △B 25/50 ≦ ±2% Satisfy 2-7,2-8 items. △R 25 ≦ ±3% △B 25/50 ≦ ±2% Satisfy 2-7,2-8 items. △R 25 ≦ ±3% △B 25/50 ≦ ±2% Satisfy 2-7,2-8 items. 4.Mechanical characteristics Testing item Testing requirement Characteristics after test 4-1 Lead wire pull test Fix terminal, pull from lead wire axis direction, hang a static load of 49N(5.0kg・f) and stay for 10 minutes. (Two is pulled at the same time) △R 25 ≦ ±3% △B 25/50 ≦ ±2% No abnormal found in appearance and 2-7,2-8 items. 4-2 Lead wire bending test Hang a load of 2.45N (0.25kg・f) on to the lead wire, bend the Sample 90°and then return it to its original position.Carry out this operation within 2~3 seconds, which is counted as 1 cycle. Run 2 cycles. △R 25 ≦ ±3% △B 25/50 ≦ ±2% No abnormal found in appearance and 2-7,2-8 items. 4-3 Drop test Drop on concrete floor from height of 1m 3 times. △R 25 ≦ ±3% △B 25/50 ≦ ±2% No abnormal found in appearance and 2-7,2-8 items. 4-4 Case pressurizing test Sensor insertion axis direction, hang a load of 249N(30kg・f) and stay for 10 minutes. (The trestle and, pushing gold are iron) △R 25 ≦ ±3% △B 25/50 ≦ ±2% No abnormal found in appearance and 2-7,2-8 items. Mitsubishi Materials Corporation Thermistor Sensor Specification Drawing № PW-AP-3610E(1st Edition) Page 3/4 ⑤ 7.2 ④ 2.0±0.5 φ4.3Hole 5.Shape・Dimension 6.2 3.5max 15.7 15±1.5 (mm) Lead wire twist angle Inner structure ➁ ① 30°max ③ 5 Adhesive High heat resistance and Low expansion type Epoxy resin Yes 4 Terminal Ring tongue terminal Yes 3 Lead wire Nickel plated 2 Coating 1 Thermistor № Part CP wire 5.5-S4 (JST) φ0.4 Yes High heat resistance and Low expansion type Epoxy resin Yes Glass enclosing chip Yes (GA13 type) Specification Mitsubishi Materials Corporation RoHS compliant Thermistor Sensor Specification Drawing № PW-AP-3610E(1st Edition) Page 4/4 6.Caution in Thermistor Sensor usage Due to the possibilities of destruction of the sensor, damage or miss use of equipment, please strictly follow below matter. ①The sensor is designed for individual usage. When it is going to be used beyond the specified condition, please speak to your daily contact person for our products. ②Whenever designing the equipment, make sure to check sensor operation and if there is no lack of quality. ③Do not use the sensor exceeding rated electric power. ④Due to possibility of causing the decrease of the value of resistance with self heat and malfunction of the equipment or the precision decrease of the inspection temperature, carefully refer to the dissipation constant usage of electric power and voltage. ⑤Do not use the sensor beyond operating temperature range. ⑥Avoid from exceeding radical temperature change, which is beyond operating temperature range. ⑦In case of independently use of the sensor as a main control of the device, make sure to design and devise through safety measures for [safe circuit] and [parallel use with same function sensor] etc, to prevent from accident. ⑧Under the environment which receives the influence of electric noise, make sure to take countermeasure by installing a protection circuit and seal the sensor. (including the lead wire) ⑨When the case type sensor is used under high humidity environment, make sure to design so that the protected case tip must be exposed to environment (in water, moisture) condition, and open part of the case must be prevented from not touching water and steam directly. ⑩Do not add excessive vibrating shocking pressure. ⑪Avoid from excessive pulling and bending of the lead wire. ⑫Do not impress excessive voltage in the insulated part and between the electrode. This might cause to occur the insulated malfunction. ⑬Consider wiring, due to contact failure might occur if the terminal of the lead wire (including the connector) is immersed into [water] [steam] [electrolyte] etc. ⑭Do not use in corrosiveness gas atmosphere (Cℓ2, NH3, SOX, NOX) beyond the designated condition. Do not use at the place where the sensor touches the electrolytic, brine, acid, alkaline and organic solvent beyond the designated condition. ⑮Due to possibility of the equipment becoming malfunction depending upon metal corrosion, consider not to cause potential difference with the contact metal for the case and screw equipped type sensor. If there is any others unclear point, please inquire to our company sales in-charge. Mitsubishi Materials Corporation
DTN-G103H3H-DGS102H 价格&库存
很抱歉,暂时无法提供与“DTN-G103H3H-DGS102H”相匹配的价格&库存,您可以联系我们找货
