NJM2286M-TE1
NJM2286M-TE1
    NJR(新日本无线)
    SOIC16
    IC VIDEO SWITCH 2IN/1OUT 16DMP
NJM2286M-TE1 数据手册
NJM2286 2-INPUT 3CHANNEL VIDEO SWITCH ■ GENERAL DESCRIPTION NJM2286 is a switching IC for switching over from one audio or video input signal to another. Internalizing 2 inputs, 1 output, and then each set of 3 can be operated independently. They are a Clamp type", and it can be operated while DC level fixed in position of the video signal. It is a higher efficiency video switch, featuring the operating supply voltage 4.75 to 13.0V, the frequency feature 10MHz, and then the Crosstalk 75dB (at 4.43MHz). ■ FEATURES • 2 Input-1 Output Internalizing 3 Circuits (Clamp type). • Wide Operating Voltage (4.75 to 13.0V) • Crosstalk 75dB (at 4.43MHz) • Wide Bandwidth Frequency Feature 10MHz (2VP-P Input) • Package Outline DIP16, DMP16, SSOP16 • Bipolar Technology ■ PACKAGE OUTLINE NJM2286D NJM2286M NJM2286V ■ APPLICATIONS • VCR, Video Camera, AV-TV, Video Disk Player. ■ BLOCK DIAGRAM NJM2286D NJM2286M Ver.2004-02-17 -1- NJM2286 ■ MAXIMUM RATINGS PARAMETER Supply Voltage (Ta = 25ºC) SYMBOL RATINGS + V 14 (DIP16) (DMP16) UNIT V 700 350 mW mW Power Dissipation PD Operating Temperature Range Topr -40 to +85 ºC Storage Temperature Range Tstg -40 to +125 ºC (V+ = 5V, Ta = 25°C) ■ ELECTRICAL CHARACTERISTICS PARAMETER Operating Current (1) SYMBOL ICC1 MIN. TYP. MAX. UNIT + TEST CONDITION 7.9 11.3 14.7 mA + 9.8 14.1 18.4 mA V = 5V (Note1) Operating Current (2) ICC2 V = 9V (Note1) Voltage Gain GV VI = 100kHz, 2VP-P, VO / VI -0.6 -0.1 +0.4 dB Frequency Gain Differential Gain Differential Phasa Output Offset Voltage Crosstalk Switch Change Over Voltage Switch Change Over Voltage GF DG DP VOS CT VCH VCL VI = 2VP-P, VO (10MHz) / VO (100kHz) VI = 2VP-P, Standard Staircase Signal VI = 2VP-P, Standard Staircase Signal (Note2) VI = 2VP-P, 4.43MHz, VO / VI All inside Switch ON All inside Switch OFF -1.0 -15 2.5 - 0 0.3 0.3 0 -75 - +1.0 +15 1.0 dB % deg mV dB V V (Note1) S1 = S2 = S3 = S4 = S5 = S6 = S7 = 1 (Note2) S1 = S2 = S3 = S4 = S5 = S6 =1, S7= 1→2 Measure the output DC voltage difference -2- Ver.2004-02-17 NJM2286 ■ TEST CIRCUIT PARAMETER S1 S2 S3 S4 S5 S6 S7 S8 ICC1 ICC2 Gv1 Gf1 DG1 DP1 CT 1 CT 2 CT 3 CT 4 CT 5 CT 6 VOS1 VC1 THD 1 1 2 2 2 2 2 1 1 1 1 1 1 1/2 2 1 1 1 1 1 1 1 2 1 1 1 1 1 2/1 1 1 1 1 1 1 1 1 1 2 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 2 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 2 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 2 1 1 1 1 1 1 1 1 1 2 1 2 1 2 1 1/2 VC 1 1 1 1 1 1 1 1 1 2 2 3 3 1 1 1 Ver.2004-02-17 TEST PART + V vo vo VO VC vo -3- NJM2286 ■ TERMINLAL EXPLANATION PIN No. PIN NAME VOLTAGE 16 1 11 14 8 9 IN 1 A IN 1 B IN 2 A IN 2 B IN 3 A IN 3 B [Input] 2 12 7 CTL 1 CTL 2 CTL 3 [Switching] 3 5 6 OUT1 OUT2 OUT3 [Output] 0.8V 13 V+ 5V 15 4 10 GND 1 GND 2 GND 3 -4- INSIDE EQUIVALENT CIRCUIT 1.5V Ver.2004-02-17 NJM2286 ■ TYPICAL CHARACTERISTICS Operating Current 1 vs. Temperature Operating Current vs. Operating Voltage Voltage Gain 1 vs. Temperature Frequency Gain 1 vs. Temperature Differential Gain 1 vs. Temperature Differential Phase 1 vs. Temperature Ver.2004-02-17 -5- NJM2286 ■ TYPICAL CHARACTERISTICS Offset Voltage vs. Temperature Crosstalk 1 vs. Temperature Crosstalk 2 vs. Temperature Crosstalk 3 vs. Temperature Crosstalk 4 vs. Temperature -6- Crosstalk 5 vs. Temperature Ver.2004-02-17 NJM2286 ■ TYPICAL CHARACTERISTICS Crosstalk 6 vs. Temperature Supply Current 2 vs. Temperature Frequency Gain 1 vs. Operating Voltage Ver.2004-02-17 Switch Change Over 1 vs. Temperature Voltage Gain 1 vs. Operating Voltage Differential Gain 1 vs. Operating Voltage -7- NJM2286 ■ TYPICAL CHARACTERISTICS Differential Phase 1 vs. Operating Voltage Offset Voltage 1 vs. Operating Voltage Crosstalk 1 vs. Operating Voltage Crosstalk 2 vs. Operating Voltage Crosstalk 3 vs. Operating Voltage -8- Crosstalk 4 vs. Operating Voltage Ver.2004-02-17 NJM2286 ■ TYPICAL CHARACTERISTICS Crosstalk 5 vs. Operating Voltage Crosstalk 6 vs. Operating Voltage Switch Change Over 1 vs. Operating Voltage Voltage Gain 1 vs. Frequency Feature Differential Gain 3 vs. Load Resistor Differential Phase 3 vs. Load Resistor Ver.2004-02-17 -9- NJM2286 ■ TYPICAL CHARACTERISTICS Differential Gain 3 vs. APL - 10 - Differential Phase 3 vs. APL Ver.2004-02-17 NJM2286 ■ APPLICATION This IC requires 1MΩ resistance between INPUT and GND pin for clamp type input since the minute current causes an unstable pin voltage. This IC requires 0.1µF capacitor between INPUT and GND, 1MΩ resistance between INPUT and GND for clamp type input at mute mode. [CAUTION] The specifications on this databook are only given for information , without any guarantee as regards either mistakes or omissions. The application circuits in this databook are described only to show representative usages of the product and not intended for the guarantee or permission of any right including the industrial rights. Ver.2004-02-17 - 11 -
NJM2286M-TE1 价格&库存
很抱歉,暂时无法提供与“NJM2286M-TE1”相匹配的价格&库存,您可以联系我们找货
