425AR-100-T5X
425AR-100-T5X
    MUELLERELECTRIC
    可编程(多功能) 延时继电器 DPST-NO(2 FormA) 0 秒 ~ 9999 小时 延时 5A @ 230VAC DIN 轨道
425AR-100-T5X 数据手册
START INPUT Gate/Pulse start (programmable) ACCURACY RESET ±0.05% of F.S or 50 msec (F.S.=Full Scale) Front, Remote, Power interruption (programmable) OUTPUT CONTACT 2 SPST (2 NO) 425AR Series SPECIFICATIONS RELAY RATING 5A @ 230V AC MODES ON delay / Interval delay Cyclic ON first / Cyclic OFF first Forward-pause-reverse Instantaneous + delayed Batch Multifunction Timer • Multifunction - 7 Timing Functions • 9 Time Ranges • Dual Display, 4 Digit, 7 segment LED • LED Status Indicator: Relay Status, Seconds, Minutes, Hours COUNTING Up/Down DIRECTION • Batch Function 10 years CONFIGURATION Password protected LOCK DIMENSIONS SUPPLY VOLTAGE 90 to 270V AC/DC (50/60Hz) -15% to 10% tolerance 46mm 5VA max. TEMPERATURE Operating: 0-50°C (32 to 122°F) Storage: -20 to 75°C (-4 to 167°F) HUMIDITY 95% RH (non-condensing) WEIGHT 6.2 oz. PROTECTION LEVEL IP65 for faceplate 48mm POWER CONSUMPTION (INCHES/MILLIMETERS) 10mm 48mm 46mm MEMORY • 2 Setpoints PANEL MOUNTED DIGITAL TIMERS 0-99.99 sec 0-999.9 sec 0-9999 sec 0-99:59 min:sec, 0-999.9 min 0-9999 min 0-99:59 hr:min, 0-999.9 hr 0-9999 hr 45mm TIME RANGES E339488 100mm TERMINAL CONNECTIONS 1 11 6 + 2 12 7 3 13 8 + 4 14 9 – 5 15 10 GND L (+) NO1 – 24V AC/DC MODEL AVAILABLE Please consult factory COM1 NO2 COM2 (-) N RST +12V STRT Cable Size (AWG): 13; Stud Hole for Lug (inch): 0.137 ; Tightening Torque (Lb-inch): 7 ORDERING INFORMATION MODEL NUMBER 425AR100T5X Automatic Timing & Controls 800.727.5646 SUPPLY VOLTAGE 90 to 270 V AC/DC automatictiming.com 107 425AR Series TIMING DIAGRAMS Function: ON Delay Function: Interval Supply Voltage Supply Voltage Start Start Start Reset Reset Reset Output NO ON Delay NC Output NO ON Delay NC Output NO Cyclic ON NC tStrt PANEL MOUNTED DIGITAL TIMERS Function: Cyclic ON First Supply Voltage t tStrt t tStrt tStrt = start time ; t = set time delay Function: Cyclic OFF First tStrt tStrt t1 t Function: Motor Reverse Mode Supply Voltage Reset Output NO Cyclic OFF NC t2 t1 tStrt t1 t2 Function: Instantaneous + Delayed At Power ON Supply Voltage Start Reset Instant NO Contact NC Delayed NO Contact NC t1 t2 t3 t2 tStrt t1 = ON time of Relay1 ; t2 = Pause time ; t3 = ON time of Relay2 t Function: Batch Preset 0 Output t tStrt t tStrt = start time ; t = set time delay 108 Automatic Timing & Controls t2 800.727.5646 tStrt t tStrt = start time ; t = set time delay Batch tStrt tStrt t1 t2 Supply Voltage Start Reset Instant NO Contact NC Delayed NO Contact NC t1 t2 tStrt = start time ; t1 = OFF time ; t2 = ON time t2 tStrt = start time ; t1 = ON time ; t2 = OFF time Function: Instantaneous + Delayed At Start Pulse Supply Voltage Start Reset NO Relay 1 NC NO Relay 2 NC Start tStrt t1 t tStrt = start time ; t = set time delay automatictiming.com
425AR-100-T5X 价格&库存
很抱歉,暂时无法提供与“425AR-100-T5X”相匹配的价格&库存,您可以联系我们找货
