Designated client product
This product will be discontinued its production in the near term.
And it is provided for customers currently in use only, with a time limit.
It can not be available for your new project. Please select other new or
existing products.
For more information, please contact our sales office in your region.
New Japan Radio Co.,Ltd.
www.njr.com
NJM2103
SYSTEM RESET IC
■ GENERAL DESCRIPTION
NJM2103 is supply voltage supervisory IC to detect the abnormal
conditions, such as shut down of all supply voltages at once, or sudden
voltage down and then generate the reset signal. It supervises both 5V
supply voltage and the voltage optionally set up.
■ PACKAGE OUTLINE
NJM2103D
■ FEATURES
● Precise Detection of Supply Voltage Down
● Possible Detection of Optional Voltage Down
● Possible Detection of Optional Over-loading
● Low Operating Current
● Reference Voltage can be taken out.
● Low Reset Validated Voltage
● Voltage Detection with Hystersis Feature
● Package Outline
● Bipolar Technology
NJM2103M
(VSA=4.2V±2.5%)
(VSB=1.22V±1.5%)
(ICC≦560µA@VSB=5V)
(V+=0.8V Typ.)
NJM2103L
DIP8, DMP8, SIP8
■ PIN CONFIGURATION
PIN FUNCTION
1. CT
2. VSC
3. OUTC
4. GND
5. V+
6. VSB/ RESIN
7. VSA
8. RESET
NJM2103L
NJM2103D
NJM2103M
■ BLOCK DIAGRAM
V
5
100kΩ
1.235V
7
40kΩ
VSA
VSB / RESIN
6
10µA
Comp.A
1.235V
Reference Voltage
6µA
2
VSC
4
GND
Comp.C
Comp.B
R
Q
S
1
CT
Ver.2012-07-09
8
3
RESET OUTC
-1-
NJM2103
(Ta=25°C)
■ ABSOLUTE MAXIMUM RATINGS
SYMBOL
RATINGS
UNIT
Supply Voltage
PARAMETER
V+
V
Power Dissipation
PD
Input Voltage A
VSA
V++0.3 (13.5V)
⎛ R ⎞
Detecting Voltage ≒ ⎜⎜1 + 4 ⎟⎟ ×VSB
⎝ R5 ⎠
R ⎞
Constant Voltage Output VS ≒ ⎜⎜1 + 1 ⎟⎟ ×VSC
⎝ R2 ⎠
4) Compulsry Reset
Input Reset signal TTL level to VSB - terminal
⎧V (High Level )
RESET Output ≒ ⎨ S
⎩OV (Low Level)
Ver.2012-07-09
-5-
NJM2103
5) 5V, VCC
很抱歉,暂时无法提供与“NJM2103L”相匹配的价格&库存,您可以联系我们找货
