Designated client product
This product will be discontinued its production in the near term.
And it is provided for customers currently in use only, with a time limit.
It can not be available for your new project. Please select other new or
existing products.
For more information, please contact our sales office in your region.
New Japan Radio Co.,Ltd.
www.njr.com
NJM2246
3-INPUT VIDEO SWITCH WITH 6dB AMPLIFIER
■ GENERAL DESCRIPTION
The NJM2246 is three input integrated video switch, which selects one
video signal from three input signals.
It contains 6dB amplifier and its operating supply voltage range is 4.75 to
13V and bandwidth is 5MHz.
Crosstalk is 65dB (at 4.43MHz).
■ FEATURES
● Operating Voltage
4.75 to 13V
● 3 Input-1 Output
● Internal 6dB Amplifier
● Muting Function available
● Internal Clamp Function
● Cross-talk
65dB (at 4.43MHz)
● Wide Frequency Range
5MHz (1VP-P Input)
● Package Outline
DIP8, DMP8, SIP8
● Bipolar Technology
■ PACKAGE OUTLINE
NJM2246D
NJM2246M
NJM2246L
■ APPLICATION
● VCR
AV-TV Video Disc Player
■ PIN CONFIGURATION
NJM2246L
NJM2246D
NJM2246M
■ BLOCK DIAGRAM
■ INPUT CONTROL SIGNAL-OUTPUT SIGNAL
SW1
SW2
OUTPUT SIGNAL
L
L
VIN1
H
L
VIN2
L/H
H
VIN3
(note) : Input clamp voltage is about 2/5 of supply
voltage.
Ver.2016-04-08
-1-
NJM2246
■ ABSOLUTE MAXIMUM RATINGS
PARAMETER
SYMBOL
Supply Voltage
V
Power Dissipation
PD
(Ta = 25°C)
RATINGS
15
UNIT
V
(DIP8) 500
(DMP8) 300
(SIP8) 800
mW
mW
mW
Operating Temperature Range
Topr
-40 to +85
°C
Storage Temperature Range
Tstg
-40 to +125
°C
(V+ = 5V, Ta = 25°C)
■ ELECTRICAL CHARACTERISTICS
PARAMETER
SYMBOL
TEST CONDITION
MIN.
TYP.
MAX.
UNIT
4.75
13.0
V
Recommended Supply Voltage
V
Operating Current
ICC
S1=S2=S3=S4=S5=2
9.5
14.0
21.0
mA
Voltage Gain
GV
Vin=1.0VP-P, 1MHz, Vo/Vi, RL=1kΩ
5.7
6.2
6.7
dB
Frequency Characteristics
Gf
Vin=1.0VP-P, Vo(10MHz) / Vo (1MHz) RL=1kΩ
-1.0
+1.0
dB
Differential Gain
DG
Vin=1.0VP-P, staircase, RL=1kΩ
0.3
Differential Phase
DP
0.3
deg.
Output Offset Voltage
Voff
S1=S2=S3=2, S5=1→2 VO : voltage change
±60
mV
Crosstalk
CT
VIN=1.0VP-P, 4.43MHz, Vo / Vi (note2)
-65
dB
VCH
All inside SW : ON
2.4
V
VCL
All inside SW : OFF
0.8
V
Switch Change Voltage
(note)Unless specified, tested with three mode below.
a) S1=1, S2=S3=S4=S5=2 b) S2=S4=1, S1=S3=S5=2 c) S1=S2=2, S3=S5=1, S4=1 or 2
(note2) Tested by the following.
a) S1=S4=1, S2=S3=2, S5=1 and 2
b) S2=1, S1=S3=S4=2, S5=1 and 2
C) S3=1, S1=S2=S5=2, S4=1 and 2
-2-
Ver.2016-04-08
NJM2246
■ APPLICATION
Oscillation Prevention on light loading conditions Recommended under circuit.
■ TEST CIRCUIT
S5
S4
DC Voltage Each Terminal
Typ. on Test Circuit Ta=25°C
Terminal Name
DC Voltage
Ver.2016-04-08
VIN1
2
5
V
SW1
VIN2
2
5
V
SW2
VIN3
2
5
V
V
VOUT
2
5
V -0.7
GND
-3-
NJM2246
■ EQUIVALENT CIRCUIT
PIN NO.
PIN
FUNCTION
PIN NO.
PIN
FUNCTION
1
VIN1
5
VIN3
(Mute)
2
SW1
6
V
3
VIN2
7
VOUT
4
SW2
8
GND
-4-
INSIDE EQUIVALENT CIRCUIT
Ver.2016-04-08
NJM2246
■ APPLICATION
This IC requires 1MΩ resistance between INPUT and GND pin for clamp type input since the minute current causes
an unstabel pin voltage.
This IC requires 0.1uF capacitor between INPUT and GND, 1MΩ resistance between INPUT and GND for clamp type
input at mute mode.
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
Ver.2016-04-08
-5-
很抱歉,暂时无法提供与“NJM2246M-TE3”相匹配的价格&库存,您可以联系我们找货
