MTQ-LVW3-B02.R1
MTQ-LVW3-B02.R1
    MULTI-TECHSYSTEMS
    Module
    RX TXRX MOD CELL U.FL CHAS MNT
MTQ-LVW3-B02.R1 数据手册
MultiConnect Dragonfly™ ® Embedded Cellular SoM (System-on-Module) BENEFITS ·· End device certified by leading carriers ·· Family of cellular options include 4G-LTE, 3G HSPA+, 3G EV-DO and 2G 1xRTT ·· Developer friendly to integrate, quick to deploy and scale assets The MultiConnect® Dragonfly™ cellular SoM’s are fully certified and MNO approved, ready-to-integrate modules that offer ·· Long solution lifecycle reduces redesign time and cost developers the functionality of a programmable computing FEATURES platform with the convenience of an onboard cellular radio ·· Lightweight SoM ideal for most IoT applications all in one compact design. Dragonfly is programmable using ARM® mbed™ allowing for rapid prototyping, development ·· On-board GNSS or GPS for fast and accurate location fix (3G models) and deployment. With its integrated Cortex®-M4 processor, developers can host their application and have access to a full ·· Multiple I/O interfaces for connecting most any “Thing” suite of interfaces for connecting sensors or other remote assets. ·· Design in or retrofit Your Devices & Data Connecting Your Devices Insight + Action + Control Energy Alerts Financial / Retail Real-Time Management Healthcare Remote Monitoring www.multitech.com/Dragonfly Wireless Service Provider Asset Management Platform Reports HIGHLIGHTS Design in or Retrofit Host Your Applications embedded cellular SoM providing the maximum The MultiConnect Dragonfly can be used as an As the first ARM mbed cellular SoM listed on in design and application flexibility or it can be used as mbed.org that is industry certified and deployment an embedded cellular modem controlled through AT ready, applications can be written and compiled quickly commands requiring little or no modification to your online using developer friendly libraries, downloaded design. Connecting to the Dragonfly through its 40-pin and hosted within the Dragonfly. Decision making board-to-board connector gives you access to all the and control is distributed to the edge, enabling data programmable I/O interfaces. You can also connect to to be more actionable without the heavy lift required the Dragonfly using the industry standard micro USB to implement complex M2M middleware and security port affording you the quickest time to market when protocols needed to deploy a low touch install. your application only requires basic cellular connectivity. SPECIFICATIONS Model Performance Frequency Band (MHz) MTQ-LAT3-B01 / MTQ-LAT3-B02 MTQ-LVW3-B01 / MTQ-LVW3-B02 MTQ-H5-B01 MTQ-H5-B02 MTQ-EV3-B01 MTQ-EV3-B02 MTQ-C2-B01 MTQ-C2-B02 LAT3: LTE 3GPP Release 9 (Category 1; 10 Mbps peak downlink/5 Mbps peak uplink) with HSPA fallback LVW3: LTE 3GPP Release 9 (Category 1; 10 Mbps peak downlink/5 Mbps peak uplink) (No fall back) HSPA+ EV-DO Rev. A CDMA2000 1xRTT LAT3: 4G: 700(B12/ B13)/850(B5)/ AWS1700(B4)/1900(B2) 3G: 850(B5)/1900(B2) LVW3: 700(B13)/ AWS1700(B4)/1900(B2) 3G: 850/900/AWS 1700/1900/2100 MHz 2G: 850/900/1800/1900 MHz 3G/2G: 800/1900 MHz 2G: 800/1900 MHz 2 UFL (Cellular, Rx Diversity/ MIMO) 1xMicro USB, 1x 40-Pin Board-to-Board, 1xMicro SIM 3 UFL (Cellular, Rx Diversity & GPS) 1xMicro USB, 1x 40-Pin Board-to-Board, 1xMicro SIM TCP/IP Functions Connectors FTP, HTTP, SMTP, SSL, TCP, UDP Host Processor I/O 1 UFL (Cellular) 1xMicro USB, 1x 40-Pin Board-to-Board Cortex M4 (STM32F411RET) 512 Kbytes of Flash memory and 96 Kbytes of SRAM (B01) 1 x UART, 1 x HS USB, 1 x SPI, 1 x I2C, up to 6 analog inputs and up to 16 digital input/output (B01/B03) 1 x UART, 1 x HS USB (B02) Dimensions Power Draw* 2 UFL (Cellular & GPS) 1xMicro USB, 1x 40-Pin Board-to-Board 58.4mm x 34.9mm (2.3 x 1.375 inches) 5VDC; 25mA sleep, 58mA idle, 540mA max power (MTQ-LAT3-B01) 5VDC; 25mA sleep, 38mA idle, 510mA max power (MTQ-LAT3-B02) 5VDC; 38mA sleep, 57mA idle, 462mA max power (MTQ-LVW3-B01) 5VDC; 26mA sleep, 37mA idle, 450mA max power (MTQ-LVW3-B02) 5VDC; 25mA sleep, 64mA idle, 635mA max power (B01) 5VDC; 36mA sleep, 42mA idle, 676mA max power (B02) Input Voltage 5VDC; 6mA sleep, 57mA idle, 707mA max power (B01) 5VDC; 24mA sleep, 49mA idle, 644mA max power (B02) 5VDC; 22mA sleep, 63mA idle, 690mA max power (B01) 5VDC; 24mA sleep, 53mA idle, 640mA max power (B02) 5VDC Environmental Operating Temperature -40° to +85° C Storage Temperature -40° to +85° C Relative Humidity 20% to 90% RH, non-condensing Services & Warranty MultiTech’s comprehensive Support Services programs offer a full array of options to suit your specific needs. These services are aimed at protecting your investment, extending the life of your solution or product, and reducing total cost of ownership. Our seasoned technical experts, with an average tenure of more than 10 years, can walk you through smooth installations, troubleshoot issues and help you with configurations. Installation Support MultiTech’s Installation Support Service delivers priority service with the ability to work one-onone with an experienced MultiTech technical support engineer, to guide you through the installation process for our products. Technical Support Services At MultiTech, we’re committed to providing you personalized attention and quality service while providing you a quick response to your product support needs. We have several options of support for you to choose from. For additional information on Support Services as well as other service offerings, please contact your MultiTech representative or visit www.multitech.com/support.go Certifications EMC Compliance Radio Compliance Safety Network Carrier FCC Part 15 Class B FCC Part 15 Class B, EN55022, EN55024 FCC Part 15 Class B LAT3: FCC Part 22, 24, 27 LVW3: FCC Part 27 FCC Part 22, FCC Part 24, RSS 132, RSS 133, EN 301 511, EN 301 489-1, EN 301 489-7, EN 301 489-24 FCC Part 22, FCC Part 24 UL/cUL 60950-1 2nd ED, IEC 60950-1 2nd ED +Am.2 UL 60950-1 2nd ED, cUL 60950-1 2nd ED, EN 60950-1 2nd ED, AS/NZS 60950-1 2nd ED UL/cUL 60950-1 2nd ED, IEC 60950-1 2nd ED +Am.2 LAT3: PTCRB PTCRB N/A LAT3: AT&T/T-Mobile/ Aeris (Bell, Rogers, Telus planned)
LVW3: Verizon AT&T/T-Mobile/Aeris (Bell, Rogers, Telus planned) Sprint, Aeris Warranty 2-Years *See Device Guide for More Detailed Information ORDERING INFORMATION Model MTQ-LAT3-B01 MTQ-LAT3-B02 MTQ-LVW3-B01 MTQ-LVW3-B02 MTQ-H5-B01 MTQ-H5-B02 MTQ-EV3-B01-N2 MTQ-EV3-B02-N2 MTQ-EV3-B01-N16 MTQ-EV3-B02-N16 MTQ-C2-B01-N2 MTQ-C2-B02-N2 MTQ-C2-B01-N16 MTQ-C2-B02-N16 Description Region LTE Cat 1 Embedded Cellular SoM (AT&T) US/Can Embedded LTE Ca1 Modem (AT&T) US/Can LTE Cat 1 Embedded Cellular SoM (Verizon) USA Embedded LTE Cat 1 Modem (Verizon) USA HSPA+ Embedded Cellular SoM w/GPS Global Embedded HSPA+ Modem w/GPS Global EV-DO Embedded Cellular SoM w/GNSS (Sprint) USA Embedded EV-DO Modem w/GNSS (Sprint) USA EV-DO Embedded Cellular SoM w/GNSS (Aeris) USA Embedded EV-DO Modem w/GNSS (Aeris) USA 1xRTT Embedded Cellular SoM (Sprint) USA Embedded 1xRTT Modem (Sprint) USA 1xRTT Embedded Cellular SoM (Aeris) USA Embedded 1xRTT Modem (Aeris) USA Developer Kit Model MTUDK2-ST-CELL Description Region SocketModem® & Dragonfly Developer Kit Global Go to www.multitech.com for detailed product model numbers. World Headquarters Multi-Tech Systems, Inc. 2205 Woodale Drive Mounds View, MN 55112 U.S.A. Tel: 763-785-3500 Toll-Free: 800-328-9717 Email: sales@multitech.com www.multitech.com EMEA Headquarters Multi-Tech Systems (EMEA) Strata House 264-270 Bath Road Harlington UB3 5JJ United Kingdom Tel: +(44) 118 959 7774 Email: sales@multitech.co.uk www.multitech.co.uk
MTQ-LVW3-B02.R1 价格&库存
很抱歉,暂时无法提供与“MTQ-LVW3-B02.R1”相匹配的价格&库存,您可以联系我们找货
