SFM-5540-03A
SFM-5540-03A
    EAST
    BUZZER 3.6V 5X5MM TH
SFM-5540-03A 数据手册
Product Specification Ningbo East Electronics Limited NO. 88 East Jinhui Road,Yinzhou Ningbo 315100,P.R.China http://www.east-mingtao.com Product Name: SMD Magnetic Transducer Part Number: Version: Date: SFM SFM-- 5540 5540-- 03A 1.04 2015 2015-- 4 - 28 Note: Company passed ISO 9001 / ISO TS16949 / ISO 14001Certifications Revision History Rev. Description Author/Date Checked By Approver 1.04 Dimension update 汤礼东 2015-4-28 郭波波 王建成 1.03 Add Coil Impedance 汤礼东 2014-10-29 李建华 王建成 1.02 Add packing information 汤礼东 2013-1-9 张春雷 王建成 Ningbo East Electronics Limited 1/6 1. Part Number SFM-5540-03A 2. Dimension Drawing (Unit: mm) SFM-TERMINAL VERSION Solder paste thickness is not below 0.2mm RECOMMENDED SMD FOOT PATTERN 3.Specification No. Item Specification 3-1 Min. Sound Pressure Level 78dB/4000Hz/3.6V /10cm 3-2 Rated Voltage 3.6V 3-3 Operating Voltage 2.5~4.5V 3-4 Max. Consumption (At 3.6VDC) 100mA/4000Hz/7.2Vp-p square wave 3-5 Resonant Frequency 4000Hz 3-6 Coil Resistance 12±2Ω 3-7 Coil Impedance 30Ω 3-8 Operating Temperature -20~+85℃ 3-9 Storage Temperature -20~+85℃ 3-10 Case Material/Color LCP/Black 3-11 Weight 0.6g 3-12 Pin Strength More than 5N NOTES: 1、Value applying rated voltage(resonant frequency,1/2duty,square wave) 2、Test should be made under the conditions of room temperature (20±10℃), normal humidity (60±20%) and normal atmospheric pressure. In this case, however, that the judgment is questionable, the test conditions are to be changed to room temperature 20±2℃, relative humidity 60~70% and normal atmospheric pressure Ningbo East Electronics Limited 2/6 4.Typical Frequency Response Curve Note: Input Voltage 3.6V Distance 10 cm 5. Reliability Test No. Item 5-1 Operating Temperature -20~+85℃ 5-2 Storage in high temperature Storage in +85℃ test box 96 hours then exposed to the room temperature for 2 hours 5-3 Storage in low temperature Storage in -20℃ test box 96 hours then exposed to the room temperature for 2 hours 5-4 Life test in the room Operate the product continuously 5 seconds on 5 seconds off temperature 300 hours at rated voltage 5-5 Temperature / humidity cycle test Ningbo East Electronics Limited Method of Test Tolerance after Testing Sound pressure level initial value ±10dB Max. consumption value ±20% Storage in +40℃, 93±3%RH test box 96 hours then exposed to the room temperature for 2 hours 3/6 5-6 5-7 5-8 5-9 5-10 Temperature (high and low) cycle test Conduct the test for 5 cycles without applying power then expose to the room temperature for 2 hours.(See Figure 5-6) Vibration test Conduct the test for the directions of X Y and Z for 0.5 hour each (total 1.5 hours). To-and Fri sweep time(from 10 to 55Hz and then 55 to 10) under single amplitude of 0.75mm is 3 minute, then expose to the room temperature for 2 hours Drop test Drop a product naturally from the height of 700mm onto the surface of 100mm thick wooden board. Two directions: upper and side of the product are to be applied for this drop test once respectively Reflow soldering heat resistance a) Pre-heating conditions shall be +140℃ to 160℃ for 160 to 200 seconds. (See Figure5-9) b) Heating conditions shall be within 60 seconds at +200℃ min., but peak temperature shall be lower than +260℃. (See Figure 5-9) Test of soldering Dip the connecting pins in soldering at 230±5℃ for 3±0.5 seconds Solder shall be attached around over 95% of the dipped portion NOTE: The pins are allowed to deform after drop test. Figure 5-6 Figure 5-9 Ningbo East Electronics Limited 4/6 6. Electrical Testing Method S.P.L.M Sound Pressure Level Meter T.S Testing Sample F.C Frequency Counter T.C Test Circuit F.S.G Frequency Signal Generator A.V.M AC Voltage Meter P.S Power Supply D.V.M DC Voltage Meter D.A.M DC Ampere Meter TEST CIRCUIT: 7. Packing Information No. 7-1 Item Tape type information Ningbo East Electronics Limited Description a) The design for such tape packing was executed under standard IEC 286-3 b) The material of the tape is polystyrene in black color. Detailed dimensions are as below: (See Figure7-1) 5/6 7-2 7-3 Dimensions of the rolling plate a) The material of the rolling plate is plastic . b) The dimensions of the rolling plate are as below(See Figure7-2) Packing dimensions and quantity a) The rolling plate is put into a 345X330X40mm inner packing box and is packed with 2000pcs of transducer per plate. b) The dimension of the outer carton is 360X 340X 210mm containing 5 inner boxes with a total quantity of 10000 pcs of transducer. c) The total gross weight per carton is 9.5Kgs, while net weight is 8.0Kgs. Figure 7-1(Unit:mm) Figure 7-2(Unit:mm) Ningbo East Electronics Limited 6/6
SFM-5540-03A 价格&库存
很抱歉,暂时无法提供与“SFM-5540-03A”相匹配的价格&库存,您可以联系我们找货
