INK RIBBON
x-series
Durable resin thermal transfer ink ribbon selected specifically for the mydpi x-series labels. Select the width
that will cover the width of the labels you will print. Full width ribbon is compatible with mydpi x-series labels
up to 4.3” wide. Half width ribbon is compatible with mydpi x-series labels measuring up to 2.25” wide.
COMPATIBILITY
Printer mydpi x-series ℹ
Labels mydpi x-series ℹ
PHYSICAL
Length 984’ (300m)
Winding Coated Side Out
Width Full 4.3” (109mm), Half 2.3” (58.4 mm)
Core 1” (25.4 mm)
RESISTANCE
Heat 356°F
(180°C)
mydpi XTT-RR1-F
Water ✅
Mineral Spirits ✅
Motor oil ✅
Ethanol ✅
Gasoline ❌
Brake Fluid ❌
STORAGE
Shelf Life 12 months recommended
Temperature 40°F to 95°F
(5°C to 35℃)
Humidity 20-80%
OTHER
mydpi XTT-RR1-H
Country of Origin USA
Note As with all labeling materials, mydpi ink
ribbons should be tested thoroughly under
end-use conditions to ensure it meets your
speci c needs.
Copyright 2023 Semireg Industries, LLC DBA mydpi
fi
Data Sheet Rev-1
很抱歉,暂时无法提供与“XTT-RR1-H”相匹配的价格&库存,您可以联系我们找货
