PART CODE:
CA45D010K337TA
SPECIFICATION SHEET
SPECIFICATION SHEET NO.
N0710- CA45D010K337TA
DATE
July 10, 2021
REVISION
A1
DESCRIPITION
SMD Standard Tantalum Capacitors Industrial Grade MnO₂
EIA code 7343-31
CA45 Series, Case D, L7.40*W4.40*H3.00mm
Rated Voltage 10 Vdc, Capacitance 330μF, Tolerance ±10%, ESR 0.4Ω Max.
Operating Temp. Range -55°C ~+125°C,
Package in Tape/Reel, 500pcs/Reel
RoHS/RoHS III compliant
CUSTOMER
CUSTOMER PART NUMBER
CROSS REF. PART NUMBER
ORIGINAL PART NUMBER
CA45-D010K3327T
PART CODE
CA45D010K337TA
VENDOR APPROVE
Issued/Checked/Approved
DATE: July 10, 2021
CUSTOMER APPROVE
DATE:
1
NextGen Components, Inc.
sales@NextGenComponent.com
www.NextGenComponent.com
PART CODE:
CA45D010K337TA
SMD TANTALUM CAPACITORS CA45 SERIES CASE D
MAIN FEATURE
• RoHS III Compliant
• Wide Operating Temperature Range -55~+125℃
• Small volume, High Stability
• Good Frequency Characteristic
APPLICATION
• For Surface Mount Consumer Electronic Equipment
• Color TV sets, PC, Mobile Telephone sets Pickup camera Radar etc.
RFQ
PART CODE GUIDE
Request For Quotation
CA45
D
010
K
337
T
A
1
2
3
4
5
6
7
1) CA45: Series code for SMD Standard Tantalum Capacitors Industrial Grade MnO₂
2) D: Case size code for Dimension L7.40*W4.40*H3.00mm, EIA code 7343-31
3) 010: Rated voltage Code, 010: 10 Vdc
4) K: Capacitance Tolerance code, K: +/-10%; M: +/-20%
5) 337: Capacitance Code: 1st two digits represent Significant figures, 3rd Digit specifies number of Zeros, 337: 330μF
6) T: Package in Tape/Reel, 500pcs/Reel
7) A: Internal control or Customer’s Special Code (A~Z or 1~9)
2
CA45D010K337TA
PART CODE:
DIMENSION (Unit: mm)
Image for reference
CA45 Case D
Item
Dimension
L
7.40±0.20
W1
4.40±0.20
W2
2.40±0.20
H
3.00±0.20
S
1.30±0.20
Capacitance code: 330µF
Marking: A337
A337
Polarity: Anode (+)
Rate Voltage Code: A=10V
Code
F
G
J
A
C
D
E
V
T
Rate Voltage (V)
2.5
4
6.3
10
16
35
50
3
PART CODE:
CA45D010K337TA
PRODUCT STRUCTURE
Image for reference
LAND DIMENSIONS/COURTYARD
Case
Code
Item
Code
Dimension
(mm)
D
Density
Level A
Max. (Most)
Land
Protrusion
W
2.55
L
2.77
S
3.67
V1
10.22
V2
5.60
W
2.43
L
2.37
S
3.87
V1
9.12
V2
5.10
W
2.33
L
1.99
S
4.03
V1
8.26
V2
4.84
(EIA
7343-31)
Density Level A: For low-density product applications.
Recommended for wave solder applications and provides
a wider process window for reflow solder processes.
Density Level B: For products with a moderate level of
component density. Provides Recommended Profile
Density
Level B
Max.
(Nominal)
Land
Protrusion
Conditions for reflow solder processes.
Density Level C: For high component density product
applications. Before adapting the Min. land pattern
variations, the user should perform qualification testing
based on the conditions outlined in IPC - 7351).
Note:
Density
Level C
Max. (Least)
Land
Protrusion
1. Height of these chips may create problems in wave soldering.
2. Land pattern geometry is too small for silkscreen outline.
4
PART CODE:
CA45D010K337TA
ELECTRONICAL CHARACTERISTICS
Item
Unit
Operating
Temperature Range
Symbol
Characteristic
Condition
°C
-55~+125
@>85℃
Applying Voltage
Derating: 10V
Rated Voltage
Range
V DC
10
Capacitance
Tolerance
±10
@25℃, 100Hz
Leakage Current
μA
I0
Measured after 5 Minutes Application
of rated voltage reading,
I 0≤ 0.01 CRUR or 33.0μA Max.
whichever is greater @25 ℃
CR: (μF) Nominal
Capacitance
UR: (V) Rated voltage
Capacitance
μF
CR
330
@25℃, 100Hz
Dissipation Factor
tgδ
14.0 Max.
ESR
Ω
0.4 Max.
@25℃, 100KHz
TEMPERATURE CHARACTERISTICS
Item
Unit
Dissipation Factor
(tgδ Max)
Temperature
Characteristics
Capacitance change
Leakage Current
(I Max.)
@Nominal Capacitance 330μF
-55
+85
+125
9
9
12
-55
+85
+125
±10
±10
±12
μA
Load Life
Failure Rate Level
≤150%
of the specified value
Within ± 10%
of the initial value
+85
+125
8*I 0
10* I 0
≤ 8 * of the
specified value
Under the normal load of 1000 hours, the failure rate of the product is less than
100 ppm
5
PART CODE:
CA45D010K337TA
APPLICATION NTOE
Storage Condition
1) Environmental temperature:10°C~ +30°C
2) Relative humidity no more than 60%
3) Storing period: No more than one and half year since the date of stocking.
Application Guide
1) Ripple Current and Voltage
If the ripple current is applied to the capacitor, the Joule heat (power dissipated) will be generated in the capacitor,
so it will affect the reliability of the capacitor.
(1) Power Dissipated
The actual power dissipated can be calculated using the following formula: P=I² × ESR………Formula 1
P: Power dissipated (W); I: Ripple current (A); ESR: Equivalent series resistance (Ω)
Power Dissipation for Case D ( EIA Code 7343-31): 105mW Max. @+25°C
(2) Ripple Current
Using the maximum power dissipation 105mW Max., the ripple current can be calculated using the following
formula: I=
×K×F…………Formula 2
K: Temperature derating factor...... Table 1; F: Frequency derating factor........ Table 2
ESR: Refer to the ratings of each specific product
Table 1: Temperature Drop Factor K
Temperature
Temperature
Derating Factor K
25 °C
1
85 °C
0.9
125 °C
0.4
Table 2: Frequency Derating Factor F
Frequency
(KHz)
10
100
500
1000
MnO2
0.80
1.0
1.15
1.20
Polymer
0.75
1.0
1.10
1.30
Using formula 3 to calculate corrugated voltage E: E=Z×I………. Formula 3
E: Ripple voltage; Z: Specific frequency impedance
6
PART CODE:
CA45D010K337TA
(3) Ripple Voltage
The ripple voltage applied to the capacitor is limited by three criteria.
(a) The power dissipation in the ESR of capacitor must not exceed 105mW Max. @+25°C
(b) The positive peak AC voltage plus the DC bias voltage must not exceed the DC voltage rating of the capacitor.
(c) The negative peak AC voltage, in combination with the bias voltage, if any , must not exceed the permissible
reverse voltage ratings presented .
2) Reverse Voltage
Solid tantalum capacitors are polarized devices , and applied reverse voltage can not be allowed . If the reverse
voltage is unavoidable, a small degree of transient reverse voltage is permissible for short periods as follow.
25°C……. 10% of Max. rated voltage or 1V whichever is smaller
85°C……. 5% of Max. rated voltage or 0.5V whichever is smaller
125°C……1% of Max. rated voltage or 0.1V whichever is smaller
Even under these restrictions, capacitors can not be used continuously in reverse voltage mode.
3) Working Voltage
(1) For general applications, using 50% of rated voltage of capacitors or less.
(2) When used at the power circuit, low impedance circuit , coupling circuit or witching circuit which has leakage
current problems, please design the circuit with voltage under 30% of the working voltage ( max 50%) to avoid
the adverse effect of the surge current.
(3) Derating voltage when temperature above 85°C.
When the chip tantalum capacitor is used at 85℃ or more temperatures, the reduced voltage (UT) is calculated
from the following expression, however, note that the ambient temperature is not more than 125℃.
U T=V 0 (U R-U C)(T-85)/40
UR: Rated voltage (V); UC: Derating voltage at 125°C; T: Ambient temperature (°C )
7
PART CODE:
CA45D010K337TA
4) Protective Resistance
In a circuit(switching circuit, charge / discharge circuit, etc.) that has an instantaneous current, series resistance is
at least 3Ω/V, this can improve the reliability of tantalum capacitors. If the capacitor is in a low impedance circuit,
the voltage applied to the capacitor should be half or one third of the rated voltage.
5) Redundancy
MnO2 tantalum capacitors will heat, and may cause fire and burn in the short circuit . This is determined by the
situation, time and other factors. When the circuit is designed, it is possible to provide the best possible space to
keep the tantalum capacitor reliability.
6) Test Condition
Ambient Temperature 25°C; Relative Humidity 60 to 70%; Air Pressure 800 to 1060mbar. Test and experiment, in
order to make the test results not problems, it is necessary to will test the product after fully discharge.
This product is a polar components, testing or when using it is strictly prohibited to will is negative pick back, in
order to avoid performance failure
7) Soldering
The SMD tantalum capacitor can be used for reflow soldering, which is not suitable for wave soldering and manual
welding. The reflow temperature are ≤250°C, ≤ 5 seconds. If you must use manual welding, should use the melted
solder to contact lead, and the electric soldering iron power should be less than or equal to 25W, temperature
should be less than 300℃, welding time should be less than 3 seconds, can not use electric iron contact the
product lead directly, and in particular, can not contact the product ontology directly. Recommended profile
conditions for convection and IR reflow reflect the profile conditions of the IPC/J-STD-020D standard for moisture
sensitivity testing
8
PART CODE:
CA45D010K337TA
Temperature
8)
. Recommended Profile Conditions
Time
Characteristics
Unit
Symbol
SnPb Assembly
Pb-Free Assemble
Preheat Temperature Min.
°C
T smin
100
150
Preheat Temperature Max.
°C
T smax
150
200
Preheat time
Second
Ts
60~120
60~120
Ramp-up Rate
°C/Second
T L to T p
≤3
≤3
Liquidous Temperature
°C
TL
183
217
Time Above Liquidous
Second
tL
30~150
60~150
Peak Temperature
°C
Tp
220 or 235
245 or 250
Time within 5°C Max. Peak
Temperature
Second
tp
≤ 10
≤3
Ramp-down Rate
°C/Second
T p to T L
≤6
≤6
Time 25°C to Peak
Temperature
minute
≤6
≤6
9
PART CODE:
CA45D010K337TA
% Working Voltage
9) Recommended Voltage Derating Guidelines
Recommended Max
Application Voltage
(As % of Rated Voltage)
+85
-55
Temperature
Condition
-55 °C ~ 85 °C
% Change in Working DC Voltage with Temperature
VR
Recommended Max. Application @VR ≤10V
50 of VR
Recommended Max. Application @VR ≥16V
30% of VR
10
PART CODE:
CA45D010K337TA
REEL 7”/180MM DIMENSION (Unit: mm, 500pcs/Reel)
Code
Dimension
A
178.0+/-2.0
B
50.0 Min.
C
13.0+/-0.50
G
12.4+/-1.5
T
1.50+/-1.0
Code
Dimension
A0
4.48+/-0.10
B0
7.62+/-0.10
K
3.22+/-0.10
W
12.0+/-0.30
E
1.75+/-0.10
F
5.50+/-0.05
P
8.00+/-0.10
P1
2.00+/-0.05
P2
4.00+/-0.10
D
1.50+/-0.20
D1
1.50+/-0.25
TAPE WIDE 12MM DIMENSION (Unit: mm)
Note: Tolerance ±0.2mm over 10 sprocket hole spaces
DISCLAIMER
NextGen Component, Inc. reserves the right to make changes to the product(s) and or information contained herein
without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany
the sale of any such product(s) or information
11
