PART CODE:
CR0201FM240RS1
SPECIFICATION SHEET
SPECIFICATION SHEET NO.
Q0211- CR0201FM240RS1
DATE
Feb. 11, 2023
REVISION
A1
DESCRIPITION
Thick Film Chip Resistors, 0201 (0603 Metric), CR01 Series,
Dimension L0.60*W0.30*H0.23mm, 2 Terminations
Tolerance: ±1%, Resistance 240 ohm, Dissipation Max. 1/20W @ 70℃
Temperature Coefficient Rate (TCR) Max. ±200ppm/°C
Operating Temp. Range -55°C ~+125°C
Package in Tape/Reel, 15,000pcs/Reel
RoHS/RoHS III compliant and HF
CUSTOMER
CUSTOMER PART NUMBER
CROSS REF. PART NUMBER
ORIGINAL PART NUMBER
Aillen CR01FM240R
PART CODE
CR0201FM240RS1
VENDOR APPROVE
Issued/Checked/Approved
DATE: Feb. 11, 2023
CUSTOMER APPROVE
DATE:
1
2/11/2023
NextGen Components, Inc.
sales@NextGenComponent.com
www.NextGenComponent.com
PART CODE:
CR0201FM240RS1
THICK FILM CHIP RESISTORS CR01 SERIES
DESCRIPTION
The resistors are constructed in a high grade ceramic body (aluminum oxide). Internal
metal electrodes are added at each end and connected by a resistive paste that is
applied to the top surface of the substrate. The composition of the paste is adjusted to
give the approximate resistance required and the value is trimmed to within tolerance
by laser cutting of this resistive layer. The resistive layer is covered with a protective
coat. Finally, the two external end terminations are added. For ease of soldering the
outer layer of these end terminations is a Tin (lead free) alloy.
MAIN FEATURE
• High Reliability And Stability
• Reduced Size Of Final Equipment
• Lower Assembly Costs
• Higher Component And Equipment Reliability
• RoHS III Compliant And Halogen Free Products
APPLICATION
• Consumer Electrical Equipment
• EDP, Computer Application
• Telecom Application
RFQ
PART CODE GUIDE
Request For Quotation
CR
0201
F
M
240R
S1
1
2
3
4
5
6
1) CR: Product code for Thick Film Chip Resistors
2) 0201: Size Code, 0201 (0603 Metric), CR01 Series, Dimensions L0.60*W0.30*H0.23mm,
3) J: Resistance Range Tolerance Code, P: Jumper; B: +/-0.1%; D: +/-0.5%; F: +/-1%; J: +/-5%
4) M: Package Code, A: 4Kpcs/7”Reel; B:5kpcs/7”Reel; C:10kpcs/7”Reel; M:15kpcs/7”Reel; D:10kpcs/10”Reel; E:20kpcs/10”Reel
5) 240R: Resistance value code. 0R: 0ohm; 1R2: 1.2ohm; 15R: 15ohm; 20R: 20ohm; 51R: 51ohm; 240R: 240ohm; 390R: 390ohm
1K: 1Kohm; 10K: 10Kohm; 15K: 15 Kohm;10K5: 10.5Kohm; 1K21: 1.21Kohm; 100K: 100Kohm; 226K: 226Kohm; 1M: 1.0Mohm;
1M2: 1.2Mohm
6) S1: Internal control code, digits and letter; Blank: N/A
2
2/11/2023
PART CODE:
CR0201FM240RS1
DIMENSION (Unit: mm)
General Marking:
Blank
Image for reference
CR01 series
Item
Dimension
L
0.60±0.03
W
0.30±0.03
T
0.23±0.03
Tb
0.15±0.05
Tt
0.10±0.05
Item
Dimension
Resistors Construction
For Reference
Recommended
Solder Pad
(mm)
2/11/2023
W
0.25~0.30
L
0.70~0.90
D
0.30~0.40
3
PART CODE:
CR0201FM240RS1
GENERAL ELECTRONICAL CHARACTERISTICS
Item
Unit
Symbol
Characteristic
Product Name
CR
Size
0201
CR01 Series,
L0.60*W0.30*H0.23mm
Resistance Range
Ω
Resistance Tolerance
TCR
10Ω~100MΩ
Condition
240
F
+/-1.0
ppm/°C
≤±200
1Ω~9.76Ω
-200~+600
Max. Dissipation
W
1/20
@ Tamb=70°C
Operating Temperature
-55 ~+125
Max. Operation Voltage
V
25
@DC or RMS
Max. Overload Voltage
V
50
@DC or RMS
Note
1) This is the maximum voltage that may be continuously supplied to the resistor element, see “IEC publication 60115-8”
2) Max. Operation Voltage : So called RCWV (Rated Continuous Working Voltage) is determined by
RCWV = 𝑅𝑎𝑡𝑒𝑑 𝑃𝑜𝑤𝑒𝑟 × 𝑅𝑒𝑠𝑖𝑠𝑡𝑎𝑛𝑐𝑒 𝑉𝑎𝑙𝑢𝑒 or Max. RCWV listed above, whichever is lower.
3) Test condition for jumper (0 Ω)
Item
Unit
Symbol
Characteristic
Power Rating At 70℃
W
1/20
Max. Resistance
mΩ
50
Rated Current
A
1.0
Peak Current
A
2.5
-55 ~+125
4
2/11/2023
Condition
PART CODE:
CR0201FM240RS1
PRODUCT CHARACTERIZATION
Standard values of nominal resistance are taken from the E24 & E96 series for resistors with a tolerance Of +/-1% &
+/-5%, The values of the E24/E96 series are in accordance with “IEC publication 60063”
DERATING
The power that the resistor can dissipate depends on the operating temperature; see Fig.1
Fig 1 Maximum dissipation in percentage of rated power as a function of the ambient temperature for CR0402
MOUNTING
Due to their rectangular shapes and small tolerances, Surface Mountable Resistors are suitable for handling by
automatic placement systems. Chip placement can be on ceramic substrates and printed-circuit boards (PCBs).
Electrical connection to the circuit is by individual soldering condition. The end terminations guarantee a reliable
contact.
5
2/11/2023
PART CODE:
CR0201FM240RS1
REFLOW SOLDERING CONDITION
The robust construction of chip resistors allows them to be completely immersed in a solder bath of 260 ℃ for 10
seconds. Therefore, it is possible to mount Surface Mount Resistors on one side of a PCB and other discrete
components on the reverse (mixed PCBs). Surface Mount Resistors are tested for solderability at 235 ℃ during 2
seconds. The test condition for no leaching is 260℃ for 30 seconds. Typical examples of soldering processes that
provide reliable joints without any damage are given in Fig 2.
Fig 2. Infrared soldering profile for Chip Resistors
6
2/11/2023
PART CODE:
CR0201FM240RS1
TEST AND REQUIREMENT (JIS C 5201-1 : 1998)
TEST
PROCEDURE / TEST METHOD
REQUIREMENT
Resistor
Electrical
- DC resistance values measurement
Within the
Characteristics
- Temperature Coefficient of Resistance (T.C.R)
specified tolerance
JISC5201-1: 1998
Natural resistance change per change in degree
Refer to “QUICK
Clause 4.8
centigrade.
REFERENCE DATA”
0Ω
很抱歉,暂时无法提供与“CR0201FM240RS1”相匹配的价格&库存,您可以联系我们找货
