SLEEVE BEARING
NE
W
09225SS (92 X 25L)
NMBTC.COM / 248.919.2250
Characteristic Curves
General Specifications
Motor Protection:
In H2O
Auto Restart/Polarity Protection
Insulation Resistance:
.32
10M Ω or over with a DC500V Megger
Speed Curve
80
4,000
Q
Static Pressure
Ps
N
3,000
.24
60
.20
50
.16
40
.12
30
1,500
.08
.04
10
Expected Life
M
2,500
L
K
2,000
500
K
50,000 Hours (L10)
L
M
N
Q
0.8
1.2
1.6
28.25
42.38
56.50
2.0 (m3/min)
70.63
CFM
Air Flow
Material
Outline
11.81
min (300)
Casing : Plastic (Black) UL94V-0
Impeller : Plastic (Black) UL94V-0
Bearing : Sleeve Bearing
Lead Wire : UL1007, AWG26, +Red, -Black, (tach White)
Panel Cut-Outs
.17
(4- 4.3)
.17
(4- 4.3)
3.25
(82.5)
3.53
(89.6)
3.53
(89.6)
INLET SIDE
OUTLET SIDE
3.53
(89.6)
3.53
(89.6)
3.25
(82.5)
3.25
(82.5)
09 )
4. 104
94 )
3. 100
3.25
(82.5)
3.25
(82.5± 0.3)
.17
(4- 4.3)
3.62
(92.0± 0.5)
inch
Units: (mm)
ROTATION
AIR
NAME
PLATE
3.25
(82.5± 0.3)
.98
(25± 0.5)
3.62
(92.0± 0.5)
Specifications
MODEL
Rated
Operating
Voltage
Voltage
Current
Input
(V)
(V)
(A)*1
(W)*1
Speed
Power
Max.
Max. Static
Air Flow
Pressure
Noise
(min-1)*1 CFM*1 (m3/min)*1 in H2O (Pa)*1 (dB)*1
Mass
(g)
09225SS-12K-AT-D0
12
6.0 ~ 13.8
0.07
0.84
2050
33.55
0.95
.09
21.5
22.0
102
09225SS-12L-AT-D0
12
6.0 ~ 13.8
0.09
1.09
2400
39.91
1.13
.12
29.0
25.0
102
09225SS-12M-AT-D0
12
6.0 ~ 13.8
0.14
1.68
2750
45.20
1.28
.15
36.2
29.0
102
09225SS-12N-AT-D0
12
6.0 ~ 13.8
0.16
1.92
3100
51.21
1.45
.18
45.0
32.0
102
09225SS-12Q-AT-D0
12
7.0 ~ 13.8
0.28
3.36
3900
64.98
1.84
.29
73.0
40.0
102
Rotation: Clockwise
Airflow Outlet: Air Out Over Struts
*1: Average Values in Free Air
Note: PWM/Locked Rotor/Tach Available
DC Axial Fans
-10°C ~ +70°C (Operating)
-40°C ~ +70°C (Storage)
(non-condensing environment)
3,500
70
Speed
.28
Dielectric Withstand Voltage: AC 700V 1s
Allowable Ambient Temperature Range:
40°C
P-Q Curve
(Pa)
09225SS (92 X 25L)
NE
W
SLEEVE BEARING
Specifications
MODEL
Rated
Operating
Voltage
Voltage
Current
Input
(V)
(V)
(A)*1
(W)*1
Speed
Power
Max.
Max. Static
Air Flow
Pressure
Noise
Mass
(g)
09225SS-24K-AT-D0
24
15.0 ~ 27.6
0.06
1.44
2050
33.55
0.95
.09
21.5
22.0
102
09225SS-24L-AT-D0
24
15.0 ~ 27.6
0.07
1.68
2400
39.91
1.13
.12
29.0
25.0
102
09225SS-24M-AT-D0
24
15.0 ~ 27.6
0.09
2.16
2750
45.20
1.28
.15
36.2
29.0
102
09225SS-24N-AT-D0
24
15.0 ~ 27.6
0.12
2.88
3100
51.21
1.45
.18
45.0
32.0
102
09225SS-24Q-AT-D0
24
12.0 ~ 27.6
0.14
3.36
3900
64.98
1.84
.29
73.0
40.0
102
Rotation: Clockwise
很抱歉,暂时无法提供与“09225SS-12Q-AT-D0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 90+56.5726990+6.86766
