UPA-100S
UPA-100S
    MUELLERELECTRIC
    UNIVERSAL POWER ALERT-SOLID ON
UPA-100S 数据手册
UPA-100 Series The UPA-100 Power Alert reduces the risk of electrical arc flash by pre-verifying the electrical isolation from outside of a control panel. Hard wired to the circuit breaker or main disconnect, the UPA flashes whenever voltage is present. Engineered with redundant circuitry, the Power Alert is powered by the same voltage that it indicates. IND. CONT. EQ. 496Y OPERATION The eight detector UPA-100 visually alerts to the presence of dangerous AC or DC (Stored Energy) potentials occurring between any combination of the four monitored input lines (L1, L2, L3, GND). Two LED indicators are assigned to each input line and are designated “+” and “-”. For each input line carrying an AC potential (bi-polar), both the “+” and “-” LEDs will be active. A DC or Stored Energy potential will illuminate the “+” LED for the positive line and the “-” LED for the negative line. UL TYPE 4X Universal Power Alert OSHA 1910.147 THE CONTROL OF HAZARDOUS ENERGY (LOCKOUT/TAGOUT) If there is a possibility of reaccumulation of stored energy to a hazardous level, verification of isolation shall be continued until the servicing or maintenance is completed, or until the possibility of such accumulation no longer exists. (d)(6) “Verification of Isolation.” Prior to starting work on machines or equipment that have been locked out or tagged out, the authorized employee shall verify that isolation and de-energization of the machine or equipment have been accomplished. SPECIFICATIONS OPERATIONAL RANGE AC Single or 3-Phase DC or Stored Energy MAXIMUM RATED VOLTAGE 750 VAC/1000 VDC (LINE-TO-LINE or LINE-TO-GND) DETECTION THRESHOLDS 29 VAC 3-Phase, 40 VAC SINGLE-Phase, 27 VDC (TYP Cutoff) POWER CONSUMPTION 1.2 Watts @ 750 VAC (Approximately) TEMPERATURE RATING Operate Storage ENCLOSURE NEMA 4X 105°C PVC, Totally Encapsulated for Environment Protection TERMINATIONS (4) 8 ft, 18 AWG 1000V, UL-1452 WEIGHT 9 oz. 40 to 600 VAC, 50/60/400 Hz, (LINE-TO-LINE or LINE-TO-GND) 30 to 1000 VDC, (LINE-TO-LINE or LINE-TO-GND) • Detects Single or 3-Phase AC & DC Voltage or Stored Energy • Redundant Circuitry • Verification of Zero Energy in a Panel • Fits 1-1/4" Conduit Knock-Out ORDERING INFORMATION MODEL NUMBER DESCRIPTION UPA-100 UPA-100S Universal Power Alert Universal Power Alert Solid-ON Red Accessories UPA-WP100 ANSI WARNING Plate The UPA-100 Series is UL Listed under UL File Number E55826. UPA-100C UNIVERSAL POWER ALERT CAT III CAT IV DIMENSIONS (INCHES) -4° to 131°F (-20° to +55°C) -40° to 185°F (-40° to +85°C) POWER ALERTS Following the application of lockout or tagout devices to energy isolating devices, all potentially hazardous stored or residual energy shall be relieved, disconnected, restrained, and otherwise rendered safe. (d)(5)(ii) INDICATOR FLASH RATES (L1, L2, L3, GND) 3- Phase Line-To-Line (VAC)
UPA-100S 价格&库存
很抱歉,暂时无法提供与“UPA-100S”相匹配的价格&库存,您可以联系我们找货
