GFD-100
GFD-100
    MUELLERELECTRIC
    THREE PHASE GROUND FAULT DISPLAY
GFD-100 数据手册
GFD Series The ATC Diversified Electronics GFD Series is intended for the use on ungrounded systems to detect and indicate the phase of the first ground fault condition. This enables corrective action to avoid the potential hazards resulting from a second ground fault. OPERATION With nominal 3 phase line voltage applied, a flashing NORMAL green LED gives indication of a non-fault condition and integrity of the wire connection to the corresponding phase. A flashing red LED gives positive FAULT indication of either a phase-toground fault, or a lost connection to the corresponding phase. NOTE: Distributed capacitance to ground or equally loaded phases to ground will de-sensitize detection and will require lower phase-to-ground resistance to produce a FAULT indication. 3-Phase Ground Fault Display SPECIFICATIONS DIMENSIONS (INCHES) NOMINAL VOLTAGE 208-600 VAC, ±10%, Phase-to-Phase, 50/60 Hz MAX. CONTINUOUS VOLTAGE 660 VAC, Phase-to-Phase REV. CONNECTION Yes PROTECTED POWER ALERTS DETECTION THRESHOLD 11.7 k Ω ±20% @ 50 Hz; 9.3 k Ω ±20% @ 60 Hz Single Phase-to-Ground WIRING DETECTOR INDUCED 50 Hz FAULT CURRENT 60 Hz 7.5 mA @ 600 VAC (1 Phase-to-Ground shorted) 9 mA @ 600 VAC (1 Phase-to-Ground shorted) FRESNEL LENS INDICATORS Normal Fault (3) Green LEDs, 2 Flashes/Sec (3) Red LEDs, 2 Flashes/Sec APPARENT POWER REQUIRED 50 Hz 60 Hz 2.5 VA @ 600 VAC 3 VA @ 600 VAC TEMPERATURE RATINGS Operate Storage 32° to 131°F (0° to +55°C) -40° to 185°F (-40° to +85°C) ENCLOSURE 94V-0 Flame Retardant Black ABS Plastic, Panel Mount with 1/4" Plastic Electrical Conduit Adapter, Encapsulated for Environmental Protection TERMINATIONS (4) 2 ft., 18 AWG, 600V, 105°C PVC Stranded Wire w/ Wire Pin Terminations, racketed with 18" Slit Nylon Corrugated Tubing, .556" O.D. WEIGHT NET: 3.52 oz Shipping: 5.12 oz ORDERING INFORMATION 226 Diversified Electronics MODEL NUMBER DESCRIPTION GFD-100 GFD-200 Vertical Mount Horizontal Mount 800.727.5646 atcdiversified.com
GFD-100 价格&库存
很抱歉,暂时无法提供与“GFD-100”相匹配的价格&库存,您可以联系我们找货
