PART CODE:
RD27M00000S300
SPECIFICATION SHEET
SPECIFICATION SHEET NO.
Q0119- RD27M00000S300
DATE
Jan.19, 2023
REVISION
A1
DESCRIPITION
SMD Oscillator, 5032 Type, L5.0*W3.2*H1.3mm, 4 Pads, COM53 series
27.0000MHz, 3.3V, +/-50ppm, Symmetry 45/55,
Operating Temp. Range -40°C ~+85°C, Reflow Profile Condition 260 °C Max.
HCMOS//15pF, Supply Current 40mA Max,
Tristate function - Enable via Pad 1,
Packed in Tape/Reel, 1000pcs/Reel
RoHS/RoHS III compliant
CUSTOMER
CUSTOMER PART NUMBER
CROSS REF. PART NUMBER
ORIGINAL PART NUMBER
TGS COM5331BGI01TLF-27M000
PART CODE
RD27M00000S300
VENDOR APPROVE
Issued/Checked/Approved
DATE: Jan.19, 2023
CUSTOMER APPROVE
DATE:
1/19/2023
NextGen Components, Inc.
1
sales@NextGenComponent.com
www.NextGenComponent.com
PART CODE:
RD27M00000S300
MHZ SMDSMD
OSCILLATOR
CRYSTAL 5032
2520 TYPE 4 PADS
MAIN FEATURE
• SMD Package, Seam Sealed, 5032 Type, L5.0*W3.2*H1.3mm, 4 Pads
• Low noise and Low current
• Industry standard
• Reflow Profile Condition 260 °C Max.
• Cross more competitors part
• RoHS/RoHS III compliant
APPLICATION
• PDA, PND, DSC, Smart phone, WiLAN, Bluetooth and more
• Communication Electronics
RFQ
PART CODE GUIDE
Request For Quotation
RD
27M00000
S
300
1
2
3
4
1) RD: Part family Code for SMD Oscillator 5032 Type, L5.0*W3.2*H1.3mm, 4 Pads, COM53 series
2) 27M00000: Frequency range code for 27.00000MHz
3) S: SMD type, Package Tape/Reel, 1000pcs/Reel
4) 300: Specification code for original part No.: TGS COM5331BGI01TLF-27M000
1/19/2023
2
PART CODE:
RD27M00000S300
MHZ SMD OSCILLATOR 5032 TYPE 4 PADS
DIMENSION (Unit: mm, Tol. +/-0.15mm)
Image for reference
Marking
Line 1: 27.0000
Line 2: Special Code
COM53
Pin Function
#1 Enable (Tri-State)
#2 Ground
#3 Output
#4 VDD
Recommend Pad Layout
Circuit Principle
1/19/2023
3
PART CODE:
RD27M00000S300
ELECTRICAL PARAMETERS
Parameter
Part No.
Symbol
Units
Value
Min.
Original Manufacturer
Holder Type
Typical
Condition
Max.
TGS
TGS Crystals
COM53
SMD Oscillator, 5032 Type, L5.0*W3.2*H1.30mm,
4 Pads
Supply Voltage
3
Enable/Disable Function
1
Overall Freq. Tolerance
B
ppm
-50
+50
G
°C
-40
+85
°C
-55
+125
45
55
V OH
V
90%
V OL
V
Load
pF
Storage Temp. Range
Symmetry
Output
I
Output Waveform
V
3.3
+/-10%
@ Control via
pin 1
@25°C
High (Logic “1”)
10%
Low (Logic “0”)
15
01
HCMOS
@OutputLoad
15pF
Startup Time
ms
10
Supply Current
mA
40
Rise/ Fall time
ns
10
Phase Jitter
ps
1.0
@12KHz~20MHz
ppm/year
±3
@1st year
Aging
Others
Package
T
Tape/Reel
RoHS
Status
LF
RoHS III compliant
Add Value
N/A
Internal
Control
Code *
N/A
Frequency Range
-27M000
27.0000MHz
Note: 1) Original Part Number: TGS COM5331BGI01TLF-27M000
2) * Internal Control Code- 2 letter or digits; Blank: N/A
1/19/2023
4
PART CODE:
RD27M00000S300
RELIABILITY
Test Items
Test Method And Conditions
Reference
Documents
High Temperature
High Humidity Storage
Temperature: 85℃±3℃
Relative Humidity:85%RH
Time: 1000 Hours
JIS C5023
High Temperature
Storage
Temperature: 125℃±3℃
Time: 1000+/-12 Hours.
MIL-STD-883
Low Temperature
Storage
Temperature: -40℃±3℃
MIL-STD-883
Thermal Shock
Temperature 1: -125℃±3℃
Temperature 2: -55℃±3 ℃
Temperature change between T1 and T2 10 min
100 cycles maintain T1 and T2 for 10 Min. each cycle
MIL-STD-883
Resistance to Solder
Heat
Solder Temperature: 260℃±5℃
Time: 10±1 Seconds
MIL-STD-202
Solderability
The solder pot temperature is 245±5℃
Immersing Depth: 0.5nm Min.
Immersion Time: 5 ± 1 sec.
Flux: Rosin resin methyl alcohol solvent (1:4)
MIL-STD-883
Drop Test
3 Times Free Fall from 75cm height table to 3cm thickness
hard wood board
JIS C6701
Mechanical Shock
Half sine wave,1000 G
3 Times for all 3 directions(X,Y Z)
MIL STD 202
Vibration
Frequency Range: 10Hz~2000Hz
Amplitude: 1.52m/20G
Sweep time: 20 minutes
4 Hours in each direction, total 12 Hours
MIL-STD-883
Leakage Test
Gross leak: standard sample for automatic gross leak
detector, test pressure: 2 kg/cm²
Fine leak: Helium Bomging 4.5kgf/cm² for 2 hours
MIL-STD-883
Pressure cooker storage
121℃±3℃, RH 100%; 2 bar, 240 hours
JIS C6701
1/19/2023
5
PART CODE:
RD27M00000S300
SUGGESTED REFLOW PROFILE (For Reference Only)
Total time: 200 Sec. Max. Solder melting point: 220℃
Profile Feature
Pb-Free Assembly
Average Ramp-up Rate (Ts Max to Tp)
3℃/second Max
Preheat
Temperature Min (Ts Min.)
125℃
Temperature Max (Ts Max.)
200℃
Time (ts Min. to ts Max.)
60~180 seconds
Temperature (TL)
217℃
Time (tL)
60~150 seconds
Time maintained
above
Peak/Classification Temperature (Tp)
260 ℃
Time within 5℃ of actual Peak Temperature (tp)
20~40 seconds
Ramp-down rate
6 ℃ /Second Max.
Time 25 ℃ to Peak Temperature
8 minutes Max.
Suggest reflow times
3 Times Max.
1/19/2023
6
PART CODE:
RD27M00000S300
TAPE/REEL (Unit: mm)
All Devices are packed in accordance with EIA standard RS-481-2 and specifications, 1000pcs/Reel
DISCLAIMER
NextGen Components, Inc. reserves the right to make changes to the product(s) and or information contained
herein without notice. No liability is assumed as a result of their use or application. No rights under any patent
accompany the sale of any such product(s) or information
1/19/2023
7
