UOA Series
The UOA Series offers protection to SINGLE PHASE equipment that is
required to operate above a certain voltage minimum.
OPERATION
STYLE "A"
Style A
only
STYLE "N"
With operating voltage applied above the preset PICK-UP voltage, the
internal relay will energize. When the voltage falls below the preset
DROP-OUT voltage for a period longer than the release delay, the output
relay will de-energize. When line conditions return above the preset
PICK-UP voltage, the UOA Series automatically resets and the internal
relay energizes.
The HYSTERESIS in each unit provides a differential between the PICK-UP
and DROP-OUT trip points.
E55826
Single Phase Under Voltage Monitor
MODEL
NUMBER
PHASE VOLTAGE MONITORS
SPECIFICATIONS
OPERATING
Style A
RATING
Style N
DPDT, 5A @ 240 VAC, Resistive;
211 VA @ 240 VAC
SPDT, 10A @ 240 VAC, Resistive;
180 VA, Inductive, @ 120 VAC
RESPONSE TIMES Operate
Release
50 mSEC. (approx.) (500 mSEC. on
12 VDC units)
0.5 SEC (approx.)
TEMPERATURE
RATING
32° to +131°F (0° to +55°C)
-49° to 185°F (-45° to +85°C)
Operate
Storage
POWER REQUIRED Models Up To 110 VDC: 3 Watts, Max.
Models Up To 300 VAC: 5 VA, Max.
WEIGHT
5 oz. to 5.5 oz.
UOA-24-A*A
UOA-120-A*A
UOA-208-A*A
UOA-240-A*A
UOA-12-D*A
UOA-24-D*A
UOA-48-D*A
UOA-110-D*A
UOA-220-D*A
UOA-240-D*A
UOA-120-AFN
UOA-208-AFN
UOA-220-AFN
UOA-230-AFN
UOA-240-AFN
*Adjustments -
DROP-OUT PICK-UP HYSTERESIS
VOLTAGE VOLTAGE VOLTAGE
19-27 VAC
97-130 VAC
177-222 VAC
205-250 VAC
9-14 VDC
19-27 VDC
38-53 VDC
92-125 VDC
185-230 VDC
205-250 VDC
100 VAC
180 VAC
180 VAC
190 VAC
202 VAC
F = Fixed
K = Knob
L = Locknut
WIRING
RB-08 or PF083A
166
Diversified Electronics
800.727.5646
atcdiversified.com
21-29 VAC
102-135 VAC
185-230 VAC
215-260 VAC
10-15 VDC
21-29 VDC
40-55 VDC
97-130 VDC
194-239 VDC
215-260 VDC
105 VAC
188 VAC
187 VAC
198 VAC
210 VAC
2
5
8
10
1
2
2
5
9
10
5
8
7
8
8
很抱歉,暂时无法提供与“UOA-240-AKA”相匹配的价格&库存,您可以联系我们找货
