SIR318M000S041
SIR318M000S041
    NEXTGEN
    SIP4
    318 MHz SAW 谐振器 50 Ohms -40°C ~ 85°C 表面贴装型
SIR318M000S041 数据手册
PART CODE: SIR318M000S041 SPECIFICATION SHEET SPECIFICATION SHEET NO. Q0528-SIR318M000S041 DATE May 28, 2023 REVISION A0 DESCRIPITION SMD SAW Resonator L5.0*W3.5*H1.5mm 5035 Type 4 Pads SIR Series 318.00000MHz, 1-Port, Insertion Loss: 1.8 dB Max. Tolerance ±50KHz Operating Temp. Range -40°C ~+85°C, Reflow Profile Condition 260 °C Max. Tape/Reel, 1000pcs/Reel RoHS/RoHS III compliant CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER TGS SIR 318.0ME TLF PART CODE SIR318M000S041 VENDOR APPROVE Issued/Checked/Approved DATE: May 28, 2023 CUSTOMER APPROVE DATE: 5/28/2023 NextGen Components, Inc. 1 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SIR318M000S041 SMD SAW RESONATOR SMD CRYSTAL 5035 2520 TYPE TYPE SIR 4SERIES PADS MAIN FEATURE • SMD SAW Resonator L5.0*W3.5*H1.5mm 5035 Type 4 Pads • Package Code QCC4A • One Port SAW Resonator • Electrostatic Sensitive Device(ESD) • Low-loss and Short Lead time • Cross more competitors part • RoHS/RoHS III compliant APPLICATION • Bluetooth, wireless communication set • Communication Electronics RFQ PART CODE GUIDE Request For Quotation SIR 318M000 S 041 1 2 3 4 1) SIR: Series Code, SMD SAW Resonator L5.0*W3.5*H1.5mm 5035 Type 4 pads 2) 318M000: Frequency range code for 318.0000MHz 3) S: SMD type, Package Tape/Reel, 4) 041: Internal code (A~Z or 1~9 or Blank) 5/28/2023 NextGen Components, Inc. 2 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SIR318M000S041 SMD SAW RESONATOR 5035 TYPE SIR SERIES DIMENSION (Unit: mm, Tol.: +-0.15mm) Image for reference SIR series, Package Code QCC4A L5.0*W3.5*H1.5mm 5035 Type Pin Configuration 1 Input/Output 3 Output/Input 2,4 Ground Marking: Standard + ● : Pin 4 Test Circuit 5/28/2023 NextGen Components, Inc. 3 sales@NextGenComponent.com www.NextGenComponent.com SIR318M000S041 PART CODE: SMD SAW RESONATOR 5035 TYPE SIR SERIES ELECTRICAL PARAMETERS Parameter Part No. Symbol Units Value Min. Typical Max. Original Manufacturer TGS TGS Crystals Holder Type SIR SMD SAW Resonator L5.0*W3.5*H1.5mm 5035 Type 4 Pads Frequency Range (f0) 318.0M MHz 318.0000 Frequency Tolerance E KHz ±50 Operation Temperance °C -40 +85 Storage Temperance °C -40 +85 DC Voltage V ±30 dBm 15 dB 1.2 RF Power Dissipation Insertion Loss Quality Factor (Q) @Unload 16461 Quality Factor (Q) @50 Ω Loaded 1777 1.8 ℃ Turnover Temperature Frequency Temp. Coefficient ppm/℃ Aging (Absolute Value during the First Year) ppm/Year DC Insulation Resistance MΩ ≤±10 1.0 RF Equivalent RLC Model @Motional Resistance Ω 12.0 RF Equivalent RLC Model @Motional Inductance µH 99.7 RF Equivalent RLC Model @Motional Capacitance fF 2.61 Static Capacitance pF 3.4 3.7 Package T Tape/Reel RoHS Status LF RoHS III compliant Add Value Blank: N/A Internal Control Code Blank: N/A 22.0 4.0 Note: 1) Test Temperature: 25℃±2℃, Terminating source impedance: 50Ω Terminating load impedance: 50Ω 2) Original Part Number: TGS SIR 318.0ME TLF 5/28/2023 NextGen Components, Inc. 4 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SIR318M000S041 SMD SAW RESONATOR 5035 TYPE SIR SERIES FREQUENCY RESPONSE 5/28/2023 NextGen Components, Inc. 5 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SIR318M000S041 SMD SAW RESONATOR 5035 TYPE SIR SERIES EQUIVALENT LC MODEL TEMPERATURE CHARACTERISTICS Note: The curve shown above accounts for resonator contribution only and does not include LC component temperature contributions. PLICTYPCIAL APATION CIRCUITS Typical Low-power Transmitter Application Typical Local Oscillator Application 5/28/2023 NextGen Components, Inc. 6 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SIR318M000S041 SMD SAW RESONATOR 5035 TYPE SIR SERIES RELIABILITY Test Items Test Method And Conditions Requirement Temperature (1) Temperature: 85℃±2℃ , Duration: 250h , Recovery time: 2h±0.5h It shall remain Storage (2) Temperature: –40℃±3℃ , Duration: 250h ,Recovery time: 2h±0.5h electrical performance Humidity Test Conditions: 60℃±2℃ , 90~95% RH Thermal Shock Heat cycle conditions: TA=-40℃±3℃, TB=85℃±2℃, t1=t2=30min, after tests Duration: 250h Switch time: ≤3min, Cycle time: 100 times, Recovery time: 2h±0.5h. Vibration Fatigue Frequency of vibration: 10~55Hz Directions: X,Y and Z Drop Test Solderability Amplitude:1.5mm Duration: 2h Cycle time: 10 times Height: 1.0m Temperature: 245℃±5℃ Duration: 3.0s--5.0s Depth: DIP--2/3 , SMD--1/5 Resistance to Soldering Heat (1)Thickness of PCB:1mm , Solder condition: 260℃±5℃ , Duration: 10±1s (2)Temperature of Soldering Iron: 350℃±10℃ , Duration: 3~4s , Recovery time : 2 ± 0.5h 5/28/2023 NextGen Components, Inc. 7 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SIR318M000S041 SMD SAW RESONATOR 5035 TYPE SIR SERIES SUGGESTED REFLOW PROFILE (For Reference Only) 5/28/2023 NextGen Components, Inc. 8 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SIR318M000S041 SMD SAW RESONATOR 5035 TYPE SIR SERIES TAPE DIMENSION (Unit: mm, 1000pcs/Reel) Code Dimension W 12.0+/-0.30 F 5.50+/-0.10 E 1.75+/-0.10 P0 4.00+/-0.10 P1 8.00+/-0.10 P2 2.00+/-0.10 D0 Ø1.5+/-0.10 D1 Ø1.5+/-0.25 t1 0.30+/-0.01 t2 1.90+/-0.05 A 3.70+/-0.10 B 5.20+/-0.10 REEL DIMENSION (Unit: mm) Code 5/28/2023 NextGen Components, Inc. Dimension A Ø178.0+/-2.0 B Ø60.0+/-0.5 C Ø13.0+/-0.5 D Ø21+/-0.8 E 2.00+/-0.5 T 15.4+/-1.00 t 0.31 Max. 9 sales@NextGenComponent.com www.NextGenComponent.com PART CODE: SIR318M000S041 SMD SAW RESONATOR 5035 TYPE SIR SERIES CAUTION 1. As a result of the particularity of inner structure of SAW products, it easy to be breakdown by electrostatic, so we should pay attention to ESD protect in the test. 2. Static voltage between signal load and ground may cause deterioration and destruction of the component. Please avoid static voltage. 3. Ultrasonic cleaning may cause deterioration and destruction of the component. Please avoid ultrasonic cleaning. 4. Only leads of component may be soldered. Please avoid soldering another part of component. 5. There is a close relationship between the device's performance and matching network. The specifications of this device are based on the test circuit shown above. L and C values may change depending on board layout. Values shown are intended as a guide only. 6. The temperature of manual welding should not exceed 300 ℃. 7. The specifications of this device are based on the test circuit shown above and subject to change or obsolescence without notice. 8. All equipment designs utilizing this product must be approved by the appropriate government agency prior to manufacture or sale. 9. Our liability is only assumed for the Surface Acoustic Wave (SAW) component(s) perse, not for applications, processes and circuits implemented within components or assemblies. 10. For questions on technology, prices and delivery, please contact our sales offices or e-mail: sales@NextGenComponent.com. DISCLAIMER NextGen Components, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information 5/28/2023 NextGen Components, Inc. 10 sales@NextGenComponent.com www.NextGenComponent.com
SIR318M000S041 价格&库存
很抱歉,暂时无法提供与“SIR318M000S041”相匹配的价格&库存,您可以联系我们找货
