RC20M00000S300
RC20M00000S300
    NEXTGEN
    4-SMD, No Lead
    OSC 20.0000MHZ HCMOS SMD
RC20M00000S300 数据手册
PART CODE: RC20M00000S300 SPECIFICATION SHEET SPECIFICATION SHEET NO. Q0119-RC20M00000S300 DATE Jan.19, 2023 REVISION A1 DESCRIPITION SMD Oscillator, 0705 Type, L7.0*W5.0*H1.50mm, 4 Pads, COM75 series 20.0000MHz, 3.3V, +/-50ppm, Symmetry 45/55, Operating Temp. Range -40°C ~+85°C, Reflow Profile Condition 260 °C Max. HCMOS//15pF, Supply Current 25mA Max. Tristate function - Enable via Pad 1, Packed in Tape/Reel, 1000pcs/Reel RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER TGS COM7531BGI01TLF-20M000 PART CODE RC20M00000S300 VENDOR APPROVE Issued/Checked/Approved DATE: Jan.19, 2023 CUSTOMER APPROVE DATE: 1/19/2023 NextGen Components, Inc. 1 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: RC20M00000S300 MHZ SMDSMD OSCILLATOR CRYSTAL 0705 2520 TYPE 4 PADS MAIN FEATURE • SMD Package, Seam Sealed, 0705 Type, L7.0*W5.0*H1.50mm, 4 Pads, • Low noise and Low current • Industry standard • Reflow Profile Condition 260 °C Max. • Cross more competitors part • RoHS/RoHS III compliant APPLICATION • PDA, PND, DSC, Smart phone, WiLAN, Bluetooth and more • Communication Electronics RFQ PART CODE GUIDE Request For Quotation RC 20M00000 S 300 1 2 3 4 1) RC: Part family Code for SMD Oscillator, 0705 Type, L7.0*W5.0*H1.50mm, 4 Pads, COM75 series 2) 20M00000: Frequency range code for 20.0000MHz 3) S: SMD type, Package Tape/Reel, 1000pcs/Reel 4) 300: Specification code for original part No.: TGS COM7531BGI01TLF-20M000 1/19/2023 NextGen Components, Inc. 2 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: RC20M00000S300 MHZ SMD OSCILLATOR 0705 TYPE 4 PADS DIMENSION (Unit: mm, Tol. +/-0.15mm) Image for reference Marking Line 1: 20.0000 Line 2: Special Code COM75 Pin Function #1 Enable (Tri-State) #2 Ground #3 Output #4 VDD Recommend Pad Layout Circuit Principle 1/19/2023 NextGen Components, Inc. 3 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: RC20M00000S300 MHZ SMD OSCILLATOR 0705 TYPE 4 PADS ELECTRICAL PARAMETERS Parameter Part No. Symbol Units Value Min. Original Manufacturer Holder Type Typical TGS TGS Crystals COM75 SMD Oscillator, 0705 Type, L7.0*W5.0*H1.50mm, 4 Pads Max. Supply Voltage 3 Enable/Disable Function 1 Overall Freq. Tolerance B ppm -50 +50 Operating Temp. Range G °C -40 +85 °C -55 +125 % 45 55 V OH V 90% V OL V Load pF Storage Temp. Range Symmetry Output I Output Waveform V Condition 3.3 +/-10% Tristate function - Enable @ Control via pin 1 High (Logic “1”) 10% HCMOS @OutputLoad 15pF Startup Time ms 10 Supply Current mA 25 Rise/ Fall time ns 10 Phase Jitter ps RoHS Status Others N/A ppm/year Package ±3 T Tape/Reel, 1000pcs/Reel LF- RoHS III compliant Add Value N/A Internal Control Code * N/A Frequency Range Low (Logic “0”) 15 01 Aging @25°C 20M000 @1st year 20.0000MHz Note: 1) Original Part Number: TGS COM7531BGI01TLF-20M000 2) * Internal Control Code- 2 letter or digits; Blank: N/A 1/19/2023 NextGen Components, Inc. 4 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: RC20M00000S300 MHZ SMD OSCILLATOR 0705 TYPE 4 PADS RELIABILITY Test Items Test Method And Conditions Reference Documents High Temperature High Humidity Storage Temperature: 85℃±3℃ Relative Humidity:85%RH Time: 96 Hours JIS C5023 High Temperature Storage Temperature: 125℃±3℃ Time: 96 Hours. MIL-STD-883E Method 1005.8 Low Temperature Storage Temperature: -40℃±3℃ Time: 96 Hours. MIL-STD-883E Method 1013 Thermal Shock Temperature 1: -55℃±5℃ Temperature 2: 85℃±5 ℃ Temperature change between T1 and T2 5 min 10cycles maintain T1 and T2 for 30 minutes each cycle MIL-STD-202F Method 107 Condition A Resistance to Solder Heat Solder Temperature: 260℃±5℃ Time: 10±1 Seconds MIL-STD-202F Method 210E Solderability The solder pot temperature is 245±5℃ , dwell time 5±0.5sec J-STD-002B Drop Test 3 Times Free Fall from 50cm height table to 3cm thickness hard wood board J-STD-002B Mechanical Shock Half sine wave,1000 G 3 Times for all 3 directions(X,Y Z) MIL STD 202F Method 213B Vibration Frequency Range: 10Hz~55Hz Amplitude: 0.75mm 2 Hours in each direction, total 6 Hours MIL-STD-883E Method 2007.3 Leakage Test Take measurements with a helium Leakage detector Leakage Rate≤1×10ˉ³Pa cm³/s MIL-STD-883E 1/19/2023 NextGen Components, Inc. 5 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: RC20M00000S300 MHZ SMD OSCILLATOR 0705 TYPE 4 PADS SUGGESTED REFLOW PROFILE (For Reference Only) Total time: 200 Sec. Max. Solder melting point: 220℃ Profile Feature Pb-Free Assembly Average Ramp-up Rate (Ts Max to Tp) 3℃/second Max Preheat Temperature Min (Ts Min.) 125℃ Temperature Max (Ts Max.) 200℃ Time (ts Min. to ts Max.) 60~180 seconds Temperature (TL) 217℃ Time (tL) 60~150 seconds Time maintained above Peak/Classification Temperature (Tp) 260 ℃ Time within 5℃ of actual Peak Temperature (tp) 20~40 seconds Ramp-down rate 6 ℃ /Second Max. Time 25 ℃ to Peak Temperature 8 minutes Max. Suggest reflow times 3 Times Max. 1/19/2023 NextGen Components, Inc. 6 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: RC20M00000S300 MHZ SMD OSCILLATOR 0705 TYPE 4 PADS TAPE/REEL (Unit: mm) All Devices are packed in accordance with EIA standard RS-481-2 and specifications, 1000pcs/Reel DISCLAIMER NextGen Components, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information 1/19/2023 NextGen Components, Inc. 7 sales@NextGenComponent.com www.NextGenComponent.com
RC20M00000S300 价格&库存
很抱歉,暂时无法提供与“RC20M00000S300”相匹配的价格&库存,您可以联系我们找货
