PART CODE:
UT226M100HFKTA
SPECIFICATION SHEET
SPECIFICATION SHEET NO.
Q0622- UT226M100HFKTA
DATE
Jun. 22, 2023
REVISION
A1
DESCRIPITION
SMD Aluminum Electrolytic Capacitors, Wide Temperature Standard Type
UT series, 2 pads Capacitance: 22µF, Tolerance ±20%, Voltage 100V,
Case size: Ø D8.00*L10.2mm, Ripple Current 100mA Max.@+105℃, 120Hz
Lifetime 2000Hours @105°C, Operating Temp. Range -55°C ~+105°C
RoHS/RoHS III Compliant & Halogen Free
Package in Tape/Reel, 500pcs/Reel
CUSTOMER
CUSTOMER PART NUMBER
CROSS REF. PART NUMBER
ORIGINAL PART NUMBER
Aillen CAE226M2AHUTFJ5TR
PART CODE
UT226M100HFKTA
VENDOR APPROVE
Issued/Checked/Approved
DATE: Jun. 22, 2023
CUSTOMER APPROVE
DATE:
6/22/2023
NextGen Components, Inc.
1
sales@NextGenComponent.com
www.NextGenComponent.com
PART CODE:
UT226M100HFKTA
SMD ALUMINUM ELECTROLYTIC CAPACITORS UT SERIES
MAIN FEATURE
• Polar Aluminum Electrolytic Capacitor (Foil Type)
• High stability and reliability
• Lifetime 2000 Hours @ 105°C
• Designed Capacitor’s Quality Meets IEC60384.
• Applicable To Automatic Mounting Machine
• Cross Competitors Parts FN, FKS, MVE UUT SKV, SGV Series and more.
• RoHS Complaint And Halogen Free
APPLICATION
• High-density Patch Assembly General Electronic Circuit Etc.
RFQ
PART CODE GUIDE
Request For Quotation
UT
226
M
100
H
F
K
T
A
1
2
3
4
5
6
7
8
9
1) UT: SMD Aluminum Electrolytic Capacitors, UT series, 2 pads
2) 226: Rated Capacitance Code, 105: 1.0µF; 225: 2.2µF; 335: 3.3µF; 475: 4.7µF; 106: 10µF; 226: 22µF; 336: 33µF; 476: 47µF
107: 100µF; 227: 220µF; 337: 330µF ; 477: 470µF; 687: 680µF; 108: 1000µF; 158: 1500µF; 228: 2200µF
3) M: Capacitance tolerance code, M: ±20%; K: ±10%; V: -10% ~ ±20%,
4) 100: Rated Voltage Code, 6V3: 6.3V; ; 010: 10V; 016:16V; 025: 25V; 035: 35V; 050: 50V; 063: 63V; 100: 100V
5) H: Environmental Requirements code, R: RoHS Complaint; H: RoHS III Complaint & Halogen Free
6) F: Aluminum Case size code, B: Ø D3.0mm; C: Ø D4.0mm; D: Ø D5.0mm; E: Ø D6.3mm; F: Ø D8.0mm; G: Ø D10.0mm; P: Ø D12.5mm
7) K: Aluminum case Heigh code, H: L5.4mm; I: L6.5mm; J: L7.7mm; K: L10.2mm; L: L11.5mm; M: L12.5mm; N: L13.5mm
8) T: Package in Tape/Reel, 500pcs/Reel
9) A: Internal control or Customer’s Special Code (A~Z or 1~9)
6/22/2023
2
PART CODE:
UT226M100HFKTA
Image For Reference
UT Series
Case Ø D8.0*L10.2mm
Explosion Proof Value
Marking
Capacitance
Negative
Polarity
22
100V
UT
Symbol
Dimension
(mm)
A
8.3
B
8.3
D
Ø 8.0
C
9.0
+/-0.2
L
10.2
-0.2/+0.8
p
3.1
+/-0.20
W
0.70~1.1
Recommended Pad Layout
Rated Voltage
Series code
6/22/2023
Symbol
Dimension
G
3.0
X
2.5
Y
3.5
3
PART CODE:
UT226M100HFKTA
CONSTRUCTION
Inside Unit:
5. Separator
6. Anode Foil
7. Cathode Foil
Pressure Relief
3. Aluminum Can
4. Sealing Rubber
2. Isolator
1.
Terminals
No.
Parts
Material
1
Terminal
Tinned Copper – Clad Steel Wire (Pb Free)
2
Isolator
Thermo-plastic resin
3
Aluminum Can
Aluminum
4
Sealing Rubber
Synthetic rubber
5
Separator
Manila hemp
6
Anode Foil
High purity aluminum foil
7
Cathode Foil
Aluminum foil
6/22/2023
4
PART CODE:
UT226M100HFKTA
CHARACTERISTICS
Standard Atmospheric Conditions
The standard range of atmospheric conditions for making measurements/test as follows:
Ambient temperature: 15 ̊C to 35 ̊C
Relative humidity: 45% to 85% ;
Air Pressure: 86kPa to 106kPa
If there is any doubt about the results, measurement shall be made within the following conditions:
Ambient temperature: 20 ̊C ± 2 ̊C
Relative humidity: 60% to 70%
As to the detailed information, please refer to following Table
Operating Temperature Range
The ambient temperature range at which the capacitor can be operated continuously at rated voltage is
-55 ̊C to 105 ̊C.
As to the detailed information, please refer to table 1
6/22/2023
5
PART CODE:
UT226M100HFKTA
Table 1
ITEM
Nominal Capacitance
(Tolerance)
PERFORMANCE
Measuring Frequency : 120Hz±12Hz
Measuring Voltage : Not more than 0.5V
Measuring Temperature : 20±2℃
Shall be within the specified capacitance tolerance
Leakage Current
After DC Voltage is applied to capacitors through the series protective resistor
(1kΩ±10Ω) so that terminal voltage may reach the reacted use voltage. The
leakage current when measured in 2 minutes shall not exceed the values of the
following equation.
I (μA) ≤ 0.01 CV or 3 (μA), Whichever is greater
I: Leakage Current (μA)
C: Capacitance (μF)
V: Rated Working Voltage (V)
tanδ
See Normal Capacitance, for measuring frequency, voltage and temperature.
The tangent of the loss angle (Tanδ) of the capacitors shall refer to the following
table. Measurements shall be made under the same conditions as those given
for the measurement of the capacitance.
Rated Woking Voltage (WV)
Surge Voltage (SV)
W.V.
6.3
10
16
25
35
50/63/100
Tanδ
0.30
0.24
0.20
0.18
0.16
0.14
W.V.
(V.DC)
6.3
10
16
25
35
50
63
100
S.V.
(V.DC.)
8
13
44
63
79
125
6/22/2023
6
PART CODE:
UT226M100HFKTA
ITEM
Temperature Characteristic
IEC-60384-4 4.12
PERFORMANCE
Step.
Testing Temperature(℃)
Time
1
20±2
Time to reach thermal equilibrium
2
-55(-25) ±3
3
20±2
4.
105±2
5
20±2
a.
At +105℃, capacitance shall be within ±20% of their origin at +20℃,
measured capacitance, Tanδ shall be within limit of 4.3. The leakage current
value at +105℃ shall not more than 8 times the specified value.
b.
At step 5, Tanδ shall be within the limit of 4.3. The leakage current value
shall not more than the specified value.
c.
At-55℃ (-25℃), impedance (Z) ratio shall not exceed the value of the
following table.
Rated Voltage (V)
d.
Sealing Tape Reel Strength
6.3
10
16
25
35/50/63/100
Z-25℃/
Z+20℃
(120Hz)
<Ф8
4
3
2
2
2
≥Ф8
5
4
3
2
2
Z-55℃/
Z+20℃
(120Hz)
<Ф8
12
8
4
4
3
≥Ф8
8
8
6
4
3
Capacitance Tanδ and impedance shall be measured at 120Hz
Peel angle: 165 to 180℃ referred to the surface on which the tape is glued.
Peel speed: 300mm per minutes
The peel strength must be 0.1 ~ 0.7N under these conditions.
6/22/2023
7
PART CODE:
UT226M100HFKTA
ITEM
Load Life Test
IEC-60384- 4 4.13
PERFORMANCE
The capacitor is stored at a temperature of 105 ℃ ±2 ℃ with rated voltage
applied continuously for 2000+48/0 hours, Then the product should be tested
after 16 hours recovering time at atmospheric conditions. The result should
meet the following table:
The characteristic shall meet the following requirements.
Capacitance Change
±30% of initial measured value.
tanδ
200% or less of the specified value
Leakage current
Not more than the specified value.
Appearance
No leakage of electrolyte or swelling of the case.
All markings shall be legible
Inner construction
No corrosion of tab terminals or electrodes
Remarks: Prior to the measurement of the leakage current, the D.C. rated
voltage shall be applied across the capacitor and its protective resistance (1kΩ)
for 30 mines after which it shall be discharged.
Shelf Life Test
IEC-60384- 4 4.17
The capacitors are then stored with no voltage applied at a temperature of 105
±2℃ for 1000+48/0 hours. Following this period the capacitors shall be removed
from the test chamber and be allowed to stabilized at room temperature for 4~8
hours. Next they shall be connected to a series limiting resistor(1k±100Ω) with
D.C. rated voltage applied for 30min. After which the capacitors shall be
discharged, and then, tested the characteristics.
Capacitance Change
tanδ
Leakage current
Not more than 300% of the specified value
Appearance
Inner construction
Remark:
If the capacitors are stored more than 1 year, the leakage current may increase.
6/22/2023
Please apply voltage through about 1 Kω resistor, if necessary.
8
PART CODE:
UT226M100HFKTA
ITEM
Surge Test
IEC-60384- 4 4.9
PERFORMANCE
Test temperature:15~35℃
Series resistor: R=
R: protective resistor (KΩ)
C: nominal capacitance (μF) Test voltage: Surge voltage item 4.4
No. of cycles: 1000cycles Each cycles lasts for 6±0.5min
“ON” for 30±5 s “OFF” for 5±0.5min.
Capacitance Change
Within±15% of initial value.
tanδ
Leakage current
Appearance
There shall be no leakage of electrolyte.
Attention: This test simulates over voltage at abnormal situation, and not be
hypothesizing that over voltage is always applied.
Vibration Test
IEC-60384- 4 4.8
Fix it at the point 4 mm or less from body. For ones of 12.5 mm or more in
diameter or 25 mm or Capacitance; Direction and during of vibration:3
orthogonal directions mutually each for 2 hours(total of 6 hours)
Vibration frequency range : 10Hz ~ 55Hz
Peak to peak amplitude : 1.5mm
Sweep rate : 10Hz ~ 55Hz ~ 10Hz in about 1 minute
Capacitance Change
Within ±10% of initial value.
tanδ
Leakage current
Appearance
6/22/2023
9
PART CODE:
UT226M100HFKTA
ITEM
Solderability Test
IEC-60384-4 4.6
PERFORMANCE
The capacitor shall be tested under the following conditions: Soldering
temperature : 245±3 ℃
Dipping depth : 2mm
Dipping speed : 25±2.5mm/s
Dipping time : 3±0.5s
Coating quality
Resistance To Solder Heat
Test
A minimum of 95% of the surface being immersed
After reflow soldering . The capacitor shall be left at room temperature for
before measurement.
Damp Heat Test
IEC60384-4 4.12
Capacitance Change
tanδ
Leakage current
Appearance
Humidity Test: According to IEC60384-4 No.4.12 methods, capacitor shall be
exposed for 1000±8 hours in an atmosphere of 90~95% R H .at 60±3℃, the
characteristic change shall meet the following requirement.
Capacitance Change
Within ±20% of initial value.
tanδ
Not more than 120% of the specified value.
Leakage current
Appearance
6/22/2023
10
PART CODE:
UT226M100HFKTA
ITEM
Change Of Temperature Test
IEC-60384-4 4.7
PERFORMANCE
Temperature cycle: According to IEC60384-4 No.4.7 methods, capacitor shall be
placed in an oven, the condition according as below
No.
Temperature
Time
1
+25℃
≤3 Minutes
2
-55℃
30±2 Minutes
3
+25℃
≤3 Minutes
4
+105℃
30±2 Minutes
5
+25℃
≤3 Minutes
1 to 5 = 1 cycle, Total 5 cycles
and then the capacitor shall be subjected to standard atmospheric conditions for
4 hours, after which measurements shall be made.
Low Temperature Test
Capacitance Change
tanδ
Leakage current
Appearance
No broken and undamaged.
Capacitors are placed at -55 ± 3℃ for 96 ± 4 hours. And then the capacitor shall
be subjected to standard atmospheric conditions for 4 hours, after which
Capacitance Change
tanδ
Leakage current
Appearance
6/22/2023
11
PART CODE:
UT226M100HFKTA
ITEM
Vent Test
IEC-60384-4 4.16
PERFORMANCE
The following test only apply to those products with vent products at diameter
≥ Ф8 with vent.
D.C. test
The capacitor is connected with its polarity reversed to a DC power source. Then
a current selected from following table is applied.
Diameter (mm)
DC Current (A)
22.4 or less
1
No emission of gas after 30 minutes of the voltage application also meets the
specification. The vent shall operate with no dangerous conditions such as
flames or dispersion of pieces of the capacitor and/or case.
Mechanical
Characteristics Test
Bending Test: Apply pressure in the direction of the arrow at a rate of about
0.5 mm / s until bent width reaches 2 mm and hold for 60s. The board shall be
the test board “B” as specified in JIS C 0051: 2002. If the land area differs, it shall
be specified clearly in the next item.
Without mechanical damage such as breaks. Electrical characteristics shall be
satisfied. If there are electrodes on both surfaces, above requirements shall be
satisfied on whichever surface it may be fixated on.
6/22/2023
12
PART CODE:
UT226M100HFKTA
CASE SIZE & MAX RIPPLE CURRENT
Rated
Capacitance
Case Size
Dissipation Factor
Ripple Current
Leakage Current
Voltage
(+/-20%)
Ø D*L
@+20°C, 120Hz
@+105°C, 120Hz
@20 °C
V
µF
mm
Tanδ Max.
mA rms .
µA Max.
100
22
8.0*10.2
0.14
100
22
Remark:
1)Specification are subject to change without notice should a safety or technical concern arise regarding the product please be
sure to contact our sales offices;
2)The sizes in the above table are all general specifications. If you need other specifications, please contact us.
3) Frequency Coefficient of Allowable Ripple Current:
Frequency
50Hz
120Hz
300Hz
1KHz
≥10KHz
Coefficient
0.70
1.00
1.17
1.36
1.50
WELDING METHODS AND APPLICABILITY
Welding Method
Reflow Soldering
Soldering Iron
Wave Soldering
The feasibility of
OK
OK
No
Temperature °C
Conditions for the use of lead-free reflow soldering:
Time Second
METHODS THE FOLLOWING
Reflow soldering: please follow the temperature condition during welding. If high temperature is used, please
measure and inform the capacitor temperature and reflow soldering condition. The product size is larger and its
rising temperature is slower. It is not necessary to adjust the temperature of the reflow solder in accordance with
the size of the product. For example, the products of 4 and 10 will be installed in the PCB over tin furnace.
6/22/2023
13
PART CODE:
UT226M100HFKTA
Precautions For Soldering Tin:
Related factors of reflow soldering temperature:
Product size: The product size is larger and its temperature rises slowly.
Product installation position: The temperature of PCB center is lower than that of PCB.
Reflow soldering
If possible, avoid reflow soldering twice.
If repeated reflux is unavoidable, measure and inform the first and second reflux temperature,
and the time of reflow soldering.
Please do not 3 times of reflow soldering
Please follow the following conditions when soldering tin soldering:
Soldering iron maximum temperature:350±5℃
Welding time:3+1/-0 sec
TEST METHOD AND PEAK TEMPERATURE PERMISSIBLE RANGE
Part Code
UT226M100HFKTA
100 V
Rated Voltage(V)
Case Size
Preheating
The Duration Of The
Ø D8.0*L10.2mm
Temperature Range (T1~T2)
150~180 ℃
Time (t1) Max.
180 Second
Temperature Range (T3)
230 ℃ Max.
Time (t2) Max.
The Highest Temperature
40 Second
Temperature Range (T4)
Time (t3) Max.
250 ℃
5 Second
Return The Number
≤2 times
Note
1) Please contact us if the condition of use are higher than the
2) When performing 2nd reflow Soldering, please make sure the temperature of capacitor have cooled to :5~35℃
3) If the reflow condition is based on IPC/JEDEC(J-STD-020), please contact us.
6/22/2023
14
PART CODE:
UT226M100HFKTA
ATTENTION FOR OP-CAP SOLDERING
Reflow soldering will reduce the rated electrostatic capacity of the product, and it should be confirmed whether
reflow soldering condition meets the specification of recommended reflow soldering.
Although the actual reflow condition change is still based on the reflow soldering method, please note that the
highest temperature and the electrode terminal at the bottom of the aluminum shell must not exceed the
maximum temperature.
Please note: OP - CAP products during the process of reflow heating temperature should increase to more than
200 ℃. If the reflow condition temperature or duration is greater than the above table, the OP-CAP product will
be damaged. The electrostatic capacity of the product is reduced by about 50%, the leakage current is large (up to
mA), and the outside of the capacitor is damaged.
APPLICATION GUIDELINE
Circuit Design
1) Please make sure the environmental and mounting conditions to which the capacitor will be exposed are
within the conditions specified in catalogue.
2) Operating temperature and applied ripple shall be within specification.
3) Appropriate capacitors which comply with the life requirement of the products should be selected when
designing the circuit.
4) Aluminum electrolytic capacitors are polar. Make sure that no reverse voltage or AC voltage is applied to the
capacitors. Please use bi-polar capacitors for a circuit that can possibly see reversed polarity.
Note: Even bi-polar capacitors cannot be used for AC voltage application.
5) Do not use aluminum electrolytic capacitors in a circuit that requires rapid and very frequent charge/
discharge. In this type of circuit, it is necessary to use a special design capacitor with extended life
characteristics.
6) Do not apply excess voltage.
(1) Please pay attention to that the peak voltage, which is DC voltage overlapped by ripple current, will not
exceed the rated voltage.
(2) In the case where more than 2 aluminum electrolytic capacitors are used in series, please make sure that
applied voltage will be lower than rated voltage and the voltage will be applied to each capacitor equally by
using a balancing resistor in parallel with the capacitor.
7) Aluminum electrolytic capacitors shall not be used under the following environmental conditions:
(1) (a) Capacitors will be exposed to water (including condensation), brine or oil. (b) Ambient conditions that
include toxic gases such as hydrogen sulfide, sulfurous acid, nitrous acid, chlorine, bromine, methyl bromide,
ammonium, etc. (c) Ambient conditions that expose the capacitor to ozone, ultraviolet ray and radiation.
6/22/2023
15
PART CODE:
UT226M100HFKTA
(2) Severe vibration and physical shock conditions that exceed specification.
Vibration test condition: 10-55-10Hz
vibration frequency range : 10~55~10Hz
sweep rate : 10~55~10Hz/minute
sweep method : logarithmic
amplitude or acceleration : 1.5mm (max. acceleration is 10G)
direction of vibration : X, Y, Z direction
testing time: 2 hours per each direction
Shock is not applicable normally.
If a particular condition is required, please contact our sales office.
8) The main chemical solution of the electrolyte and the separator paper used in the capacitors are combustible.
The electrolyte is conductive. When it comes in contact with the PC board, there is a possibility of pattern
corrosion or short circuit between the circuit pattern, which could result in smoking or catching fire. Do not locate
any circuit pattern beneath the capacitor end seal.
9) Do not design a circuit board that the heat generating components are placed near the aluminum electrolytic
capacitor or on the reverse side of PC board, if that just under the capacitor.
10) Electrical characteristics may vary depending on changes in temperature and frequency. Please consider this
variation when you design circuits.
11) When you install more than 2 capacitors in parallel, please consider the balance of current flowing into the
capacitors.
12) While mounting capacitors on double-side PC board, the capacitors should be away from those unnecessary
base plate holes and connection holes.
Mounting
1) Once a capacitor has been assembled in the set and power applied, do not attempt to re-use the capacitor in
other circuits or application.
2) Leakage current of the capacitors that have been stored for more than 2 years may increase. When leakage
current has increased, please perform a voltage treatment using a 1kΩ resistor.
3) Please confirm specifications and polarity before installing capacitors on the PC board.
4) Do not drop capacitors on the floor, nor use a capacitor that was dropped.
5) Do not deform the capacitor during installation.
6) Please pay attention to the mechanical shock to the capacitor by suction nozzle of the automatic insertion
machine or automatic mounter, or by product checker, or by centering mechanism.
6/22/2023
16
PART CODE:
UT226M100HFKTA
Reflow Soldering
1) Please follow “Reflow Soldering Conditions” when use the part.
2) When an infrared heater is used, please pay attention to the extent of heating since the absorption rate of
infrared will vary due to difference in the color and size of the capacitor.
(1) Do not tilt lay down or twist the capacitor body after the capacitor are soldered to the PC board.
(2) Do not carry the PC board by grasping the soldered capacitor.
(3) Please do not allow anything to touch the capacitor after soldering. If PC boards are stored in stack, please
make sure the PC board or other components away from the capacitor.
(4) The capacitors shall not be effected by any radiated heat from the soldered PC board or other components
after soldering.
(5) Cleaning:
(a) Do not clean capacitors with halogenated cleaning agent. However, if it is necessary to clean with halogenated
cleaning agent, please contact our sales office.
(b) Recommended cleaning method, Applicable : Any type, any ratings
Cleaning conditions: Total cleaning time shall be within 2 minutes by immersion, ultrasonic or other methods.
Temperature of the cleaning agents shall be 40℃ or below. After cleaning, capacitors should be dried by using hot
air for the minimum 10 minutes along with the PC board mounted. Hot air temperature should be within the
maximum operating temperature of the capacitor. Insufficient dryness after water rinse may cause appearance
problems, such as bottom-plate bulge and etc.; Avoid using ozone destructive substances as cleaning agents for
protecting global environment.
In The PCB After Mounted
1) Do not directly touch terminal by hand.
2) Do not link positive terminal and negative terminal by conductor, nor spill conductible liquid such as alkaline or
acidic solution on or near the capacitor.
3) Please make sure that the ambient conditions where the set is installed are free from spilling water or oil, direct
sunlight, ultraviolet rays, radiation, poisonous gases, vibration or mechanical shock.
6/22/2023
17
PART CODE:
UT226M100HFKTA
Maintenance and Inspection
Please periodically inspect the aluminum capacitors that are installed in industrial equipment. The following items
should be checked:
Appearance: remarkable abnormality such as pressure relief vent opening, electrolyte leaking, etc.
Electrical characteristics: capacitance, dielectric loss tangent, leakage current and etc., which are specified in
catalogue or alternate product specification.
In an Emergency
1) If you see smoke due to operation of safety vent, please turn off the main switch or pull out the plug from the
outlet.
2) If you breathe the gas or ingest the electrolyte, please wash out your mouth and throat with water immediately.
3) If your skin is exposed to the electrolyte, please wash it away using soap and water.
Storage
1) Do not keep capacitor in high temperature and high humidity atmosphere.Storage conditions should be:
Temperature: 5℃~35℃
Humidity : lower than 75%
Place : Indoor
2) Avoid ambient conditions where capacitors are covered with water, brine or oil.
3) Avoid ambient conditions where capacitors are exposed to ozone, ultraviolet ray or radiation.
Disposal
Please take either of the following methods in disposing capacitors.
1) Incinerate them after crushing capacitors or making a hole on the capacitor body.
2) If incineration is not applicable, hand them over to a waste disposal agent and have them buried in landfills.
6/22/2023
18
PART CODE:
UT226M100HFKTA
TAPE (Unit: mm), 500pcs/Reel,
Applicable standard JIS C0806 and IEC 60286.
REEL (Unit: mm)
Case size:
Ø D8.0*L10.2mm
6/22/2023
Symbol
Dimension
(mm)
W
24.0
P
16.0
F
11.5
A
8.7
B
8.7
T2
11.0
Ø d
1.5
P1
2.0
P2
4.0
t1
0.4
W1
1.75
W2
26.0
+/-0.3
19
PART CODE:
UT226M100HFKTA
PACKING METHOD
Polarity: Anode on the opposite side of the feed hole
The leader length of the tape shall not be less than 400mm including 10 or more embossed sections in which no
parts are contained.
The winding core is provided with an over 40mm long empty section
DISCLAIMER
NextGen Component, Inc. reserves the right to make changes to the product(s) and or information contained herein
without notice. No liability is assumed as a result of their use or application. No rights under any patent accompany
the
sale of any such product(s) or information
6/22/2023
