NJM3775
DUAL STEPPER MOTOR DRIVER
■ GENERAL DESCRIPTION
The NJM3775 is a switch-mode (chopper), constantcurrent driver with two channels: one for each winding
of a two-phase stepper motor. NJM3775 is equipped
with a Disable input to simplify half-stepping operation.
The NJM3775 contains a clock oscillator, which is
common for both driver channels, a set of comparators
and flip-flops implementing the switching control, and
two output H-bridges, including recirculation diodes.
Voltage supply requirements are + 5 V for logic and +
10 to + 45 V for the motor. Maximum output current is
750mA per channel.
■ PACKAGE OUTLINE
NJM3775D2
NJM3775E3
NJM3775FM2
■ FEATURES
• Dual chopper driver
• 750 mA continuous output current per channel
• Digital filter on chip eliminates external filtering components
• Packages
DIP22 / PLCC28 / EMP24(batwing)
■ BLOCK DIAGRAM
Phase 1
Dis1 VR1
E1
C1
NJM3775
VCC
V
CC
R
S
Q
M A1
M B1
Logic
V MM1
V MM2
M B2
Logic
M A2
RC
Phase 2
Figure 1. Block diagram
Dis 2 V
R2
C2
S
R
GND
Q
E2
NJM3775
VMM2
19
GND
18
GND
VR1 8
17
VR2
C1 9
16
C2
Phase1 10
15
Dis1 11
14
Dis2
RC 12
13
Vcc
VMM1 5
GND 6
GND 7
NJM
3775E3
Phase2
VMM1 4
19 VMM2
18 GND
GND 5
GND 6
VR1 7
C1 8
Phase 1 9
26 C 2
27 V R2
MA2
NJM
3775D2
MA2 5
25
Phase 2
E2 6
24
Dis 2
M B2 7
23
VCC
22
RC
M B1 8
17 GND
16 V R2
NJM3775FM2
GND 9
21
Dis 1
E1 10
Phase1
M A1 11
19
C1
15 C 2
14 Phase 2
Dis1 10
13 Dis2
RC 11
12 VCC
VR1 18
21
20 MA2
MA1 3
GND 17
MA1 4
1 GND
E2
28 GND
22
21 E 2
GND 16
E1 3
E1 2
GND 15
MB2
GND 14
23
4 VMM2
MB1 2
22 MB2
GND 13
NC
VMM1 12
24
2 GND
MB1 1
NC 1
3 GND
■ PIN CONFIGURATIONS
Figure 2. Pin configurations
■ PIN DESCRIPTION
EMP
DIP
PLCC
Symbol
Description
2
3
4
5
6,7
18,19
1
2
3
4
5, 6,
17, 18
MB1
E1
MA1
VMM1
GND
8
7
[8]
[10]
[11]
[12]
[1-3, 9,
13-17,
28]
[18]
9
8
[19]
C1
10
9
[20]
Phase1
11
10
[21]
Dis1
12
11
[22]
RC
13
14
12
13
[23]
[24]
VCC
Dis2
15
14
[25]
Phase2
16
15
[26]
C2
17
16
[27]
VR2
22
23
19
22
[4]
[5]
[6]
[7]
VMM2
MA2
E2
MB2
Motor output B, channel 1. Motor current flows from MA1 to MB1 when Phase1 is HIGH.
Common emitter, channel 1. This pin connects to a sensing resistor RS to ground.
Motor output A, channel 1. Motor current flows from MA1 to MB1 when Phase1 is HIGH.
Motor supply voltage, channel 1, +10 to +40 V. VMM1 and VMM2 should be connected together.
Ground and negative supply. Note: these pins are used thermally for heat-sinking.
Make sure that all ground pins are soldered onto a suitably large copper ground plane
for efficient heat sinking.
Reference voltage, channel 1. Controls the comparator threshold voltage and hence the output
current.
Comparator input channel 1. This input senses the instantaneous voltage across the sensing
resistor, filtered by the internal digital filter or an optional external RC network.
Controls the direction of motor current at outputs MA1 and MB1. Motor current flows from MA1 to
Disable input for channel 1. When HIGH, all four output transistors are turned off, which results
in a rapidly decreasing output current to zero.
Clock oscillator RC pin. Connect a 12 kohm resistor to VCC and a 4 700 pF capacitor to ground
to obtain the nominal switching frequency of 23.0 kHz and a digital filter blanking time of 1.0µs.
Logic voltage supply, nominally +5 V.
Disable input for channel 2. When HIGH, all four output transistors are turned off, which results
Controls the direction of motor current at outputs MA2 and MB2. Motor current flows from MA2 to
MB2 when Phase2 is HIGH.
Comparator input channel 2. This input senses the instantaneous voltage across the sensing
Reference voltage, channel 2. Controls the comparator threshold voltage and hence the output
current.
Motor supply voltage, channel 2, +10 to +40 V. VMM1 and VMM2 should be connected together.
Motor output A, channel 2. Motor current flows from MA2 to MB2 when Phase2 is HIGH.
Common emitter, channel 2. This pin connects to a sensing resistor RS to ground.
Motor output B, channel 2. Motor current flows from MA2 to MB2 when Phase2 is HIGH.
VR1
NJM3775
■ FUNCTIONAL DESCRIPTION
Each channel of the NJM3775 consists of the following sections: an output H-bridge with four transistors and four
recirculation diodes, capable of driving up to 750 mA continuous current to the motor winding,
a logic section that controls the output transistors, an S-R flip-flop, and a com- parator. The clock-oscillator is
common
to both channels.
Constant current control is achieved by switching the output current to the windings. This is done by sensing the
peak current through the winding via a current-sensing resistor RS, effectively connected in series with the motor
winding. As the current increases, a voltage develops across the sensing resistor, which is fed back to the comparator. At the predetermined level, defined by the voltage at the reference input VR, the comparator resets the flipflop, which turns off the upper output transistor. The turn-off of one channel is independent of the other channel.
The current decreases until the clock oscillator triggers the flip-flops of both channels simultaneously, which turns
on the output transistors again, and the cycle is repeated.
To prevent erroneous switching due to switching transients at turn-on, the
NJM3775 includes a digital filter. The clock oscillator provides a blanking pulse which is used for digital filtering of
the voltage transient across the current sensing resistor during turn-on.
The current paths during turn-on, turn-off and phase shift are shown in figure 3.
V MM
1
2
3
RS
Motor Current
1
2
3
Fast Current Decay
Slow Current Decay
Figure 3. Output stage with current paths
during turn-on, turn-off and phase shift.
Time
NJM3775
■ ABSOLUTE MAXIMUM RATINGS
Parameter
Pin No. (DIP)
Symbol
Min
Max
Unit
Voltage
Logic supply
Motor supply
Logic inputs
Analog inputs
12
4, 19
9, 10, 13, 14
7, 8, 15, 16
VCC
VMM
VI
VA
-0.3
7
45
6
VCC
V
V
V
V
Current
Motor output current
Logic inputs
Analog inputs
1, 3, 20, 22
9, 10, 13, 14
7, 8, 15, 16
IM
II
IA
-850
-10
-10
+850
mA
mA
mA
Temperature
Operating junction temperature
Storage temperature
Tj
Tstg
-40
-55
+150
+150
°C
°C
Power Dissipation (Package Data)
Power dissipation at TGND = +25°C, DIP and PLCC package
Power dissipation at TGND = +125°C, DIP package
Power dissipation at TGND = +125°C, PLCC package
PD
PD
PD
5
2.2
2.6
W
W
W
■ RECOMMENDED OPERATING CONDITIONS
Parameter
Symbol
Logic supply voltage
Output emitter voltage
Rise and fall time logic inputs
Oscillator timing resistor
VCC
VMM
VE
IM
Tj
tr,, tf
RT
Min
Typ
Max
4.75
10
-750
-20
2
5
12
5.25
40
1.0
+750
+125
2
Unit
V
V
V
mA
°C
ms
kohm
| V MA – V MB |
Phase 1
Dis 1 VR1
9
10
7
C1
E1
8
2
t on
NJM3775
VCC
I CC
V
CC
12
R
S
Q
Logic
3
M A1
1
M B1
4
V MM1
19
V MM2
22
M B2
M A2
t
VE ( I M )
td
V
12 kW
RT
t off
50 %
R
I MM
Logic
I RC RC
11
S
R
IM
I OL
Q
t
4 700 pF
VCC
CT
14
Phase 2
II
I IH
I IL
IR
IA
15
5, 6, 17, 18
C2
GND
V
tb
RC
21
E2
IC
IA
VM
V
V
IH
16
Dis 2 V R2
VCH
VI
V
13
VA
VRC
VE
C
V
V MA
V MM
V
IL
R
t
A
RS
1
fs = t + t
on
off
Figure 4. Definition of symbols
D=
ton
ton + t off
Figure 5. Definition of terms
NJM3775
■ ELECTRICAL CHARACTERISTICS
Electrical characteristics over recommended operating conditions, unless otherwise noted. - 20°C ≤ Tj ≤ + 125°C.
Parameter
Symbol
General
Supply current
Supply current
Total power dissipation
ICC
ICC
PD
PD
Thermal shutdown junction temperature
Turn-off delay
td
Logic Inputs
Logic HIGH input voltage
Logic LOW input voltage
Logic HIGH input current
Logic LOW input current
Analog Inputs
Threshold voltage
Input current
|VC1—VC2| mismatch
VIH
VIL
IIH
IIL
VCH
IA
VCdiff
Motor Outputs
Lower transistor saturation voltage
Lower transistor leakage current
Lower diode forward voltage drop
Upper transistor saturation voltage
Upper transistor leakage current
Upper diode forward voltage drop
Chopper Oscillator
Chopping frequency
Digital filter blanking time
Conditions
Note 4.
Dis1= Dis2= HIGH.
VMM= 24 V, IM1= IM2= 500 mA.
Notes 2, 3, 4.
VMM= 24 V, IM1= 700 mA, IM2= 0 mA.
Notes 2, 3, 4.
TA = +25°C, dVC/dt ≥ 50 mV/µs,
IM = 100 mA. Note 3.
VI = 2.4 V
VI = 0.4 V
VR=5 V
VR= 5 V
IM = 500 mA
VMM=41 V,TA = +25°C. Dis1= Dis2= HIGH.
IM = 500 mA
IM = 500 mA.
VMM=41 V,TA = +25°C. Dis1= Dis2= HIGH..
IM = 500 mA.
fs
tb
CT = 4 700 pF, RT = 12 kohm
CT = 4 700 pF. Note 3.
Min
Typ
Max
Unit
55
7
2.0
70
10
2.3
mA
mA
W
1.7
2.0
W
160
1.1
2.0
°C
µs
2.0
-0.2
-0.1
0.6
V
V
µA
mA
480
500
500
1
520
mV
µA
mV
0.4
1.1
1.1
1.1
0.8
100
1.3
1.4
100
1.4
V
µA
V
V
µA
V
21.5
23.0
1.0
24.5
kHz
µs
■ THERMAL CHARACTERISTICS
Parameter
Symbol
Thermal resistance
RthJ-GND
RthJ-A
RthJ-GND
RthJ-A
RthJ-GND
RthJ-A
Conditions
DIP package.
DIP package. Note 2.
PLCC package.
PLCC package. Note 2.
EMP package
EMP package
Min
Typ
Max
Unit
11
40
9
35
13
42
°C/W
°C/W
°C/W
°C/W
°C/W
°C/W
Notes
1. All voltages are with respect to ground. Currents are positive into, negative out of specified terminal.
2. All ground pins soldered onto a 20 cm2 PCB copper area with free air convection, TA = + 25° C.
3. Not covered by final test program.
4. Switching duty cycle D = 30 %, fs = 23.0 kHz.
NJM3775
■ APPLICATIONS INFORMATION
Current control
The regulated output current level to the motor winding is determined by the voltage at the reference input and the
value of the sensing resistor, RS. The peak current through the sensing resistor (and the motor winding) can be
expressed as:
IM,peak = 0.1•VR / RS [A]
With a recommended value of 0.5 ohm for the sensing resistor RS, a 2.5 V reference voltage will produce an output
current of approximately 500 mA. RS should be selected for maximum motor current. Be sure not to exceed the
absolute maximum output current which is 850 mA. Chopping frequency, winding inductance and supply voltage
also affect the current, but to much less extent.
For accurate current regulation,
the sensing resistor should be a 0.5 -1.0 W precision resistor, i. e. less than 1% tolerance and low temperature coefficient.
V MM
+5 V
0.1 µF
0.1µF
12
V
9
4
V
CC
19
V
MM1
MM2
Phase 1
10
Dis1
7
V R1
14
MA1
3
MB1
1
NJM3775
MA2
Phase 2
13
Dis 2
16
RC GND
+5 V 12 kΩ
22
MB2
V R2
11
5, 6,
17, 18
C1
8
E1
2
10 µF
C2
STEPPER
MOTOR
E2
15
21
Pin numbers refer
to DIP package.
4 700 pF
RS
RS
0.47 Ω
0.47 Ω
GND (V MM )
GND (VCC )
Figure 6. Typical stepper motor driver application with NJM3775.
VCC
(+5 V)
V MM
4x
10 kΩ
4.7 µF
0.1 µF
0.1µ F
10 µF
16
Direction
Step
Half/Full
Step
6
7
10
11
8
V
DIR
STEP
HSM
12
CC
P
A1
NJM
3517
7
P
B1
2
14
13
B
9 fl
A
V
9
10
INH
fl
4
GND
16
3
4
V
CC
19
V
MM1
Phase 1
Dis 1
V R1
MM2
MA1
3
MB1
1
NJM3775
MA2
Phase 2
Dis 2
V R2
RC GND
11
12 kΩ
5, 6,
17, 18
MB2
C1
8
E1
2
C2
15
E2
21
4 700 pF
GND (V CC )
RS
RS
1.0 Ω
1.0 Ω
STEPPER
MOTOR
Pin numbers refer
to DIP package.
GND (V MM )
Figure 7. Half stepping system where NJM3517 is used as controller circuit in
order to generate the necessary sequence to the NJM3775.
NJM3775
Current sense filtering
At turn-on a current spike occurs, due to the recovery of the recirculation diodes and the capacitance of the motor
winding. To prevent this spike from reseting the flip-flops through the current sensing comparators, the clock
oscillator generates a blanking pulse at turn-on. The blanking pulse pulse disables the comparators for a short time.
Thereby any voltage transient across the sensing resistor will be ignored during the blanking time.
Choose the blanking pulse time to be longer than the duration of the switching transients by selecting a proper CT
value. The time is calculated as:
tb = 210 • CT [s]
As the CT value may vary from approximately 2 200 pF to 33 000 pF, a blanking time ranging from 0.5 µs to 7 µs is
possible. Nominal value is 4 700 pF, which gives a blanking time of 1.0 µs.
As the filtering action introduces a small delay, the peak value across the sensing resistor, and hence the peak
motor current, will reach a slightly higher level than what is defined by the reference voltage. The filtering delay also
limits the minimum possible output current. As the output will be on for a short time each cycle, equal to the digital
filtering blanking time plus additional internal delays, an amount of current will flow through the winding. Typically this
current is 1-10 % of the maximum output current set by RS.
When optimizing low current performance, the filtering may be done by adding an external low pass filter in series
with the comparator C input. In this case the digital blanking time should be as short as possible. The recommended
filter component values are 1 kohm and 820 pF. Lowering the switching frequency also helps reducing the minimum
output current.
To create an absolute zero current, the Dis input should be HIGH.
Switching frequency
The frequency of the clock oscillator is set by the timing components RT and CT at the RC-pin. As CT sets the digital
filter blanking time, the clock oscillator frequency is adjusted by RT. The value of RT is limited to 2 - 20 kohm. The
frequency is approximately calculated as:
fs = 1 / ( 0.77 • RT • CT)
Nominal component values of 12 kohm and 4 700 pF results in a clock frequency of 23.0 kHz. A lower frequency will
result in higher current ripple, but may improve low level linearity. A higher clock frequency reduces current ripple,
but increases the switching losses in the IC and possibly the iron losses in the motor.
Phase inputs
A logic HIGH on a Phase input gives a current flowing from pin MA into pin MB.
A logic LOW gives a current flow in the opposite direction. A time delay prevents cross conduction in the H-bridge
when changing the Phase input.
Phase 1
Dis 1
Phase 2
Dis 2
Thermal resistance [°C/W]
80
V R1
22-pin
DIP
70
140%
100%
V R2
60
140%
100%
50
I MA1
140%
100%
24-pin
EMP
40
–100%
–140%
30
I MA2
140%
100%
10
15
30
PCB copper foil area [cm 2 ]
35
28-pin
PLCC
PLCC package
DIP package
–100%
–140%
Full step mode
Figure 8. Typical thermal resistance vs. PC Board
copper area and suggested layout.
Half step mode
Figure 9. Stepping modes
Modified half step mode
NJM3775
Dis (Disable) inputs
A logic HIGH on the Dis inputs will turn off all four transistors of the output H-bridge, which results in a rapidly
VR (Reference) inputs
The Vref inputs of the NJM3775 have a voltage divider with a ratio of 1 to 10 to reduce the external reference
voltage to an adequate level. The divider consists of closely matched resistors. Nominal input reference voltage is 5
V.
Interference
Due to the switching operation of NJM3775, noise and transients are generated and might be coupled into adjacent
circuitry. To reduce potential interference there are a few basic rules to follow:
• Use separate ground leads for power ground (the ground connection of RS), the ground leads of NJM3775, and
the ground of external analog and digital circuitry. The grounds should be connected together close to the GND
pins of NJM3775.
• Decouple the supply voltages close to the NJM3775 circuit. Use a ceramic capacitor in parallel with an electrolytic
type for both VCC and VMM. Route the power supply lines close together.
• Do not place sensitive circuits close to the driver. Avoid physical current loops, and place the driver close to both
the motor and the power supply connector. The motor leads could preferably be twisted or shielded.
Motor selection
The NJM3775 is designed for two-phase bipolar stepper motors, i.e. motors that have only one winding per phase.
The chopping principle of the NJM3775 is based on a constant frequency and a varying duty cycle. This scheme
imposes certain restrictions on motor selection. Unstable chopping can occur if the chopping duty cycle exceeds
approximately 50 %. See figure 5 for definitions. To avoid this, it is necessary to choose a motor with a low winding
resistance and inductance, i.e. windings with a few turns.
It is not possible to use a motor that is rated for the same voltage as the actual supply voltage. Only rated current
needs to be considered. Typical motors to be used together with the NJM3775 have a voltage rating of 1 to 6 V,
while the supply voltage usually ranges from 12 to 40 V.
Low inductance, especially in combination with a high supply voltage, enables high stepping rates. However, to
give the same torque capability at low speed, the reduced number of turns in the winding in the low resistive, low
inductive motor must be compensated by a higher current. A compromise has to be made. Choose a motor with the
lowest possible winding resistance and inductance, that still gives the required torque, and use as high supply
voltage as possible, without exceeding the maximum recommended 40 V. Check that the chopping duty cycle does
not exceed 50 % at maximum current.
Heat sinking
NJM3775 is a power IC, packaged in a power DIP,EMP or PLCC package. The ground leads of the package (the
batwing) are thermally connected to the chip. External heatsinking is achieved by soldering the ground leads onto a
copper ground plane on the PCB.
Maximum continuous output current is heavily dependent on the heatsinking and ambient temperature. Consult
figures 8,10 and 11 to determine the necessary heatsink, or to find the maximum output current under varying
conditions.
A copper area of 20 cm2 (approx. 1.8” x 1.8”), copper foil thickness 35 µm on a 1.6 mm epoxy PCB, permits the
circuit to operate at 2 x 450 mA output current, at ambient temperatures up to 85° C.
Thermal shutdown
The circuit is equipped with a thermal shutdown function that turns the outputs off at a chip (junction) temperature
above 160° C. Normal operation is resumed when the temperature has decreased.
Programming
Figure 9 shows the different input and output sequences for full-step, half-step and modified halfstep operations.
NJM3775
Full-step mode.
Both windings are energized at all the time with the same current, IM1 = IM2. To make the motor take one step, the current
direction (and the magnetic field direction) in one phase is reversed. The next step is then taken when the other phase current
reverses. The current changes go through a sequence of four different states which equal four full steps until the initial state is
reached again.
Half-step mode.
In the half-step mode, the current in one winding is brought to zero before a complete current reversal is made.
The motor will then have taken two half steps equalling one full step in rotary movement. The cycle is repeated, but on the other
phase. A total of eight states are sequenced until the initial state is reached again.
Half-step mode can overcome potential resonance problems. Resonances appear as a sudden loss of torque at one or more
distinct stepping rates and must be avoided so as not to loose control of the motor´s shaft position.
One disadvantage with the half-step mode is the reduced torque in the half step positions, in which current flows through one
winding only. The torque in this position is approximately 70 % of the full step position torque.
Modified half-step mode.
The torque variations in half step mode will be elimi-nated if the current is increased about 1.4 times in the halfstep position. A
constant torque will further reduce resonances and mechanical noise, resulting in better performance, life expectancy and
reliability of the mechanical system.
Modifying the current levels must be done by bringing the reference voltage up (or down) from its nominal value correspondingly.
This can be done by using DACs or simple resistor divider networks. The NJM3775 is designed to handle about 1.4 times higher
current in one channel on mode, for example 2 x 500 mA in the full-step position, and 1 x 700 mA in the half-step position.
NJM3775
■ TYPICAL CHARACTERISTICS
PD (W)
VCE Sat (V)
Maximum allowable power dissipation [W]
6
3.0
1.2
5
bie
nt
te
on
o
c
One
re
0.8
0.6
ch
Tw
tu
2
n
an
1.0
pe
ture
pera
tem
els
m
ra
3
1.0
pin
ing
2.0
Batw
Am
4
0.20
0.4
1
han
nel
on
0.2
50
75
100
125
150
Temperature [°C]
0.40
0.60
0.80
PLCC package
DIP package
I M (A)
Figure 10. Power dissipation vs.
motor current.Ta = 25°C.
free air convection.
VCE Sat (V)
1.2
1.0
1.0
1.0
0.8
0.8
0.8
0.6
0.6
0.6
0.4
0.4
0.4
0.2
0.2
0.2
I M (A)
0.60
0.80
0.80
Vd, ud (V)
1.2
0.20
0.60
I M (A)
1.2
Figure 11. Maximum allowable power Figure 12. Typical lower transistor
saturation voltage vs. output current.
dissipation.
Vd, ld (V)
0.40
I M (A)
0.60
0.80
0.40
0.60
0.80
I M (A)
Figure 11. Typical lower diode voltage Figure 12. Typical upper transistor
Figure 13. Typical upper diode
drop vs. recirculating current.
saturation voltage vs. output current. voltage drop vs. recirculating current.
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions.
The application circuits in this databook are
described only to show representative
usages of the product and not intended for
the guarantee or permission of any right
including the industrial rights.
