NJM2121M-TE1
NJM2121M-TE1
    NJR(新日本无线)
    IC OP AMP BIPO HS W/SWITCH 8DMP
NJM2121M-TE1 数据手册
Designated client product This product will be discontinued its production in the near term. And it is provided for customers currently in use only, with a time limit. It can not be available for your new project. Please select other new or existing products. For more information, please contact our sales office in your region. New Japan Radio Co.,Ltd. www.njr.com NJM2121 HIGH SPEED OPERATIONAL AMPLIFIER WITH SWITCH ■ GENERAL DESCRIPTION The NJM2121 is a dual operational amplifier of 2-INPUT and 1-OUTPUT with analog switch. The NJM2121 can be used as analog switch under the condition of GV=0dB, as Switch + Amp in order that each gain (A or B) can be adjusted independently. Each amplifier of the NJM2121 has the same electrical characteristics as the NJM4560. The NJM2121 is suitable for Audio, Video, Electrical musical instrument…etc. ■ FEATURES ● Analog Switch Function ● Operating Voltage ● Slew Rate ● Wide Unity Gain Bandwidth ● Package Outline ● Bipolar Technology ■ PACKAGE OUTLINE NJM2121D NJM2121M ( ±3V~±18V ) ( 4V/µs typ. ) ( 14MHz typ. ) DIP8,DMP8 ■ PIN CONFIGURATION Top View PIN FUNCTION 1.SW.CONTROL 2.A +INPUT 3.A -INPUT 4.V5.OUTPUT 6.B –INPUT 7.B +INPUT + 8.V ■ EQUIVALENT CIRCUIT Ver.2011-03-16 -1- NJM2121 ■ ABSOLUTE MAXIMUM RATINGS ( Ta=25˚C ) PARAMETER Supply Voltage Differential Input Voltage Input Voltage Output Current SYMBOL V+/VVID VIC IO Power Dissipation PD Operating Temperature Range Storage Temperature Range Topr Tstg RATINGS ± 18 ( 36 ) ± 30 ± 15 ± 50 ( DIP8 ) 500 ( DMP8 ) 300 -20~+75 -40~+125 UNIT V V V mA mW ˚C ˚C ■ ELECTRICAL CHARACTERISTICS ( V+/V-=±15V,Ta=25˚C ) PARAMETER Operating Current Input Offset Voltage Input Bias Current Large Signal Voltage Gain Maximum Output Voltage Swing Total Harmonic Distortion Supply Voltage Rejection Ratio Channel Separation Unity Gain Bandwidth Slew Rate Equivalent Input Noise Voltage SYMBOL ICC VIO IB AV VOM THD SVR CS fT SR VNI TEST CONDITION SW ON SW OFF RS=10kΩ VIN RL=2kΩ RL≥10kΩ f=1kHz,VO=5Vrms,GV=20dB f=1kHz GV=0dB GV=0dB,RL=2kΩ//100pF RS=1kΩ,BW=10Hz~30kHz,Flat MIN. ± 12 - TYP. 2.3 2.1 0.8 0.2 110 ± 14 0.002 20 82 14 4 2.0 MAX. 6.0 6.0 6.0 1.0 150 - UNIT mA mA mV µA dB V % µV/V dB MHz V/µs µVrms ■ TEST CIRCUIT -2- Ver.2011-03-16 NJM2121 ■ TYPICAL CHARACTERISTICS Ver.2011-03-16 -3- NJM2121 ■ APPLICATION CIRCUIT -4- Ver.2011-03-16 NJM2121 ( 1 ) GV=10dB FLAT Amp+Analog Switch Circuit ( 2 ) Analog Switch Circuit ( GV=0dB Voltage Follower Amp ) ■ SWITCHING MECHANISM Ver.2011-03-16 -5- NJM2121 Switching Mechanism of NJM2121 is as follows. Switch signal is communicated in case that VF of Q26 goes ON on current mirror which is composed with Q26 and Q27.Q10 goes ON by 4diodes of Q10 in case that terminal 1 goes OFF and Amp ( ch A ) goes active.Q9 goes ON by 6 diodes of Q9 in case that terminal 1 goes ON and Amp ( ch B ) goes active.So,NJM2121 have merit that drive system is controlled freely. Because drive system is not related to supply voltage system ( Single supply type/Two supply type ) in order that switch change by current ON/OFF. But, this switch goes ON by very little current because of signal communicate system which depend on ON of VF. So, please use NJM2121 under the condition of lowering sensitivity for current ON/OFF by external Pull-up-resistance ( Rp ) -6- Ver.2011-03-16 NJM2121 [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. Ver.2011-03-16 -7-
NJM2121M-TE1 价格&库存
很抱歉,暂时无法提供与“NJM2121M-TE1”相匹配的价格&库存,您可以联系我们找货
