1T477M025HFCBA
1T477M025HFCBA
    NEXTGEN
    Radial, Can
    CAP ALUM 470UF 20% 25V T/H
1T477M025HFCBA 数据手册
PART CODE: 1T477M025HFCBA SPECIFICATION SHEET SPECIFICATION SHEET NO. P1125- 1T477M025HFCBA DATE Nov.25, 2022 REVISION A1 DESCRIPITION Through Hole Standard Aluminum Electrolytic Capacitors, Radial Type 1T series, 2 Pins, Capacitance: 470µF, Tolerance ±20%, Voltage 25V, Case size: Ø8.0*L12.0mm, Ripple Current 406mA Max. Load Life:2000 Hours, Sleeve: PET, Operating Temp. Range -40°C ~+105°C RoHS/RoHS III Compliant & Halogen Free Package in Bulk, 500pcs/Bag CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER Aillen CBE477M1EH1TF12RR PART CODE 1T477M025HFCBA VENDOR APPROVE Issued/Checked/Approved DATE: Nov.25, 2022 CUSTOMER APPROVE DATE: 11/25/2022 NextGen Components, Inc. 1 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: 1T477M025HFCBA DIP ALUMINUM ELECTROLYTIC CAPACITORS 1T SERIES MAIN FEATURE • Through Hole Standard Aluminum Electrolytic Capacitors, Radial Type • Long Load Life • RoHS Complaint And Halogen Free • Tape Package And Lead Cut 3.5~7.0mm Optional APPLICATION • For Standard Circuit Like Coupling Filter And Energy Storage Etc. RFQ PART CODE GUIDE Request For Quotation 1T 477 M 025 H F C B A 1 2 3 4 5 6 7 8 9 1) 1T: Through Hole Standard Aluminum Electrolytic Capacitors, Radial Type, 1T series 2) 477: Rated Capacitance Code, 105: 1.0µF; 225: 2.2µF; 335: 3.3µF; 475: 4.7µF; 685: 6.8µF; 106: 10µF; 226: 22µF; 336: 33µF; 476: 47µF; 686: 68µF; 107: 100µF; 227: 220µF; 337: 330µF; 477: 470µF 3) M: Capacitance tolerance code, M: ±20%; V: -10% ~ ±20%; R: -0~ ±20% 4) 025: Rated Voltage Code, 6V3: 6.3V; 010: 10V; 016:16V; 025: 25V; 035: 35V; 050: 50V; 063: 63V; 100: 100V; 160: 160V 200: 200V; 250: 250V; 350: 350V; 400: 400V; 450V: 450V 5) H: Environmental Requirements code, R: RoHS Complaint; H: RoHS III Complaint & Halogen Free 6) F: Aluminum Case size code, D: Ø5.0mm; E: Ø6.3mm; F: Ø8.0mm; G: Ø10.0mm; I: Ø12.5mm; J: Ø13.0mm; K: Ø16.0mm L: Ø18.0mm; N: Ø22.0mm 7) C: Aluminum case Heigh code, A: L11mm; B: L11.5mm; C: L12mm; D: L12.5mm; E: L20mm; F: L21.5mm; G: L31.5mm 8) B: Package in Bulk, 500pcs/Bag 9) A: Internal control or Special Code (A~Z or 1~9) 11/25/2022 NextGen Components, Inc. 2 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: 1T477M025HFCBA DIP ALUMINUM ELECTROLYTIC CAPACITORS 1T SERIES Image for reference 1T Series Case Ø8.0*L12mm Symbol Dimension (mm) D Ø8.0 F 2.5/3.5 d Ø0.50 L 12.0+/-α α 1.5 11/25/2022 NextGen Components, Inc. 3 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: 1T477M025HFCBA DIP ALUMINUM ELECTROLYTIC CAPACITORS 1T SERIES CONSTRUCTION Single ended type to be produced to fix the terminals to anode and cathode foil, and wind together with paper, and then wound element to be impregnated with electrolyte will be enclosed in an aluminum case. Finally sealed up tightly with end seal rubber, then finished by putting on the vinyl sleeve. No. Component Material 1 Lead Line Tinned CP Wire (Pb Free) 2 Terminal Aluminum Wire 3 Sealing Material Rubber 4 Al-Foil (+) Formed Aluminum Foil 5 Al-Foil (-) Etched aluminum foil or formed Aluminum Foil 6 Case Aluminum case 7 Sleeve PET 8 Separator Electrolyte paper 11/25/2022 NextGen Components, Inc. 4 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: 1T477M025HFCBA DIP ALUMINUM ELECTROLYTIC CAPACITORS 1T SERIES CHARACTERISTICS Standard atmospheric conditions The standard range of atmospheric conditions for making measurements/test as follows: Ambient temperature: 15°C to 35°C Relative humidity: 45% to 85% Air Pressure: 86kPa to 106kPa If there is any doubt about the results, measurement shall be made within the following conditions: Ambient temperature: 20°C ± 2°C Relative humidity: 60% to 70% Air Pressure: 86kPa to 106kPa As to the detailed information, please refer to following Table 1 and Table 2 Table 1 ITEM CHARACTERISTICS Operating Temperature Range -40~+105℃ Rated Voltage Range 25 V Capacitance Range 470 μF Capacitance Tolerance at 20℃, 120Hz ±20% 11/25/2022 NextGen Components, Inc. 5 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: 1T477M025HFCBA DIP ALUMINUM ELECTROLYTIC CAPACITORS 1T SERIES Table 2 ITEM Rated Voltage (WV)/Surge Voltage (SV) Nominal capacitance (Tolerance) CHARACTERISTICS WV 6.3 10 16 25 35 50 63 SV 8.0 13 20 32 44 63 79 WV 100 160 200 250 350 400 450 SV 125 200 250 300 400 450 500 Measuring Frequency : 120Hz±12Hz Measuring Voltage : Not more than 0.5Vrms Measuring Temperature : 20±2℃ Shall be within the specified capacitance tolerance Leakage current Connecting the capacitor with a protective resistor (1kΩ±10Ω) in series for 2 minutes, and then, measure leakage current. 6.3~100V: I (μA)≤0.01CV or 3 (μA) whichever is greater. 60~450V: I (μA)≤0.03CV + 40 (μA) I: Leakage current (μA) C: Capacitance (μF) V: Rated DC working voltage (V) tanδ See Nominal capacitance, for measuring frequency, voltage and temperature. W.V(V) 6.3 10 16 25 35 50 63 Tan δ Max. 0.26 0.22 0.18 0.16 0.14 0.12 0.10 W.V(V) 100 160 200 250 350 400 450 Tan δ Max. 0.08 0.15 0.20 0.20 0.24 0.24 0.24 For capacitance value >1000uF, add 0.02per another 1000uF 11/25/2022 NextGen Components, Inc. 6 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: 1T477M025HFCBA DIP ALUMINUM ELECTROLYTIC CAPACITORS 1T SERIES Item Terminal strength Characteristics Tensile strength of terminals Fixed the capacitor, applied force to the terminal in lead out direction for 10± 1 seconds. Bending strength of terminals. Fixed the capacitor, applied force to bent the terminal (1~4 mm from the rubber) for 90o within 2~3 seconds, and then bent it for 90o to its original position within 2~3 seconds. Diameter of lead wire Tensile force N (kgf) Bending force N (kgf 0.5mm and less 5 (0.51) 2.5 (0.25) Over 0.5mm to 0.8mm 10 (1.0) 5 (0.51) No noticeable changes shall be found, no breakage or looseness at the terminal Temperature characteristics Step Testing temperature(℃) Time 1 20±2 Time to reach thermal equilibrium 2 (-40) -25±3 Time to reach thermal equilibrium 3 20±2 Time to reach thermal equilibrium 4 105±2 Time to reach thermal equilibrium 5 20±2 Time to reach thermal equilibrium a. At +105℃: capacitance measured shall be within ±20% of its original value at +20℃: tan δ shall be within the limit of tanδ, The leakage current measured shall not more than 8 times of its specified value. b. In step 5, tan δ shall be within the limit of tanδ, The leakage current shall not more than the specified value. c. At-25 ℃ : Impedance (Z) ratio shall not exceed the value of the following table. Rated Voltage (V) 6.3 10 16 25~ 100 160~ 350 400~ 420 450 Z-25℃/ Z +20℃ 5 4 3 2 4 6 15 Z-40℃/ Z +20℃ 10 8 6 4 / / / Capacitance, tan δ, and impedance shall be measured at 120Hz. 11/25/2022 NextGen Components, Inc. 7 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: 1T477M025HFCBA DIP ALUMINUM ELECTROLYTIC CAPACITORS 1T SERIES Item Load life test Characteristics According to IEC60384-4 No.4.13 methods, The capacitor is stored at a temperature of 105±2°C with DC bias voltage plus the rated ripple current for 2000+48/0 hours. (The sum of DC and ripple peak voltage shall not exceed the rated working voltage) Then the product should be tested after 16 hours recovering time at atmospheric conditions. The result should meet the following table: The characteristic shall meet the following requirements. Shelf life test Leakage current Value in 4.3 shall be satisfied Capacitance Change Within ±20% of initial value tanδ Not more than 200% of the specified value. Appearance There shall be no leakage of electrolyte. The capacitors are then stored with no voltage applied at a temperature of 105±2℃ for 1000+48/0 hours. Following this period the capacitors shall be removed from the test chamber and be allowed to stabilized at room temperature for 4~8 hours. Next they shall be connected to a series limiting resistor(1k±100Ω) with D.C. rated voltage applied for 30min. After which the capacitors shall be discharged, and then, tested the characteristics. The characteristic shall meet the following requirements. Leakage current Value in 4.3 shall be satisfied Capacitance Change Within ±20% of initial value tanδ Not more than 200%of the specified value. Appearance There shall be no leakage of electrolyte. Remark: If the capacitors are stored more than 1 year, the leakage current may increase. Please apply voltage through about 1 K Ω resistor, if necessary. 11/25/2022 NextGen Components, Inc. 8 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: 1T477M025HFCBA DIP ALUMINUM ELECTROLYTIC CAPACITORS 1T SERIES Item Surge test Characteristics Applied a surge voltage to the capacitor connected with a (100 ±50)/CR (KΩ) resistor. The capacitor shall be submitted to 1000 cycles, each consisting of charge of 30 ±5s, followed discharge of 5 min 30s. The test temperature shall be 15~35℃. CR :Nominal Capacitance (μF) Leakage current Not more than the specified value Capacitance Change Within ±15% of initial value tanδ Not more than the specified value Appearance There shall be no leakage of electrolyte. Attention: This test simulates over voltage at abnormal situation only. It is not applicable to such over voltage as often applied. Solderability test The capacitor shall be tested under the following conditions: Soldering temperature : 245±3°C Dipping depth : 2mm Dipping speed : 25±2.5mm/s Dipping time : 3±0.5s Coating quality : A minimum of 95% of the surface being immersed 11/25/2022 NextGen Components, Inc. 9 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: 1T477M025HFCBA DIP ALUMINUM ELECTROLYTIC CAPACITORS 1T SERIES Item Vibration test Characteristics The following conditions shall be applied for 2 hours in each 3 mutually perpendicular directions. Vibration frequency range : 10Hz ~ 55Hz Peak to peak amplitude : 1.5mm Sweep rate : 10Hz ~ 55Hz ~ 10Hz in about 1 minute Mounting method: The capacitor with diameter greater than 12.5mm or longer than 25mm must be fixed in place with a bracket. After the test, the following items shall be tested: Resistance to solder heat test Inner construction No intermittent contacts, open or short circuiting. No damage of tab terminals or electrodes Appearance No mechanical damage in terminal. No leakage of electrolyte or swelling of the case. The markings shall be legible Terminals of the capacitor shall be immersed into solder bath at 260±5℃for10±1seconds or 400±10℃fo for3 01 seconds to 1.5~2.0mm from the body of capacitor. Then the capacitor shall be left under the normal temperature and normal humidity for 1~2 hours before measurement. Leakage current Not more than the specified value Capacitance Change Within ±10% of initial value tanδ Not more than the specified value Appearance There shall be no leakage of electrolyte. 11/25/2022 NextGen Components, Inc. 10 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: 1T477M025HFCBA DIP ALUMINUM ELECTROLYTIC CAPACITORS 1T SERIES Item Change of temperature test Characteristics Temperature cycle: According to IEC60384-4 No.4.7 methods, capacitor shall be placed in an oven, the condition according as below: Temperature Time (1)+20℃ ≤ 3 Minutes (2)-40℃ 30±2 Minutes (3)+105℃ 30±2 Minutes (1) To (3) = 1 cycle, Total 5 Cycles The characteristic shall meet the following requirement. Damp heat test Leakage current Not more than the specified value. Tan δ Not more than the specified value. Appearance There shall be no leakage of electrolyte. Humidity test: According to IEC60384-4 No.4.12 methods, capacitor shall be exposed for 500±8 hours in an atmosphere of 90~95%R H .at 40±2℃, the characteristic change shall meet the following requirement. Vent test Leakage current Not more than the specified value. Capacitance Change Within ±20% of initial value.. Tan δ Not more than 120% of the specified value. Appearance There shall be no leakage of electrolyte. The following test only apply to those products with vent products at diameter ≥Ø 6.3 with vent. D.C. test The capacitor is connected with its polarity reversed to a DC power source. Then a current selected from Table 2 is applied. Diameter (mm) DC Current (A) 22.4 or less 1 The vent shall operate with no dangerous conditions such as flames or dispersion of pieces of the capacitor and/or case. 11/25/2022 NextGen Components, Inc. 11 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: 1T477M025HFCBA DIP ALUMINUM ELECTROLYTIC CAPACITORS 1T SERIES CASE SIZE & MAX RIPPLE CURRENT Rated Voltage (V) Capacitance (Tol.+/-20%) (µF) Case Size Ø*L (mm) Surge Volt (V) Tanδ @+105°C, 120Hz Load Life (Hrs) Ripple Current @+105°C, 120Hz (mA r.m.s .) 25 470 8.0*12.0 32 0.16 2000 406 FREQUENCY COEFFICIENT OF ALLOWABLE RIPPLE CURRENT Cap. 470µF Frequency 50Hz(60Hz) 120Hz 500Hz 1KHz ≥10kHz Coefficient 0.80 1.0 1.1 1.15 1.20 Remark: 1) Specification are subject to change without notice should a safety or technical concern arise regarding the product ,please be sure to contact our sales offices 2) The sizes in the above table are all general specifications. If you need other specifications, please contact us. 11/25/2022 NextGen Components, Inc. 12 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: 1T477M025HFCBA DIP ALUMINUM ELECTROLYTIC CAPACITORS 1T SERIES ATTENTION When using Aluminum Electrolytic Capacitor, please pay attention to the points listed below. If the following types of electrical loads are applied to Aluminum Electrolytic Capacitor, rapid deterioration of electrical property occurs: • Reverse voltage • Overvoltage exceeding rated working voltage • Current exceeding rated ripple current • Severe charging/discharging At such time, severe heat is generated, gas electrolyte leaks from the sealed area, and pressure relief vent operates due to increase of internal pressure. In the worst case, explosion or ignition may occur, and along with destruction of the capacitor combustibles may burst out. 1.CAUTION DURING CIRCUIT DESIGN 1) OPERATIONAL ENCIRONMENT,MOUNTING ENVIRONMENT ANDCONDITIONS Ensure that operational and mounting conditions follow the specified conditions detailed in the catalog and specification sheets 2) OPERATING TEMPERARURE,RIPPLE CURRENT AND LOAD LIFE. Operating temperature and applied ripple current should be within the specified value in the catalog or specification sheets. Do not use Aluminum Electrolytic Capacitors at temperature which exceeds the specified category temperatures range. Do not apply excessive current to the capacitors, which exceeds the specified rated ripple current. During circuit design ,please ensure that capacitors are selected to match with the lifetime requirements of the application 3) APPLICATION Aluminum Electrolytic Capacitors are normally polarized .Reverse voltage or AC Voltage should not be applied. When polarity may flip over, non-polar type should be used, but the non-polar type cannot be used for AC. Standard Aluminum Electrolytic Capacitors are not suitable for rapid charge and discharge applications. Group in your area about specialty signed capacitors for rapid charge and discharge. 4) APPLIED COLTAGE Do not exceed the rated voltage of capacitors 5) INSULATION Aluminum Electrolytic Capacitors should be electrically isolated from the following. Aluminum case, cathode lead wire, anode lead wire and circuit pattern; Auxiliary terminals of snap-in type, anode terminal, outward terminals and circuit pattern. The PVC sleeve of Aluminum Electrolytic Capacitors is not recognized as an insulator, and therefore ,the standard capacitor should not be used in a place where insulation function is needed. Please consult with Shanghai Suzuki Electronics or sales office of Suzuki Techno Group in your area, if you require a higher grade of insulating sleeve. 11/25/2022 NextGen Components, Inc. 13 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: 1T477M025HFCBA DIP ALUMINUM ELECTROLYTIC CAPACITORS 1T SERIES 6) CONDITIONS OF USE The following environments should be avoided when suing Aluminum Electrolytic Capacitors. Damp conditions such as water ,salt water or oil spray or fumes, high humidity or humidity condensation situations. Hazardous gas/fumes such as hydrogen sulfide, sulfurous acid gas, nitrous acid, chlorine gas, ammonia or bromine gas; Exposure of ozone ,ultraviolet rays or radiation; Severe vibration or shock which exceeds the condition specified in the catalog or specification sheet. 7) CONSIDERATION TO ASSEMBLY CONDITION In designing a circuit ,the following matters should be ensured in advance to the capacitor’s assembly on the printed circuit board (PC board) Design the appropriate hole spacing to match the lead pitch of capacitors; Do not locate any wiring and circuit patterns directly above the capacitor’s vent; Ensure enough free space above the capacitor’s vent. The recommended space is specified in the catalog or specification sheets; In case the capacitor’s vent is facing the PC board, make a gas release hole on PC board. The sealing side of the screw terminal type should not face down in the application. When the capacitors are mounted horizontally, the anode screw terminals must be positioned at upper side.. 8) CONSIDERATION TO CIRCUIT DESIGN Any copper lines or circuit patterns should not be laid under the capacitor; Parts which radiate heat should not be placed close to the reverse side of the Aluminum Electrolytic Capacitors on the PC board. 9) OTHERS Performance of electrical characteristics of Aluminum Electrolytic Capacitors is affected by variation of operating temperature and frequency. Consider this variation when designing the circuit. Excessive holes and connection hole between both sides on the PC board should be avoided around or under the mounting area of the Aluminum Electrolytic Capacitors on double sided or multilayer PC board. Torque of tightening screw terminals should not exceed the specified maximum value which is described in the catalog and specification sheets . Consider current balance when 2 or more Aluminum Electrolytic Capacitors are connected in parallel. Use bleeding resistors when 2 or more Aluminum Electrolytic Capacitors are connected in series .In this case, the resistors should be connected parallel to the capacitors. 2. CAUTION FOR ASSEMBLING CAPACITORS 1) CAUTION BEFORE ASSEMBLY Aluminum Electrolytic Capacitors cannot be recycled after mounting and applying electricity in unit. The capacitors, which are removed from PC board for the purpose of measuring electrical characteristics at the periodical inspection, should only be recycled for the same position.; Aluminum Electrolytic Capacitors may accumulate charge naturally during storage. In this case, discharge through a 1KOHM resistor before use; Leakage current of Aluminum Electrolytic Capacitors may be increased during long storage time. In this case, the capacitors should be subject to voltage treatment through a 1KOHM resistor before use. 11/25/2022 NextGen Components, Inc. 14 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: 1T477M025HFCBA DIP ALUMINUM ELECTROLYTIC CAPACITORS 1T SERIES 2) IN THE ASSEMBLY PROCESS-1 Ensure rated voltage and capacitance of the capacitors before mounting; Ensure capacitors polarity before mounting; Do not use a capacitor which has been dropped onto a hard surface; Do not use a capacitor with damaged or dented cased or seals. 3) IN THE ASSEMBLY PROCESS-2 Capacitors should be mounted after confirmation that hole spacing on PC board matches the lead pitch of the capacitors; The snap-in type of capacitors should be mounted firmly on the PC board without a gap between the capacitor body and the surface of PC board;. Avoid excessive force when clinching lead wire during auto-insertion process; Avoid excessive shock to capacitors by automatic inserting machine, during mounting, parts inspection or centering operations; Please utilize supporting material such as strap of adhesive to mount capacitors to PC board when it is anticipated that vibration or shock is applied. 4) SOLDERING Soldering conditions (temperature and time)should be within the specified conditions which are described in the catalog or specification sheets; In case lead wire reforming is needed due to inappropriate pitch between capacitor and holes on PC board, stress to the capacitor should be avoided; In case of maintenance by soldering iron, if it is required to detach the capacitor, it should be removed from PC board after solder has melted sufficiently in order to reduce stress on the lead wires/terminals of the capacitor; Soldering iron should never touch the capacitor’s body. 5 ) FLOW SOLDERING Do not dip capacitor’s body into melted solder. It should only be soldered on the reverse side of the PC board on which the capacitors are mounted; Soldering condition (preheat, soldering temperature, dipping time)should be within the specified standard which is described in the catalog or specification sheets; Flux should not be adhered to capacitor’s body but only to its terminals; Other devices which are mounted close to capacitors should not touch the capacitors. 6) REFLOW SOLDERING Reflow soldering conditions(preheat, soldering, temperature, reflow time )should follow the specified standard which is described in the catalog or specification sheets; Heating standard should depend on surface of the capacitor color or materials when infrared rays are used because the capacitor’s heat absorption depends on the surface color or materials. Check heat condition; Standard Aluminum Electrolytic Capacitors cannot withstand two or more reflow processes. 7) HANDLING AFTER SOLDERING Do not bend or twist the capacitor’s body after soldering on PC board; Do not pick-up or move PC board by holding the soldered capacitors; Do not hit the capacitors and isolate capacitors from the PC board or other device when stacking PC boards in store. 11/25/2022 NextGen Components, Inc. 15 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: 1T477M025HFCBA DIP ALUMINUM ELECTROLYTIC CAPACITORS 1T SERIES 8) PC BOARD CLEANING Standard Aluminum Electrolytic Capacitors should be free from halogenated solvents during PC board cleaning after soldering 9 ) ADHESIVES AND COATNG MATERIALS Do not use halogenated adhesives and coating materials to fix Aluminum Electrolytic Capacitors; Flux between the surface of the PC board and sealing of capacitors should be cleaned before using adhesives or coating materials; Solvents should be dried up before using adhesives or coating materials; Do not cover up all the sealing area of capacitors with adhesives or coating materials, make coverage only partial. 3. CAUTION DURING USE OF CAPACITORS IN SETS 1) Do not touch the terminals of capacitors; 2) Do not connect electrical terminals of the capacitors. Keep the capacitors free from conductive solution, such as acid, alkali and so on; 3) Ensure the operational environment of the equipment in which the capacitor has been built is within the specified condition mentioned in the catalog or specification sheets. 4. MAINTENANCE 1) Periodical inspection should be carried out for the capacitors, which are used with industrial equipment;.Check the following points at the inspection. 2) Visual inspection to check pressure relief vent open or leakage of electrolyte. 3) Electrical characteristics: leakage current, capacitance, dissipation factor and the other points which are mentioned in the catalog or specification sheets. 5. EMERGENCY ACTION 1) If the pressure relief vent is open and some gas blows out from the capacitor, turn the main switch of the equipment off or pull out the plug from the power outlet immediately. 2) During pressure relief vent operation, extremely hot gas (over 100℃)may blow out from the vent area of the capacitors. So keep your face and skin away from capacitors during its operation. In case of eye contact, flush the open eye(s)with large amount of clean water immediately. In case of ingestion, gargle with water immediately, and do not swallow .Also do not touch electrolyte but wash skin with soap and water in case of skin contact. 6. STORAGE CONDITIO 1) Aluminum Electrolytic Capacitors should not be stored in high temperature or in high humidity. The suitable storage condition is 5℃-35℃,and less than 75% in relative humidity; 2) Aluminum Electrolytic Capacitors should not be stored in damp conditions such as water, salt water spray or oil spray; 3) Do not store Aluminum Electrolytic Capacitors in an environment full of hazardous gas (hydrogen sulfide gas, sulfurous acid gas, nitrous acid, chlorine gas, ammonia or bromine gas. 11/25/2022 NextGen Components, Inc. 16 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: 1T477M025HFCBA DIP ALUMINUM ELECTROLYTIC CAPACITORS 1T SERIES 4) Aluminum Electrolytic Capacitors should not be stored under exposure to ozone ,ultraviolet rays or radiation. 5) After one year, a capacitor should be reconditioned by applying rated voltage in series with a 1000Ω current limiting resistor for a time period of 30 minutes . 7. DISPOSAL 1) Please take either of the following actions in case of disposal. Incineration (high temperature of more than 800℃) after crushing the capacitor’s body; Consignment to specialists of industrial waste. DISCLAIMER NextGen Component, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information 11/25/2022 NextGen Components, Inc. 17 sales@NextGenComponent.com www.NextGenComponent.com
1T477M025HFCBA 价格&库存
很抱歉,暂时无法提供与“1T477M025HFCBA”相匹配的价格&库存,您可以联系我们找货
