UL157M016HEJTA
UL157M016HEJTA
    NEXTGEN
    Radial, Can - SMD
    CAP. ALUM 150UF 16V 20% SMD
UL157M016HEJTA 数据手册
PART CODE: UL157M016HEJTA SPECIFICATION SHEET SPECIFICATION SHEET NO. N0909- UL157M016HEJTA DATE Sept. 09, 2021 REVISION A0 DESCRIPITION SMD Aluminum Electrolytic Capacitors, Long Life type UL series, 2 pads Capacitance: 150µF, Tolerance ±20%, Voltage 16V, Case size: Ø6.3*L7.7mm, Ripple Current 90 mA Max. 3000 Hours Operating Temp. Range -55°C ~+105°C RoHS/RoHS III Compliant & Halogen Free Package in Tape/Reel, 1000pcs/Reel CUSTOMER CUSTOMER PART NUMBER CROSS REF. PART NUMBER ORIGINAL PART NUMBER Aillen CAE157M1CHULEG7TR1 PART CODE UL157M016HEJTA VENDOR APPROVE Issued/Checked/Approved DATE: Sept. 09, 2021 CUSTOMER APPROVE DATE: 1 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: UL157M016HEJTA SMD ALUMINUM ELECTROLYTIC CAPACITORS UL SERIES MAIN FEATURE • SMD Aluminum Electrolytic Capacitors • Designed for SMD on PCB • Applicable to automatic mounting machine • RoHS Complaint and Halogen Free APPLICATION • High-density Patch Assembly Electronic Circuit • Power Supply, LED Lighting, Some Precision Equipment Products, Etc. RFQ PART CODE GUIDE Request For Quotation UL 157 M 016 H E J T A 1 2 3 4 5 6 7 8 9 1) UL: SMD Aluminum Electrolytic Capacitors, Long Life type, UL series, 2 pads 2) 157: Rated Capacitance Code, 157: 150µF 3) M: Capacitance tolerance code, M: ±20%; K: ±10%; V: -10% ~ ±20%, ; Q: -10% ~ ±20%; R: 0% ~ ±20%, 4) 016: Rated Voltage Code, 6R3: 6.3V; 010: 10V; 016:16V; 025: 25V; 035: 35V; 050: 50V; 063: 63V; 100: 100V 5) H: Environmental Requirements code, R: RoHS Complaint; H: RoHS III Complaint & Halogen Free 6) E: Aluminum Case size code, B: Ø3.0mm; C: Ø4.0mm; D: Ø5.0mm; E: Ø6.3mm; F: Ø8.0mm; G: Ø10.0mm; H: Ø12.5mm 7) J: Aluminum case Heigh code, H: L5.4mm; J: L7.7mm; K: L10.2mm; L: L11.5mm; M: L12.5mm; N: L13.5mm 8) T: Package in Tape/Reel, 1000pcs/Reel; B: in Bulk 9) A: Internal control or Customer’s Special Code (A~Z or 1~9) 2 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: UL157M016HEJTA SMD ALUMINUM ELECTROLYTIC CAPACITORS UL SERIES Image for reference UL Series Case Ø6.30*L7.7mm Marking Negative Polarity Dimension (mm) A 6.6 B 6.6 D Ø6.3 H 7.8 Max I 2.6 Ref. L 7.7+/-0.3 K 0.50 Max. p 1.8 Ref. W 0.65+/-0.1 Recommended Land (mm) Capacitance 150 16V UL Symbol Rated Voltage 3.5 1.9 3.5 Series code 1.6 3 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: UL157M016HEJTA SMD ALUMINUM ELECTROLYTIC CAPACITORS UL SERIES CONSTRUCTION Pressure Relief Aluminum Foil (Anode & Cathode Foil) Electrolytic Paper Electrolytic Aluminum Case Rubber Base Plate Lead Wire CHARACTERISTICS Standard atmospheric conditions The standard range of atmospheric conditions for making measurements/test as follows: Ambient temperature: 15°C to 35°C ; Relative humidity: 45% to 85% ; Air Pressure: 86kPa to 106kPa If there is any doubt about the results, measurement shall be made within the following conditions: Ambient temperature: 20°C ± 2°C ; Relative humidity: 60% to 70% ; Air Pressure: 86kPa to 106kPa As to the detailed information, please refer to following Table Item Characteristics Operating Temperature Range -55~+105℃ Rated Voltage Range 16V Capacitance Range 150 μF Capacitance Tolerance at 20℃,120Hz ±20% Leakage Current at 20℃ I ≤ 0.01 CV (μA) or 3 (μA), Whichever is greater after 2 minutes I: Leakage Current(μA) C: Rated Capacitance(μF) V: Working Voltage(V) 4 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: UL157M016HEJTA SMD ALUMINUM ELECTROLYTIC CAPACITORS UL SERIES Item Dissipation Factor at 20℃, 120Hz Low Temperature Stability Characteristics WV 6.3 10 16 25 35 50 63 100 Tanδ 0.30 0.24 0.20 0.18 0.16 0.14 0.14 0.14 Impedance ratio (120 Hz ) Rated Voltage (V) Load Life 6.3 10 16 25 35 ~100 Z-25℃/Z+20℃ (120Hz) 4 3 2 2 2 Z-55℃/Z+20℃ (120Hz) 8 6 4 4 3 After applying rated voltage with max ripple current for 3000 hrs at+105℃,and then resumed 16 hours, the capacitors Shall meet the following requirements. Shelf Life Capacitance Change Within ±30% of initial value Dissipation Factor Not more than 300% of the specified value Leakage Current Not more than the specified value After storage for 1000 hrs at +105℃, then resumed 16 hours, the capacitors Shall meet the following requirements Capacitance Change Within ±30% of initial value Dissipation Factor Not more than 300% of the specified value Leakage Current Not more than 300% of the specified value 5 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: UL157M016HEJTA SMD ALUMINUM ELECTROLYTIC CAPACITORS UL SERIES Item Resistance to Soldering Heat Characteristics The capacitors shall be kept on then hot plate maintained at 250℃ for 30 seconds. After removing from the hot plate and restored at room temperature, they meet the following requirement: Adhesion test Capacitance Change Within ±10% of the initial value Dissipation Factor Not more than the specified value Leakage Current Not more than the specified value Reasonable pulling strength: 0.1~0.7N; Pulling speed: 300mm/min 6 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com UL157M016HEJTA PART CODE: SMD ALUMINUM ELECTROLYTIC CAPACITORS UL SERIES CASE SIZE & MAX RIPPLE CURRENT Rated Voltage (V) Capacitanc e (+/-20%) µF Case Size Ø*L mm Tanδ @+105°C, 100KHz Ripple Current mA r.m.s . @+105°C, 100KHz Impedance Ω @20℃,100KHz 16 150 6.3*7.7 0.16 90 - FREQUENCY COEFFICIENT OF ALLOWABLE RIPPLE CURRENT Frequency 50Hz 120Hz 300Hz 1KHz ≥10kHz Coefficient 0.70 1.00 1.17 1.36 1.50 WELDING METHODS AND APPLICABILITY Welding Method Reflow Soldering Soldering Iron Wave Soldering The feasibility of OK OK N/A Temperature °C Conditions for the use of lead-free reflow soldering.: Time Second METHODS THE FOLLOWING: Reflow soldering: please follow the temperature condition during welding. If high temperature is used, please measure and inform the capacitor temperature and reflow soldering condition. The product size is larger and its rising temperature is slower. It is not necessary to adjust the temperature of the reflow solder in accordance with the size of the product. For example, the products of 4 and 10 will be installed in the PCB over tin furnace. 7 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: UL157M016HEJTA SMD ALUMINUM ELECTROLYTIC CAPACITORS UL SERIES Precautions for soldering tin: Related factors of reflow soldering temperature: Product size: The product size is larger and its temperature rises slowly. Product installation position: The temperature of PCB center is lower than that of PCB. Reflow soldering If possible, avoid reflow soldering twice. If repeated reflux is unavoidable, measure and inform the first and second reflux temperature, and the time of reflow soldering. Please do not 3 times of reflow soldering Please follow the following conditions when soldering tin soldering: Soldering iron maximum temperature:350±5℃ Welding time:3+1/-0 sec TEST METHOD AND PEAK TEMPERATURE PERMISSIBLE RANGE Part Code UL157M016HEJTA 16 V Rated Voltage(V) Case Size Preheating The Duration Of The Ø6.3*L7.7mm Temperature Range (T1~T2) 150~180 ℃ Time (t1) Max. 100 Second Temperature Range (T3) Time (t2) Max. The Highest Temperature 230 ℃ 60 Second Temperature Range (T4) Time (t3) Max. 260 ℃ 5 Second Return The Number 2 times Max. Note 1) Please contact us if the condition of use are higher than the 2) When performing 2nd reflow Soldering, please make sure the temperature of capacitor have cooled to :5~35℃ 8 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: UL157M016HEJTA SMD ALUMINUM ELECTROLYTIC CAPACITORS UL SERIES TAPE (Unit: mm), 1000pcs/Reel REEL (Unit: mm) Case size: Ø6.3*L7.7mm Symbol Dimension (mm) W 16.0 P 12.0 F 7.5 A0 7.0 B0 7.0 T2 8.3 A 18.0+/-0.3 9 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: UL157M016HEJTA SMD ALUMINUM ELECTROLYTIC CAPACITORS UL SERIES ATTENTION FOR OP-CAP SOLDERING Reflow soldering will reduce the rated electrostatic capacity of the product, and it should be confirmed whether reflow soldering condition meets the specification of recommended reflow soldering. Although the actual reflow condition change is still based on the reflow soldering method, please note that the highest temperature and the electrode terminal at the bottom of the aluminum shell must not exceed the maximum temperature. Please note: OP - CAP products during the process of reflow heating temperature should increase to more than 200 ℃. If the reflow condition temperature or duration is greater than the above table, the OP-CAP product will be damaged. The electrostatic capacity of the product is reduced by about 50%, the leakage current is large (up to mA), and the outside of the capacitor is damaged. APPLICATION GUIDELINE Circuit Design: 1) Please make sure the environmental and mounting conditions to which the capacitor will be exposed are within the conditions specified in catalogue. 2) Operating temperature and applied ripple shall be within specification. 3) Appropriate capacitors which comply with the life requirement of the products should be selected when designing the circuit. 4) Aluminum electrolytic capacitors are polar. Make sure that no reverse voltage or AC voltage is applied to the capacitors. Please use bi-polar capacitors for a circuit that can possibly see reversed polarity. Note: Even bi-polar capacitors cannot be used for AC voltage application. 5) Do not use aluminum electrolytic capacitors in a circuit that requires rapid and very frequent charge/ discharge. In this type of circuit, it is necessary to use a special design capacitor with extended life characteristics. 6) Do not apply excess voltage. (1) Please pay attention to that the peak voltage, which is DC voltage overlapped by ripple current, will not exceed the rated voltage. (2) In the case where more than 2 aluminum electrolytic capacitors are used in series, please make sure that applied voltage will be lower than rated voltage and the voltage will be applied to each capacitor equally by using a balancing resistor in parallel with the capacitor. 7) Aluminum electrolytic capacitors shall not be used under the following environmental conditions: (1) (a) Capacitors will be exposed to water (including condensation), brine or oil. (b) Ambient conditions that include toxic gases such as hydrogen sulfide, sulfurous acid, nitrous acid, chlorine, bromine, methyl bromide, ammonium, etc. (c) Ambient conditions that expose the capacitor to ozone, ultraviolet ray and radiation. 10 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: UL157M016HEJTA SMD ALUMINUM ELECTROLYTIC CAPACITORS UL SERIES (2) Severe vibration and physical shock conditions that exceed specification. Vibration test condition: 10-55-10Hz vibration frequency range : 10~55~10Hz sweep rate : 10~55~10Hz/minute sweep method : logarithmic amplitude or acceleration : 1.5mm (max. acceleration is 10G) direction of vibration : X, Y, Z direction testing time: 2 hours per each direction Shock is not applicable normally. If a particular condition is required, please contact our sales office. 8) The main chemical solution of the electrolyte and the separator paper used in the capacitors are combustible. The electrolyte is conductive. When it comes in contact with the PC board, there is a possibility of pattern corrosion or short circuit between the circuit pattern, which could result in smoking or catching fire. Do not locate any circuit pattern beneath the capacitor end seal. 9) Do not design a circuit board that the heat generating components are placed near the aluminum electrolytic capacitor or on the reverse side of PC board, if that just under the capacitor. 10) Electrical characteristics may vary depending on changes in temperature and frequency. Please consider this variation when you design circuits. 11) When you install more than 2 capacitors in parallel, please consider the balance of current flowing into the capacitors. 12) While mounting capacitors on double-side PC board, the capacitors should be away from those unnecessary base plate holes and connection holes. Mounting 1) Once a capacitor has been assembled in the set and power applied, do not attempt to re-use the capacitor in other circuits or application. 2) Leakage current of the capacitors that have been stored for more than 2 years may increase. When leakage current has increased, please perform a voltage treatment using a 1kΩ resistor. 3) Please confirm specifications and polarity before installing capacitors on the PC board. 4) Do not drop capacitors on the floor, nor use a capacitor that was dropped. 5) Do not deform the capacitor during installation. 6) Please pay attention to the mechanical shock to the capacitor by suction nozzle of the automatic insertion machine or automatic mounter, or by product checker, or by centering mechanism. 11 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: UL157M016HEJTA SMD ALUMINUM ELECTROLYTIC CAPACITORS UL SERIES Reflow soldering 1) Please follow “Reflow Soldering Conditions” when use the part. 2) When an infrared heater is used, please pay attention to the extent of heating since the absorption rate of infrared will vary due to difference in the color and size of the capacitor. (1) Do not tilt lay down or twist the capacitor body after the capacitor are soldered to the PC board. (2) Do not carry the PC board by grasping the soldered capacitor. (3) Please do not allow anything to touch the capacitor after soldering. If PC boards are stored in stack, please make sure the PC board or other components away from the capacitor. (4) The capacitors shall not be effected by any radiated heat from the soldered PC board or other components after soldering. (5) Cleaning: (a) Do not clean capacitors with halogenated cleaning agent. However, if it is necessary to clean with halogenated cleaning agent, please contact our sales office. (b) Recommended cleaning method, Applicable : Any type, any ratings Cleaning conditions: Total cleaning time shall be within 2 minutes by immersion, ultrasonic or other methods. Temperature of the cleaning agents shall be 40℃ or below. After cleaning, capacitors should be dried by using hot air for the minimum 10 minutes along with the PC board mounted. Hot air temperature should be within the maximum operating temperature of the capacitor. Insufficient dryness after water rinse may cause appearance problems, such as bottom-plate bulge and etc.; Avoid using ozone destructive substances as cleaning agents for protecting global environment. In the PCB after mounted 1) Do not directly touch terminal by hand. 2) Do not link positive terminal and negative terminal by conductor, nor spill conductible liquid such as alkaline or acidic solution on or near the capacitor. 3) Please make sure that the ambient conditions where the set is installed are free from spilling water or oil, direct sunlight, ultraviolet rays, radiation, poisonous gases, vibration or mechanical shock. 12 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com PART CODE: UL157M016HEJTA SMD ALUMINUM ELECTROLYTIC CAPACITORS UL SERIES Maintenance and Inspection Please periodically inspect the aluminum capacitors that are installed in industrial equipment. The following items should be checked: Appearance: remarkable abnormality such as pressure relief vent opening, electrolyte leaking, etc. Electrical characteristics: capacitance, dielectric loss tangent, leakage current and etc., which are specified in catalogue or alternate product specification. In an Emergency 1) If you see smoke due to operation of safety vent, please turn off the main switch or pull out the plug from the outlet. 2) If you breathe the gas or ingest the electrolyte, please wash out your mouth and throat with water immediately. 3) If your skin is exposed to the electrolyte, please wash it away using soap and water. Storage 1) Do not keep capacitor in high temperature and high humidity atmosphere.Storage conditions should be: Temperature: 5℃~35℃ Humidity : lower than 75% Place : Indoor 2) Avoid ambient conditions where capacitors are covered with water, brine or oil. Disposal Please take either of the following methods in disposing capacitors. 1) Incinerate them after crushing capacitors or making a hole on the capacitor body. 2) If incineration is not applicable, hand them over to a waste disposal agent and have them buried in landfills. DISCLAIMER NextGen Component, Inc. reserves the right to make changes to the product(s) and or information contained herein without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany the sale of any such product(s) or information 13 NextGen Components, Inc. sales@NextGenComponent.com www.NextGenComponent.com
UL157M016HEJTA 价格&库存
很抱歉,暂时无法提供与“UL157M016HEJTA”相匹配的价格&库存,您可以联系我们找货
