Designated client product
This product will be discontinued its production in the near term.
And it is provided for customers currently in use only, with a time limit.
It can not be available for your new project. Please select other new or
existing products.
For more information, please contact our sales office in your region.
New Japan Radio Co.,Ltd.
www.njr.com
NJMOP-07
LOW OFFSET VOLTAGE,LOW DRIFT OPERATIONAL AMPLIFIER
■ GENERAL DESCRIPTION
The NJM OP-07 is ultra-low input offset voltage and bias
current, low drift and high gain operational amplifier with
internal frequency compensation.
The NJM OP-07 is suitable for a precision instrumental
amplifier.
■ FEATURES
● Low VIO
● Low IB
● Low Drift
● Wide Operating Voltage
● Package Outline
● Bipolar Technology
■ PACKAGE OUTLINE
NJMOP-07D
( 60μV typ. )
( 1.8nA typ.)
( unnull 0.5μV/˚C typ.)
( null 0.4μV/˚C typ.)
( 0.4μV/Mo typ.)
( ±3V~±22V )
DIP8,DMP8,SOP8 JEDEC 150mil
NJMOP-07M
NJMOP-07E
■ PIN CONFIGURATION
NJMOP-07D
PIN FUNCTION
1. VIO Trim
2. –INPUT
3. +INPUT
4. V
5. NC
6. OUTPUT
7. V
8. VIO Trim
NJMOP-07M
NJMOP-07E
■ EQUIVALENT CIRCUIT
Ver.2014-10-31
-1-
NJMOP-07
■ ABSOLUTE MAXIMUM RATINGS
( Ta=25˚C )
PARAMETER
Supply Voltage
Input Voltage
Differential Input Voltage
SYMBOL
+ V /V
V1
VID
Power Dissipation
PD
Storage Temperature Range
Operating Temperature Range
Output Current
Tstg
Topr
RATINGS
± 22
± 22 ( note1 )
± 30
( DIP8 ) 500( note2 )
( DMP8 ) 300( note2 ) / 430( note3 )
( SOP8 ) 300 ( note2 ) / 640( note3 )
-40~+125
-40~+85
continuous
UNIT
V
V
V
mW
˚C
˚C
( note1 ) For supply voltage less than ±22V. the absolute maximum input voltage is equal to the supply voltage.
( note2) Device itself.
( note3) Mounted on the EIA/JEDEC standard board (76.2×114.3×1.6mm, two layer, FR-4).
■ ELECTRICAL CHARACTERISTICS
( Ta=+25˚C,V+/V-=±15V )
PARAMETER
Input Offset Voltage
Long Term Stability
Input Offset Current
Input Bias Current
Open Loop Output Resistance
Input Resistance
Input Resistance
Input Common Mode Voltage Range
Common Mode Rejection Ratio
Supply Voltage Rejection Ratio
Large Signal Voltage Gain 1
Large Signal Voltage Gain 2
Maximum Output Voltage 1
Maximum Output Voltage 2
Maximum Output Voltage 3
Slew Rate
Unity Gain Bandwidth
Operating Current 1
Operating Current 2
Offset Adjustment Range
Equivalent Input Noise Voltage
Equivalent Input Noise Voltage 1
Equivalent Input Noise Voltage 2
Equivalent Input Noise Voltage 3
Equivalent Input Noise Current
Equivalent Input Noise Current 1
Equivalent Input Noise Current 2
Equivalent Input Noise Current 3
-2-
SYMBOL
VIO
TEST CONDITION
( note4,5 )
IIO
IB
RO
RID
RIC
VICM
CMR
SVR
AV1
AV2
VOM1
VOM2
VOM3
SR
fT
ICC1
ICC2
VNI
en1
en2
en3
INI
in1
in2
in3
VO=0,IO=0
( Differential Mode )
( Common Mode )
VCM=±13V
+ V /V =±3V~±18V
RL≥2kΩ,VO=±10V
+ RL=500Ω,VO=±0.5V,V /V =±3V
RL≥10kΩ
RL>2kΩ
RL>1kΩ
RL≥2kΩ
AVCL=1
+ V /V =±15V
+ V /V =±3V
RP=20kΩ
0.1HZ~10Hz ( note5 )
fO=10Hz ( note5 )
fO=100Hz ( note5 )
fO=1kHz ( note5 )
0.1Hz~10Hz ( note5 )
fO=10Hz ( note5 )
fO=100Hz ( note5 )
fO=1kHz ( note5 )
MIN.
8
± 13
100
90
101.5
100.0
±12
±11.5
TYP.
60
0.4
0.8
± 1.8
60
33
120
±14
120
104
112.0
112.0
±13
±12.8
±12
0.17
0.5
2.7
0.67
±4
0.38
10.5
10.2
9.8
15
0.35
0.15
0.13
MAX.
150
2
6
±7
5.0
1.3
0.65
11.5
35
0.9
0.27
0.18
UNIT
μV
μV/MO
nA
nA
Ω
MΩ
GΩ
V
dB
dB
dB
dB
V
V
V
V/μS
MHz
mA
mA
mV
μVP-P
nV/√Hz
nV/√Hz
nV/√Hz
pAP-P
pA/√Hz
pA√/Hz
pA/√Hz
Ver.2014-10-31
NJMOP-07
( 0˚C≤Ta≤70˚C,V+/V-=±15V )
PARAMETER
Average VIO Drift ( unnull )
Average VIO Drift ( null )
Average IIIO Drift
Input Bias Current
Average IIB Drift
Voltage Gain
SYMBOL
VIO
TEST CONDITION
( note5 )
RP=20kΩ,( note5 )
IIO
( note5 )
IIB
( note5 )
VICM
CMR
SVR
AV
VOM
VCM=±13V
+ V /V =±3V~±18V
RL≥2kΩ,VO=±10V
RL≥2kΩ
MIN.
± 13
97
86
100
± 11
TYP.
85
0.5
0.4
1.6
12
± 2.2
18
± 13.5
120
120
400
± 12.6
MAX.
250
1.8
1.6
8
50
±9
50
UNIT
μV
μV/˚C
μV/˚C
nA
pA/˚C
nA
pA/˚C
V
dB
dB
V/mV
V
( note 4 ) Long Term Stability refers to the average trend line of VIO vs. time over extended periods after the first 30 days of operation.
( note 5 ) According to the evaluation by NJRC, more than 90 of all these products can be guaranteed.
■ OFFSET ADJUSTMENT METHOD
For making low sensitivity of change in the input offset voltage against resistance regulation of potentiometer
( Easy case of offset adjustment )
٭RA,RB Fixed 7.5kΩ,RC adjustable 5.0kΩ
٭RA,RB,RC are metalfilm resisters, RC is more than 10 times winding.
Ver.2014-10-31
-3-
NJMOP-07
■ TYPICAL CHARACTERISTICS
-4-
Ver.2014-10-31
NJMOP-07
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
Ver.2014-10-31
-5-
很抱歉,暂时无法提供与“NJMOP-07E”相匹配的价格&库存,您可以联系我们找货
