Designated client product
This product will be discontinued its production in the near term.
And it is provided for customers currently in use only, with a time limit.
It can not be available for your new project. Please select other new or
existing products.
For more information, please contact our sales office in your region.
New Japan Radio Co.,Ltd.
www.njr.com
NJM2264
3 - INPUT VIDEO SUPER IMPOSER WITH 75Ω DRIVER
■ GENERAL DESCRIPTION
NJM2264 is 3-input, 1-output video switch with 75Ω driver circuit.
One input is provided with sink chip clamp function, which adjusts the
DC level of video signal. The other two inputs of transistor open base
can make control of luminance signal. This video switch can be
connected to TV monitor directly, as it has 75Ω driver circuit internally.
NJM2264 is a high performance video switch which is operated with
5V supply voltage.
■ FEATURES
● Wide Operating Voltage (4.75V to 13V)
● 3 Input 1-Output
● Internal 75Ω Driver Circuit
● Internal Sink Chip Clamp Function (VIN1)
● Internal Luminance Signal Control Function (VIN2, VIN3)
● Crosstalk 70dB(at 4.43MHz)
● Wide Operating Frequency Range 10MHz (2VP-P input)
● Package Outline DIP8, DMP8, SIP8
● Bipolar Technology
■ PACKAGE OUTLINE
NJM2264D
NJM2264M
NJM2264L
■ APPLICATIONS
● VCR, Video Camera, AV-TV, Video Disc Player.
■ BLOCK DIAGRAM
Ver.2004-02-17
-1-
NJM2264
■ ABSOLUTE MAXIMUM RATINGS
PARAMETER
(Ta=25°C)
SYMBOL
RATINGS
Supply Voltage
V
Power Dissipation
PD
15
UNIT
V
(DIP8)
500
mW
(DMP8)
300
mW
(SIP8)
800
mW
Operating Temperature Range
Topr
-20 to +75
°C
Storage Temperature Range
Tstg
-40 to +125
°C
(V+=5V, Ta=25°C±2°C)
■ ELECTRICAL CHARACTERISTICS
PARAMETERS
SYMBOLS
TEST CONDITIONS
MIN.
TYP.
MAX.
UNIT
4.75
13.0
V
16.5
23.0
mA
Recommended Supply Voltage
V
Operating Current
ICC
S1 = S2 = S3 = S4 = S5 = 2
Voltage Gain
GV
VIN = 2.0VP-P, 100kHz, VO / VI
-0.8
-0.3
+0.2
dB
Frequency Characteristics
Gf
VIN = 2.0VP-P, VO (10MHz) / VO (100kHz)
-1.0
dB
Differential Gain
DG
VIN = 2.0V P-P, Staircase, RL = 150Ω
0.3
Differential Phase
DP
0.3
deg
VI = 2.0V P-P, 4.43MHz
Crosstalk
CT
Switch Change Voltage
VO / VI
-70
dB
VIN2 VIN3 Biased (Note 2)
VCH
Switch High Level Voltage
2.4
V
VCL
Switch Low Level Voltage
0.8
V
Note 1) Unless otherwise specified, tested with the following conditions.
a) S1 = 1, S2 = S3 = S4 = S5 = 2 b) S2 = S4 = 1, S1 = S3 = S5 = 2 c) S3 = S5 = 1, S1 = S2 = 1, S4 = 1 and 2
Note 2) Tested with the following conditions.
a) S1 = S4 = 1, S2 = S3 = 2, S5 = 1 and 2 b) S2 =1, S1 = S3 = S4 = 2, S5 = 1 and 2 c) S3 = 1, S1 = S2 = S5 = 2, S4 = 1 and 2
Note 3) The Clamp Input Voltage of Vin is approximately (2.0×V ) / 5(In case of V = 5V, about 2.0V).
■ SWITCH CONTROL SIGNAL - OUTPUT SIGNAL
SW1
SW2
OUTPUT SIGNAL
L
L
VIN1
H
L
VIN2
L/H
H
VIN3
-2-
Ver.2004-02-17
NJM2264
■ TEST CIRCUIT
■ APPLICATION
Oscillation Prevention on light loading conditions
Recommended under circuit.
Ver.2004-02-17
-3-
NJM2264
■ EQUIVALENT CIRCUIT
PIN NO.
PIN
FUNCTION
1
PIN NO.
PIN
FUNCTION
VIN1
5
VIN3
2
SW1
6
V
3
VIN2
7
VOUT
4
SW2
8
GND
-4-
INSIDE EQUIVALENT CIRCUIT
Ver.2004-02-17
NJM2264
■ APPLICATION
This IC requires 1MΩ resistance between INPUT and GND pin for clamp type input since the minute current causes an
unstable pin voltage.
This IC requires 0.1uF capacitor between INPUT and GND, 1MΩ resistance between INPUT and GND for clamp type
input at mute mode.
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
Ver.2004-02-17
-5-
很抱歉,暂时无法提供与“NJM2264M-TE1”相匹配的价格&库存,您可以联系我们找货
