653-8-5001
    MUELLERELECTRIC
    可编程(多功能) 延时继电器 DPDT(2 Form C) 0.001 秒 ~ 199 小时 59 分 延时 7A @ 240VAC 面板安装
653-8-5001 数据手册
These programmed values are retained in memory and are secured in memory by a keypad lockout command. The keypad can also be used to perform secondary functions such as reset, immediate time/count out, time/count inhibit, changing the direction of the display, displaying the number of cycles run, and clearing the cycle counter. The Model 653 is housed in a standard 15-terminal plug-in round case. Models are available for operation on either 120 VAC or 240 VAC. Counting can be done at either line voltage or at 12-48 VDC/24 VAC jumper selected. E205980 Multi-Function Multi-Range Solid-State • Functions As Timer or Counter • Five Time Ranges • Six Single-Cycle and Eight Repeat-Cycle Timing Modes • Sealed Faceplate • Cycle Counter DIMENSIONS (INCHES/MILLIMETERS) • Count Input Scaling • Data Retention Memory with EEPROM Circuitry. (653-8-4000, 653-8-4001 Models) • Data Retention Memory with Lithium Battery (included with timer) (653-8-5000, 653-8-5001 Models) PANEL MOUNTED DIGITAL TIMERS The timing range, count speed and timing mode are programmed with an internal DIP switch assembly. An external switch determines whether the time inhibit or count input takes place with application or removal of voltage. The time or count value is preset by the operator using the keypad on the front face. 653 Series The ATC 653 is a micro-processor-based control that can function as either a timer or a counter. It has a 4-1/2 digit LCD that can provide an indication of either the time or count value remaining or elapsed. There are five timing ranges covering time values from one millisecond to 199 hours 59 minutes. There are also three count speeds to a maximum of 7500 counts per second. The unit has an instantaneous relay output and a programmable relay output which can be programmed for any one of 14 different timing modes. WIRING model 600-3-3950 surface mounting bracket Automatic Timing & Controls 800.727.5646 automatictiming.com 111 653 Series PANEL MOUNTED DIGITAL TIMERS SPECIFICATIONS (ALL MODELS) TIMING RANGES 0.001 SEC to 19.999 SEC 0.01 SEC to 199.99 SEC 0.1 SEC to 1999.9 SEC 1 SEC to 199 MIN 59 SEC 1 MIN to 199 Hr. 59 MIN COUNT MODES 500 CPM, AC/DC 5000 CPM, AC/DC 7500 CPS, DC Only MODE OF OPERATION ON-Delay, Interval, Reverse Start Delay Reverse Start Interval, Momentary Start Accumulator, Repeat Cycle-OFF First Repeat Cycle-ON First, Repeat Cycle Reverse Start-OFF First, Repeat Cycle Reverse Start-ON First, Repeat Pulse Repeat Pulse, First Pulse Immediate Repeat Pulse-Reverse Start, Repeat Pulse First Pulse Immediate Reverse Start TIME SETTING Front Panel Keypad TIME REPEAT ACCURACY Count: 100% Time: ±0.005 SEC DISPLAY LCD - 4 1/2 Digit, 7/16" High RELAY MECHANICAL LIFE 50,000,000 Operations SPECIFICATIONS (652-8-4000 & 652-8-4001) RESET TIME 25 mSEC CONTROL VOLTAGE INITIATE TIME 25 mSEC MEMORY EEPROM Circuitry POWER CONSUMPTION 5.2 VA SPECIFICATIONS (652-8-5000 & 652-8-5001) RESET TIME 8 mSEC CONTROL VOLTAGE INITIATE TIME 8 mSEC MEMORY Lithium Battery (Included with unit) POWER CONSUMPTION 3.7 VA INSTANTANEOUS 7 Amps Resistive, 240 VAC, 2 N.O. RELAY OUTPUT 1 N.C. Contact TIMED RELAY OUTPUT 7 Amps Resistive, 240 VAC, 2 N.O. 2 N.C. Contacts TEMPERATURE 32° - 140°F (0° - 60°C) RATING ORDERING INFORMATION MODEL NUMBER DESCRIPTION OPERATING POWER 120 or 240 VAC, +10%, -20%, 50/60 Hz 653-8-4000 Plug-in, Round Case Timer 120 VAC W/EEPROM Memory TRANSIENT VOLTAGE PROTECTION Metal Oxide Varistor 653-8-4001 Plug-in, Round Case Timer 240 VAC W/EEPROM Memory NEMA RATING NEMA 12 653-8-5000 Plug-in, Round Case Timer 120 VAC W/Battery Memory TERMINALS Screw Terminals MOUNTING Plug In Case 653-8-5001 Plug-in, Round Case Timer 240 VAC W/Battery Memory WEIGHT Net: 25 oz. Shipping: 30 oz. 651-3-0128 Mounting Gasket, 1/8" Thick (Included With Timer) 651-3-0129 Mounting Gasket, 1/4" Thick (Included With Timer) 600-3-3950 Base Mounting Bracket Replacement lithium batteries - Old ATC Part #652-3-0130 is not available. Use TADIRAN#TL-5902/S SAFT, #LS14250 or EAGLE-PICHER #PT-2150 from most electrical distributers. 112 Automatic Timing & Controls 800.727.5646 automatictiming.com
653-8-5001 价格&库存
很抱歉,暂时无法提供与“653-8-5001”相匹配的价格&库存,您可以联系我们找货
