R41-B574Z
R41-B574Z
    NMBTECHNOLOGIESCORPORATION
    HSD®,Fakra,四轴 连接器 插头,公引脚 100 欧姆 通孔 焊接
R41-B574Z 数据手册
HSD Right Angle Connector CAM-K72LN / R41-B574 Features Model Name Part Number Description Coding Direction Signal Pin Power Pin Housing Shell Cover Materials Copper Alloy Copper Alloy PA Resin Zinc Alloy PA Resin CAM-K72LN R41-B574 HSD 4+2 Connector, Right-Angle Normal External Dimensions Height 14.15 mm Width 15.65 mm Depth 27.3 mm Outer Contact Length 2.3 mm Applicable Standards USCAR-2 DIN EN 60068-2 SPECIFICATIONS Electrical Characteristics Impedance Frequency Range Return Loss Insertion Loss Skew Near-end Crosstalk Far-end Crosstalk Insulation Resistance Signal Contact Resistance Outer Contact Resistance Test Voltage Working Voltage Power Current Signal Current Differential Shielding Effectiveness Mechanical Characteristics Mating Cycles Engagement Force Disengagement Force Retention Force Latch Environmental Conditions Temperature Range Thermal Shock Temperature and Humidity Vibration Mechanical Shock Maximum Soldering Temperature RoHS Compliant/Lead Free NMB Technologies Corporation • MinebeaMitsumi Group Tel: 248-919-2250 • www.nmbtc.com 100Ω DC to 2 GHz ≥ 20 dB up to 1 GHz; ≥ 17 dB up to 2 GHz ≤ 0.1 dB up to 2 GHz ≤ 5 ps ≤ 30 dB (1GHz) ≤ 35 dB (1GHz) ≥ 1 x 103 MΩ ≤ 20 mΩ ≤ 20 mΩ 250 Vrms 100 Vrms Max. DC 5A Max. DC 3A ≥ 75 dB up to 1 GHz; ≥ 65 dB up to 2 GHz ≥ 25 ≤ 60 N ≥5N ≥ 110 N -40 °C ~ 105 °C DIN EN 60068-2-14 USCAR-2 Rev. 4 (5.6.2) DIN EN 60068-2-64 DIN EN 60068-2-27 255 °C Compliant HSD Right Angle Connector CAM-K72LN / R41-B574 DiMENSIONS / FOOTPRINT / TERMINAL PINNING Packing Weight/Unit Reel 7.49 g 150 pcs/reel; 450 pcs(3 reels)/carton ORDERING INFORMATION HSD Coding Shape Coding Color RAL. No. Part Number A Jet Black 9005 R41-B574A B Cream White 9001 R41-B574B C Signal Blue 5005 R41-B574C D Claret Violet 4004 R41-B574D E Leaf Green 6002 R41-B574E F Nut Brown 8011 R41-B574F Z Water Blue 5021 R41-B574Z NMB Technologies Corporation • MinebeaMitsumi Group Tel: 248-919-2250 • www.nmbtc.com
R41-B574Z 价格&库存
很抱歉,暂时无法提供与“R41-B574Z”相匹配的价格&库存,您可以联系我们找货
