175MU
175MU
    MUELLERELECTRIC
    可编程(多功能) 延时继电器 SPDT(1 Form C) 0.1 秒 ~ 3 小时 延时 3A @ 250VAC DIN 轨道
175MU 数据手册
NEW PRODUCTS 175MU Series SPECIFICATIONS ACCURACY Setting: ±5% of F.S. Repeat: ±0.5% (F.S. = Full Scale) RESET Reset time < 100 msec OUTPUT CONTACT SPDT (1 C/O) CONTACT N/O:5A@ 250V AC RATING N/C:3A @ 250V AC E55826 Multi-Function Timer • 13 Functions • 10 Time Ranges • Front knobs for Time Range, Time Scale & Mode Setting • Slim, Space Saving Design • DIN Rail Mount DIMENSIONS (MILLIMETERS) 45mm 90 mm 35.3 mm 67.5mm On delay (A) Interval (B) Cyclic equal OFF first (C) Cyclic equal ON first (Ci) Pulse output, 500ms fixed (D) Delay on break (E) Delay on make / Delay on break (F) Interval after break (H) Single shot (I) Retriggerable Single shot (J) Latching relay (K) Delay with Totalize (Ai) Interval with Totalize (Bi) TIME RANGES 0.1 - 1 sec, 0.3 - 3 sec, 1-10 sec, 3-30 sec 0.1-1 min, 0.3-3 min, 1-10 min, 3-30 min 0.1-1 hr, 0.3-3 hr SUPPLY VOLTAGE 20-240V AC, 12-240V DC AC : (50 / 60 Hz) POWER 43.2VA max CONSUMPTION 44mm 17.5 mm Symmetrical 35mm Din Rail (EN50022) Mounting MODES 60 mm TEMPERATURE Operating: 0 to 50°C (32 to 122°F) Storage: -20 to 75°C (-4 to 167°F) HUMIDITY 95% RH (NON-CONDENSING) WEIGHT 0.163 lbs. PROTECTION LEVEL IP40 for Casing IP20 for Temrinals TERMINAL CONNECTIONS + ~– A1 A2 Control Contact Y1 15 25 16 18 NC NO ORDERING INFORMATION PART NO. 175MU SUPPLY VOLTAGE 20-240V AC/DC 12-240V DC COM Cable Size (AWG): 16 ; Tightening Torque (Lb-inch): 4.5 Cable Size (mm2): 1.5 ; Tightening Torque (N-m): 0.5 2 Automatic Timing & Controls 800.727.5646 automatictiming.com Function: Cyclic Equal OFF First (C) Function: Interval (B) Supply Voltage Supply Voltage Start NO Contact NC Contact NO Contact NC Contact T Supply Voltage NO Contact NC Contact T Function: Cyclic Equal ON First (Ci) T T Function: Delay On Break (E) Function: Pulse Output (D) Supply Voltage T T = set time T = set time T = set time NEW PRODUCTS Function: ON Delay (A) 175MU Series TIMING DIAGRAMS Supply Voltage (U) Supply Voltage Control Contact (Y1) NO Contact NC Contact T T NO Contact NC Contact T NO Contact NC Contact P T T = set time; P =500msec T = set time Function: Delay On Make / Break (F) Function: Interval After Break (H) Function: Single Shot (I) Supply Voltage (U) Supply Voltage (U) Control Contact (Y1) Control Contact (Y1) Control Contact (Y1) NO Contact NC Contact NO Contact NC Contact T T T = Set time Function: Retriggerable Single Shot (J) T NO Contact NC Contact T = Set time Function: Latching Relay (K) Supply Voltage (U) Control Contact (Y1) Control Contact (Y1) Control Contact (Y1) NO Contact NC Contact NO Contact NC Contact T ta
175MU 价格&库存
很抱歉,暂时无法提供与“175MU”相匹配的价格&库存,您可以联系我们找货
