Thermistor Sensor Specification
Type
Drawing №
PW-AP-3611E( 1st Edition)
Date
November
DTN-V103J3T-DGS103V
Page
20,
1/4
2019
1 . Usage range
This specification is applied to thermistor sensor〔 DTN-V103J3T-DGS103V 〕 .
RoHS directive pass.
2 . Thermistor characteristics
Item
2-1
Resistance
2-2
B-value
2-3
Thermal time
constant
(ambient temp.
change)
Particular
Sign
Char.
Unit
Tol.
R 25
10
kΩ
± 5%
B-value between t1℃ and t2 ℃
Rt 1
1
1
Bt 1/t 2=ln
Rt 2
t 1+273.15
t 2+273.15
B 25 /5 0
3820
K
± 3%
Where the sensor is screwed up on
aluminum block(120L*20W*20T), the block
except sensor attached surface is put into
25℃ water. From this state when the block
is moved into 50℃ water, the time required
for the temperature of the sensor to change
by 63.2% of the difference of temperature.
τ
27
sec.
Tw
-40~
+150
3
mW/℃
Resistance at 25℃ .
2-4
Operating
temperature
range
(B 25 /8 5 = 3792K)
2-5
Dissipation
constant
The electric power to increase 1 degree in
temperature of sensor at 25℃ in still air.
δ
2-6
Maximum
permissible
power
The power taking temperature of sensor to
upper limit of operating temperature range
by self-heating at 25℃ in still air.
Pmax.
2-7
Withstanding
voltage
A.C.500V 1 minute or A.C.600V 1 second.
(In water between case and lead wire)
No abnormal found
2-8
Insulation
resistance
D.C.500V megger.
I.R.
Mitsubishi Materials Corporation
or less
approx.
375
100
mW
MΩ
or more
Drawing №
Page
2/4
3 . Reliability characteristics
Testing item
Testing requirement
Changing ratio after test
3-1
Heat resistance
test
150℃
in air
placed for 1000 hours
△ R25
≦ ± 5%
△ B 2 5 / 5 0 ≦ ± 3%
3-2
Cold resistance
test
-40℃
in air
△ R25
≦ ± 5%
40℃ ,95%R.H.
△ R25
≦ ± 5%
3-3
High temperature
humidity test
3-4
Heat cycle test
-40℃ , 3 minutes ⇔ 125℃ , 3 minutes
〔 in air〕
〔 in air〕
600 cycles
△ R25
≦ ± 5%
4 . Mechanical characteristics
Testing item
Testing requirement
Characteristics after test
4-1
Pull test
From lead wire axis direction, hang a static
load of 29.4N(3.0kg・f) and stay for 1 minute
between case part and lead wire.
4-2
Vibration test
Frequency:20~ 200Hz, Cycle:15 minutes.
There is no abnormality in
Acceleration:4.4G
appearance and electrical
Vibrate up/down 4 hours,back/forth and right/left characteristics.
each 2 hours.
4-3
Drop test
Drop on wood from height 1m 5 times.
characteristics.
characteristics.
Drawing №
Page
3/4
⑦ ⑥
7.2
φ3.7Hole
5 . Shape・ Dimension
5±1
6.2
(30)
15.7
1000±20
(mm)
① ② ④⑤
③
Some lot indication is shown on lead wire.
Lot indication
① ②③ (made in Japan condition )
③ ②① (made in Malaysia condition)
V ①② ③ (made in Vietnam condition)
① :End of № for year of christian era.0~9
② :Month indication
1~9 Month characters,
10-X,11-Y,12-Z indication
③ :Lot serial № on that month indication
A~Z or AA ~ZZ (made in Japan or Vietnam condition ),
MA~MZ,AA ~AZ,BA ~BZ (made in Malaysia condition)
7
Case
Ring tongue terminal
5.5-S3
(JST)
6
Adhesive
Heatproof low expansion Epoxy resin
Yes
5
Coating
Yes
4
Coating
Yes
3
Lead wire
Cross linked polyethylene parallel wire
150℃ Heatproof
2
φ 1.08 0.14㎜ (7/0.16)〔Black〕 Tin plated soft copper wire
Yes
2
Solder
Lead free
Yes
1
Thermistor
Chip thermistor
Yes
Parts
Specifications
Yes
RoHS compliant
Drawing №
Page
4/4
6 . Caution in Thermistor Sensor usage
Due to the possibilities of destruction of the sensor, damage or miss use of equipment,
please strictly follow below matter.
① The sensor is designed for individual usage. When it is going to be used beyond the
specified condition, please speak to your daily contact person for our products.
② Whenever designing the equipment, make sure to check sensor operation and if there is no
lack of quality.
③ Do not use the sensor exceeding rated electric power.
④ Due to possibility of causing the decrease of the value of resistance with self heat and
malfunction of the equipment or the precision decrease of the inspection temperature,
carefully refer to the dissipation constant usage of electric power and voltage.
⑤ Do not use the sensor beyond operating temperature range.
⑥ Avoid from exceeding radical temperature change, which is beyond operating temperature
range.
⑦ In case of independently use of the sensor as a main control of the device, make sure to
design and devise through safety measures for [safe circuit] and [parallel use with same
function sensor] etc, to prevent from accident.
⑧ Under the environment which receives the influence of electric noise, make sure to take
countermeasure by installing a protection circuit and seal the sensor.
(including the lead wire)
⑨ When the case type sensor is used under high humidity environment, make sure to design
so that the protected case tip must be exposed to environment (in water, moisture)
condition, and to the [utmost] open part of the case must be prevented from not touching
water and steam directly.
Please note how such as making the opening downward to install it so as not to stay
in this part when you generate the be dewy water.
⑩ Do not add excessive vibrating shocking pressure.
⑪ Avoid from excessive pulling and bending of the lead wire.
⑫ Do not impress excessive voltage in the insulated part and between the electrode.
This might cause to occur the insulated malfunction.
⑬ Consider wiring, due to contact failure might occur if the terminal of the lead wire
(including the connector) is immersed into [water] [steam] [electrolyte] etc.
⑭ Do not use in corrosiveness gas atmosphere (Cℓ 2, NH 3, SO X, NO X) beyond the designated
condition.
Do not use at the place where the sensor touches the electrolytic, brine, acid,
alkaline and organic solvent beyond the designated condition.
⑮ Due to possibility of the equipment becoming malfunction depending upon metal corrosion,
consider not to cause potential difference with the contact metal for the case and screw
equipped type sensor.
If there is any others unclear point, please inquire to our company sales in-charge.
DTN-V103J3T-DGS103V 价格&库存
很抱歉,暂时无法提供与“DTN-V103J3T-DGS103V”相匹配的价格&库存,您可以联系我们找货
