R41-A739K
R41-A739K
    NMBTECHNOLOGIESCORPORATION
    HSD®,Fakra,四轴 连接器 插头,公引脚 100 欧姆 通孔 焊接
R41-A739K 数据手册
CAM-K23HR HSD Connector 4+0 Vertical Reverse MODEL NAME CAM-K23HR Part Number R41-A739* (See Coding Chart on Pg. 2) Description HSD Connector 4+0 Vertical Reverse Coding Direction Reverse EXTERNAL DIMENSIONS Height (mm) 14.15 Width (mm) 12.0 Depth (mm) 19.9 Outer Contact Length (mm) 2.25 2.3625 PACKING Weight/Unit Reel 3.70g 150 pcs/reel; 450 pcs (3 reels)/Carton ELECTRICAL PERFORMANCE Impedence 100Ω Frequency Return Loss DC to 2 GHz ≥20 dB to 1 GHz; ≥17 dB to 2 GHz H I G H S P E E D DATA C O M M U N I C AT I O N Insertion Loss ≤0.1 dB to 2 GHz Skew ≤5ps Near-end Crosstalk ≤30 dB (1 GHz) Far-end Crosstalk ≤35 dB (1 GHz) Insulation Resistance ≥1x103 M Ω Signal Contact Resistance ≤20 mΩ Outer Contact Resistance ≤20 mΩ Test Voltage 250Vrms Working Voltage 100V rms Power Current Max. DC 5A Signal Current Differential Shielding Effectiveness Max. DC 3A ≥75dB up to 1 GHZ; ≥65dB up to 2 GHZ MECHANICAL PERFORMANCE Mating Cycles Engagement Force ≥25
R41-A739K 价格&库存
很抱歉,暂时无法提供与“R41-A739K”相匹配的价格&库存,您可以联系我们找货
