IL 710-1E
IL 710-1E
    NVECORP
    TSSOP8,MSOP8
    通用 数字隔离器 2500Vrms 1 通道 110Mbps 100kV/µs CMTI 8-TSSOP,8-MSOP(0.118",3.00mm 宽)
IL 710-1E 数据手册
IL710 High Speed Single-Channel Digital Isolators Functional Diagram Features VOE IN1 OUT1 IL710 Truth Table VI L H L H VOE L L H H VO L H Z Z • • • • • • • • • • • • • • • High Speed: 150 Mbps typical (IL710S) 2500 VRMS isolation voltage 100 kV/μs common mode transient immunity No carrier or clock for low EMI emissions and susceptibility 2.7 to 5.5 volt supply range 1.2 mA/channel typical quiescent current 300 ps typical pulse width distortion (IL710S) 100 ps pulse jitter 2 ns channel-to-channel skew 10 ns typical propagation delay 44000 year barrier life Excellent magnetic immunity VDE V 0884 certified; UL 1577 recognized 500 VRMS IS-to-IS intrinsically safe 8-pin MSOP, SOIC, and PDIP packages Applications • • • • • • • • Digital Fieldbus RS-485 and RS-422 Ground loop elimination Peripheral interfaces Serial communication Logic level shifting Equipment covered under IEC 61010-1 Edition 3 5 kVRMS rated IEC 60601-1 medical applications Description NVE’s IL700 family of high-speed digital isolators are CMOS devices manufactured with NVE’s patented* IsoLoop® spintronic Giant Magnetoresistive (GMR) technology. A unique ceramic/polymer composite barrier provides excellent isolation and virtually unlimited barrier life. The symmetric magnetic coupling barrier provides a typical propagation delay of only 10 ns and a pulse width distortion as low as 300 ps (0.3 ns), achieving the best specifications of any isolator. Minimum transient immunity of 100 kV/µs is unsurpassed. The IL710 is ideal for isolating applications such as PROFIBUS, RS-485, and RS-422. The IL710 is available in 8-pin MSOP, SOIC, and PDIP packages. The IL710S is the world’s fastest isolator of its type, with a 150 Mbps typical data rate. Standard and S-Grade parts are specified over a temperature range of −40°C to +100°C. T-Grade parts are specified over a temperature range of −40°C to +125°C. The MSOP V-Series version offers full 2500 VRMS isolation in an ultraminiature package. IsoLoop is a registered trademark of NVE Corporation. *U.S. Patent numbers 5,831,426; 6,300,617 and others. NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 REV. AH (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL710 Absolute Maximum Ratings Parameters Storage Temperature Junction Temperature Ambient Operating Temperature(1) IL710T Supply Voltage Input Voltage Input Voltage Output Voltage Output Current Drive Lead Solder Temperature ESD Symbol TS TJ Min. −55 −55 TA −40 VDD1, VDD2 VI VOE VO IO −0.5 −0.5 −0.5 −0.5 Typ. Max. 150 150 100 125 7 VDD1+0.5 VDD2+0.5 VDD2+0.5 10 260 Units °C °C Max. Units 2 Test Conditions °C V V V V mA °C kV 10 sec. HBM Recommended Operating Conditions Parameters Ambient Operating Temperature IL710 and IL710S IL710T Junction Temperature IL710 and IL710S IL710T Supply Voltage Logic High Input Voltage Logic Low Input Voltage Input Signal Rise and Fall Times Symbol Min. TA −40 −40 100 125 °C °C TJ −40 −40 2.7 2.4 0 110 125 5.5 VDD1 0.8 1 °C °C V V V μs VDD1, VDD2 VIH VIL tIR, tIF Typ. Test Conditions 2 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL710 Safety and Approvals VDE V 0884-10 (VDE V 0884-11 pending) Basic Isolation; VDE File Number 5016933-4880-0001 • Isolation voltage (VISO): 2500 VRMS • Transient overvoltage (VIOTM): 4000 VPK • Surge rating: 4000 VPK • Each part tested at 1590 VPK for 1 second, 5 pC partial discharge limit. • Samples tested at 4000 VPK for 60 sec.; then 1358 VPK for 10 sec. with 5 pC partial discharge limit. • Working Voltage (VIORM; pollution degree 2): Package MSOP8 PDIP8 SOIC8 Part No. Suffix -1 -2 -3 Working Voltage 399 VRMS 1000 VRMS 1000 VRMS Safety-Limiting Values Safety rating ambient temperature Safety rating power (180 °C) Supply current safety rating (total of supplies) Symbol TS PS IS Value 180 270 54 Units °C mW mA UL 1577 (Component Recognition Program File Number E207481) • 2500 V rating for all types other than MSOP. • Each part other than MSOP tested at 3000 VRMS (4240 VPK) for 1 second; each lot sample tested at 2500 VRMS (3530 VPK) for 1 minute. • MSOP rating 1000 V; tested at 1200 VRMS (1768 VPK) for 1 second; each lot sample tested at 1500 VRMS (2121 VPK) for 1 minute. ATEC / IEC 60079-0 / 60079-11 (Intrinsic Safety under Explosive Atmosphere Standards) • IS-to-IS Certification pending • 500 VRMS rating Soldering Profile Per JEDEC J-STD-020C, MSL 1 IL710 Pin Connections 1 2 3 4 5 6 VDD1 IN NC GND1 GND2 OUT 7 VOE 8 VDD2 Supply voltage Data In No internal connection Ground return for VDD1 Ground return for VDD2 Data Out Output enable. Internally held low with 100 kΩ Supply voltage VDD1 VDD2 IN VOE NC OUT GND2 GND1 IL710 Timing Diagram Legend tPLH tPHL tPW tPLZ tPZH tPHZ tPZL tR tF Propagation Delay, Low to High Propagation Delay, High to Low Minimum Pulse Width Propagation Delay, Low to High Impedance Propagation Delay, High Impedance to High Propagation Delay, High to High Impedance Propagation Delay, High Impedance to Low Rise Time Fall Time 3 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL710 Parameters Input Quiescent Supply Current Output Quiescent Supply Current Logic Input Current Logic High Output Voltage Logic Low Output Voltage 3.3 Volt Electrical Specifications (Tmin to Tmax unless otherwise stated) Symbol Min. Typ. Max. Units IDD1 8 10 µA IDD2 1.2 1.75 mA II −10 10 μA −0.1 V V DD DD V VOH 0.8 x VDD 0.9 x VDD 0 0.1 VOL V 0.5 0.8 Test Conditions IO = −20 μA, VI = VIH IO = −4 mA, VI = VIH IO = 20 μA, VI = VIL IO = 4 mA, VI = VIL Switching Specifications (VDD = 3.3 V) Maximum Data Rate IL710, IL710T, and IL710V IL710S Pulse Width(7) Propagation Delay Input to Output (High to Low) Propagation Delay Input to Output (Low to High) Propagation Delay Enable to Output (High to High Impedance) Propagation Delay Enable to Output (Low to High Impedance) Propagation Delay Enable to Output (High Impedance to High) Propagation Delay Enable to Output (High Impedance to Low) Pulse Width Distortion(2) IL710, IL710T, and IL710V IL710S Pulse Jitter(10) Propagation Delay difference between any two parts(3) Output Rise Time (10%–90%) Output Fall Time (10%–90%) Common Mode Transient Immunity (Output Logic High or Logic Low)(4) Dynamic Power Consumption(6) ) Output side Input side PW 100 130 10 110 140 7.5 Mbps Mbps ns CL = 15 pF CL = 15 pF 50% Points, VO tPHL 12 18 ns CL = 15 pF tPLH 12 18 ns CL = 15 pF tPHZ 3 5 ns CL = 15 pF tPLZ 3 5 ns CL = 15 pF tPZH 3 5 ns CL = 15 pF tPZL 3 5 ns CL = 15 pF PWD 3 3 ns CL = 15 pF tJ 2 1 100 ps CL = 15 pF tPSK 4 6 ns CL = 15 pF tR tF 2 2 4 4 ns ns CL = 15 pF CL = 15 pF |CMH|,|CML| 100 150 140 20 kV/μs 240 40 Per IEC 60747 μA/Mbps/ch Magnetic Field Immunity(8) (VDD2 = 3 V, 3 V < VDD1 < 5.5 V) Power Frequency Magnetic Immunity HPF 1500 Pulse Magnetic Field Immunity HPM 2000 Damped Oscillatory Magnetic Field HOSC 2000 Cross-axis Immunity Multiplier(9) KX 2.5 A/m A/m A/m 50Hz/60Hz tp = 8µs 0.1Hz – 1MHz 4 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL710 Parameters Input Quiescent Supply Current Output Quiescent Supply Current Logic Input Current Logic High Output Voltage Logic Low Output Voltage 5 Volt Electrical Specifications (Tmin to Tmax unless otherwise stated) Symbol Min. Typ. Max. Units IDD1 10 15 μA IDD2 1.8 2.5 mA II −10 10 μA V −0.1 V DD DD VOH V 0.8 x VDD 0.9 x VDD 0 0.1 VOL V 0.5 0.8 Test Conditions IO = −20 μA, VI = VIH IO = −4 mA, VI = VIH IO = 20 µA, VI = VIL IO = 4 mA, VI = VIL Switching Specifications (VDD = 5 V) Maximum Data Rate IL710, IL710T, and IL710V IL710S Pulse Width(7) Propagation Delay Input to Output (High to Low) Propagation Delay Input to Output (Low to High) Propagation Delay Enable to Output (High to High Impedance) Propagation Delay Enable to Output (Low to High Impedance) Propagation Delay Enable to Output (High Impedance to High) Propagation Delay Enable to Output (High Impedance to Low) Pulse Width Distortion(2) IL710, IL710T, and IL710V IL710S Propagation Delay difference between any two parts(3) Output Rise Time (10%–90%) Output Fall Time (10%–90%) Common Mode Transient Immunity (Output Logic High or Logic Low)(4) Dynamic Power Consumption(6) ) Output side Input side Power Frequency Magnetic Immunity Pulse Magnetic Field Immunity Damped Oscillatory Magnetic Field Cross-axis Immunity Multiplier(9) PW 100 130 10 110 150 7.5 Mbps Mbps ns CL = 15 pF CL = 15 pF 50% Points, VO tPHL 10 15 ns CL = 15 pF tPLH 10 15 ns CL = 15 pF tPHZ 3 5 ns CL = 15 pF tPLZ 3 5 ns CL = 15 pF tPZH 3 5 ns CL = 15 pF tPZL 3 5 ns CL = 15 pF PWD 2 0.3 3 3 ns CL = 15 pF tPSK 4 6 ns CL = 15 pF tR tF 1 1 3 3 ns ns CL = 15 pF CL = 15 pF |CMH|,|CML| 100 150 200 30 kV/μs 340 50 Per IEC 60747 μA/Mbps/ch Magnetic Field Immunity(8) (VDD2= 5 V, 3 V < VDD1< 5.5 V) HPF 3500 HPM 4500 HOSC 4500 KX 2.5 A/m A/m A/m 50Hz/60Hz tp = 8µs 0.1Hz – 1MHz 5 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL710 Insulation Specifications Parameters Creepage Distance (external) MSOP SOIC PDIP Total Barrier Thickness (internal) Leakage Current(5) Barrier Resistance(5) Barrier Capacitance(5) Comparative Tracking Index High Voltage Endurance AC (Maximum Barrier Voltage for Indefinite Life) DC Symbol Min. Typ. 3.01 4.04 6.8 0.012 RIO CIO CTI Max. Units ≥175 1000 mm mm mm mm μA Ω pF V VRMS 1500 VDC 0.013 0.2 >1014 1.1 VIO Barrier Life 44000 Test Conditions 240 VRMS, 60 Hz 500 V f = 1 MHz Per IEC 60112 At maximum operating temperature Years 100°C, 1000 VRMS, 60% CL activation energy Units Test Conditions Thermal Characteristics Parameter Symbol Junction–Ambient Thermal Resistance Junction–Case (Top) Thermal Resistance Power Dissipation MSOP SOIC PDIP MSOP SOIC PDIP MSOP SOIC PDIP Min. Typ. 184 134 114 15 10 36 θJA θJC Max. °C/W Double-sided PCB in free air °C/W 500 675 800 PD mW Notes (apply to both 3.3 V and 5 V specifications): 1. Absolute maximum ambient operating temperature means the device will not be damaged if operated under these conditions. It does not guarantee performance. 2. PWD is defined as |tPHL − tPLH|. %PWD is equal to PWD divided by pulse width. 3. tPSK is the magnitude of the worst-case difference in tPHL and/or tPLH between devices at 25°C. 4. CMH and CML are the maximum common mode voltage slew rates that can be applied with the outputs remaining stable and within VOL and VOH specifications. 5. Device is considered a two terminal device: pins 1–4 shorted and pins 5–8 shorted. 6. Dynamic power consumption is calculated per channel. 7. Minimum pulse width is the minimum value at which specified PWD is guaranteed. 8. The relevant test and measurement methods are given in the Electromagnetic Compatibility section on p. 7. 9. External magnetic field immunity is improved by this factor if the field direction is “end-to-end” rather than to “pin-to-pin” (see diagram on p. 7). 10. 66,535-bit pseudo-random binary signal (PRBS) NRZ bit pattern with no more than five consecutive 1s or 0s; 800 ps transition time. 6 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL710 Typical Performance Graphs 35 30 V DD I DD2 (mA) 25 20 V DD V =5 =3 .3 V 15 10 5 0 0 25 50 75 100 Operating Speed (Mbps) 125 150 Figure 1. Supply current vs. operating speed. 1 3 V DD - V OH 0.8 V DD = 3. V V DD =5 V 0.6 0.4 0.2 0 0 5 10 15 I OH (mA) 20 25 Figure 2. Typical high output voltage vs. load. 1 V DD 0.8 .3 =3 V DD V =5 V V OL 0.6 0.4 0.2 0 0 5 10 15 I OH (mA) 20 25 Figure 3. Typical low output voltage vs. load 7 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL710 Application Information Dynamic Power Consumption An equivalent circuit is shown below: IsoLoop Isolators achieve their low power consumption from the way they transmit data across the isolation barrier. By detecting the edge transitions of the input logic signal and converting these to narrow current pulses, a magnetic field is created around the GMR Wheatstone bridge. Depending on the direction of the magnetic field, the bridge causes the output comparator to switch following the input logic signal. Since the current pulses are narrow, about 2.5 ns, the power consumption is independent of mark-to-space ratio and solely dependent on frequency. This has obvious advantages over optocouplers, which have power consumption heavily dependent on mark-to-space ratio. Data In Isolation Barrier Isolator Operation Data Out Field Isolator Signal Path The GMR isolator signal path starts with a buffered input signal that is driven through an ultraminiature coil. This generates a small magnetic field that changes the electron spin polarization of GMR resistors, which are configured as a Wheatstone bridge. The change in spin polarization of the resistors creates a bridge voltage which drives an output comparator to construct an isolated version of the input signal. Power Supply Decoupling Both power supplies should be decoupled with 0.1 µF typical (0.047 µF minimum) capacitors as close as possible to the VDD pins. Ground planes for both GND1 and GND2 are highly recommended for data rates above 10 Mbps. Small Size, High Speed, and Low EMI The coil, GMR, and circuitry are integrated to allow small packages. GMR is inherently high speed and low distortion, and unlike transformers, does not rely on energy transfer, so power is low and EMI emissions are minimal. Signal Status on Start-Up and Shut Down To minimize power dissipation, input signals are differentiated and then latched on the output side of the isolation barrier to reconstruct the signal. This could result in an ambiguous output state depending on power up, shutdown and power loss sequencing. Therefore, the designer should consider including an initialization signal in the start-up circuit. Initialization consists of toggling the input either high then low, or low then high. High Magnetic Immunity GMR provides large signals which improve magnetic immunity, and the Wheatstone bridge configuration cancels ambient commonmode magnetic fields, further enhancing immunity to external magnetic fields. Data Transmission Rates The reliability of a transmission system is directly related to the accuracy and quality of the transmitted digital information. For a digital system, those parameters which determine the limits of the data transmission are pulse width distortion and propagation delay skew. Electrostatic Discharge Sensitivity This product has been tested for electrostatic sensitivity to the limits stated in the specifications. However, NVE recommends that all integrated circuits be handled with appropriate care to avoid damage. Damage caused by inappropriate handling or storage could range from performance degradation to complete failure. Propagation delay is the time taken for the signal to travel through the device. This is usually different when sending a low-to-high than when sending a high-to-low signal. This difference, or error, is called pulse width distortion (PWD) and is usually in nanoseconds. It may also be expressed as a percentage: Electromagnetic Compatibility IsoLoop Isolators have the lowest EMC footprint of any isolation technology. IsoLoop Isolators’ Wheatstone bridge configuration and differential magnetic field signaling ensure excellent EMC performance against all relevant standards. These isolators are fully compliant with IEC 61000-6-1 and IEC 61000-6-2 standards for immunity, and IEC 61000-6-3, IEC 61000-6-4, CISPR, and FCC Class A standards for emissions. PWD% = Maximum Pulse Width Distortion (ns) Signal Pulse Width (ns) x 100% For example, with data rates of 12.5 Mbps: PWD% = 3 ns x 100% = 3.75% 80 ns This figure is almost three times better than any available optocoupler with the same temperature range, and two times better than any optocoupler regardless of published temperature range. IsoLoop isolators exceed the 10% maximum PWD recommended by PROFIBUS, and will run to nearly 35 Mb within the 10% limit. Immunity to external magnetic fields is even higher if the field direction is “end-to-end” rather than to “pin-to-pin” as shown in the diagram below: Propagation delay skew is the signal propagation difference between two or more channels. This becomes significant in clocked systems because it is undesirable for the clock pulse to arrive before the data has settled. Short propagation delay skew is therefore especially critical in high data rate parallel systems for establishing and maintaining accuracy and repeatability. Worstcase channel-to-channel skew in an IL700 Isolator is only 3 ns, which is ten times better than any optocoupler. IL700 Isolators have a maximum propagation delay skew of 6 ns, which is five times better than any optocoupler. Cross-axis Field Direction 8 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL710 Application Diagrams Isolated PROFIBUS / RS-485 NVE offers a unique line of single-chip isolated PROFIBUS/RS-485 transceivers, but as this circuit illustrates, IL710 isolators can also be used as part of multi-chip designs using non-isolated PROFIBUS transceivers: Isolation Boundary RS-485 Truth Table TXD RTS 1 0 0 0 1 1 0 1 IL710 A Z Z 1 0 B Z Z 0 1 RXD X X 1 0 IL710 Note: VDD1 and VISO should be decoupled with 10 nF ceramic capacitors at IL710 supply pins. ISL8485 IL710 9 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL710 Isolated USB In this circuit, power is supplied by USB bus power on one side of the isolation barrier, and the USB node’s external supply on the other side of the barrier. IL700 Isolators are specified with just 3 ns worst-case pulse width distortion: All power supplied by USB node’s external supply on this side of isolation boundary Isolation Boundary Power supplied by USB bus power this side of isolation boundary +3.3V R1 1.5k USPB NET2890 ISO_USB+ 3 4 USBM ISO_USB- 27 USBOE 5 x IL710 10 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL710 Package Drawings 8-pin MSOP (-1 suffix) Dimensions in inches (mm); scale = approx. 5X 0.114 (2.90) 0.122 (3.10) 0.016 (0.40) 0.027 (0.70) 0.114 (2.90) 0.122 (3.10) 0.189 (4.80) 0.197 (5.00) 0.032 (0.80) 0.043 (1.10) 0.024 (0.60) 0.028 (0.70) 0.005 (0.13) 0.009 (0.23) 0.010 (0.25) 0.016 (0.40) 0.002 (0.05) 0.006 (0.15) NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate 8-pin SOIC Package (-3 suffix) Dimensions in inches (mm); scale = approx. 5X 0.188 (4.77) 0.197 (5.00) 0.016 (0.4) 0.050 (1.3) 0.052 (1.32) 0.062 (1.57) 0.054 (1.37) 0.072 (1.83) 0.150 (3.8) 0.157 (4.0) 0.228 (5.8) 0.244 (6.2) 0.004 (0.1) 0.012 (0.3) 0.050 (1.27) NOM NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate 0.007 (0.2) 0.013 (0.3) 0.013 (0.3) 0.020 (0.5) 8-pin PDIP (-2 suffix) Dimensions in inches (mm); scale = approx. 2.5X 0.28 (7.1) 0.33 (8.4) 0.30 (7.6) 0.38 (9.7) 0.24 (6.1) 0.27 (6.9) 0.13 (3.30) 0.17 (4.32) NOTE: Pin spacing is a BASIC dimension; tolerances do not accumulate 0 10 0.345 (8.76) 0.40 (10.2) 0.055 (1.40) 0.065 (1.65) 0.008 (0.2) 0.015 (0.4) 0.015 (0.38) 0.040 (1.02) 0.030 (0.76) 0.045 (1.14) 0.09 (2.3) 0.11 (2.8) 0.045 (1.14) 0.070 (1.78) 0.014 (0.36) 0.023 (0.58) 11 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL710 Recommended Pad Layouts 8-pin MSOP Pad Layout Dimensions in inches (mm); scale = approx. 5X 0.120 (3.05) 0.025 (0.65) 0.017 (0.43) 8 PLCS 0.227 (5.77) 8-pin SOIC Pad Layout Dimensions in inches (mm); scale = approx. 5X 0.160 (4.05) 0.050 (1.27) 0.020 (0.51) 8 PLCS 0.275 (6.99) 12 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL710 Ordering Information and Valid Part Numbers IL 710 T - 3 E TR13 Valid Part Numbers Bulk Packaging Blank = Tube TR7 = 7" Tape and Reel TR13 = 13" Tape and Reel Package Blank = 80/20 Tin/Lead Plating E = RoHS Compliant Package Type -1 = MSOP -2 = PDIP -3 = 0.15" 8-pin SOIC Grade Blank = S = T = V = Standard High Speed High Temperature High Isolation MSOP IL710-1E IL710S-1E IL710T-1E IL710V-1E IL710-2 IL710T-2 IL710-2E IL710T-2E IL710-3 IL710S-3 IL710T-3 IL710-3E IL710S-3E IL710T-3E All MSOP and SOIC parts are available on tape and reel. Base Part Number 710 = Single Channel Product Family IL = Isolators 13 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL710 ISB-DS-001-IL710-AH November 2020 Changes • Upgraded CMTI specifications. • Added ATEC / IEC 60079 Intrinsic Safety pending (p. 3). • Added output-side dynamic power consumption specifications (pp. 5 and 6). • Changed “Propagation Delay Skew” to “Propagation Delay difference between any two parts” for clarity (pp. 5 and 6). ISB-DS-001-IL710-AG Changes • Extended minimum operating power supplies to 2.7 volts. • Updated EMC standards. • Deleted minimum magnetic field immunity specifications since it is not 100% tested. • Changed PDIP creepage specification from 7.04 mm to 6.8 mm (p. 6). • Revised thermal properties (p. 6). • Added Typical Performance Graphs (p. 7). • More detailed description of operation (p. 8). ISB-DS-001-IL710-AF Change • Updated SOIC8 package outline drawing. ISB-DS-001-IL710-AE Change • Updated VDE approvals to VDE V 0884-10. ISB-DS-001-IL710-AD Change • Added MSOP V-Series version (2500 VRMS isolation). ISB-DS-001-IL710-AC Changes • Added product illustrations to first page. • Revised and added details to thermal specifications (p. 2). • Added VDE 0884 Safety-Limiting Values (p. 3). ISB-DS-001-IL710-AB Change • IEC 60747-5-5 (VDE 0884) certification. ISB-DS-001-IL710-AA Changes • Tighter quiescent current specifications. • Upgraded from MSL 2 to MSL 1. ISB-DS-001-IL710-Z Changes • Increased transient immunity specifications based on additional data. • Added VDE 0884 pending. • Added high voltage endurance specification. • Increased magnetic immunity specifications. • Updated package drawings. • Added recommended solder pad layouts. ISB-DS-001-IL710-Y Changes • Detailed isolation and barrier specifications. • Cosmetic changes. ISB-DS-001-IL710-X Changes • Tightened typ. output quiescent supply spec. from 1.7 mA to 1.5 mA. • T-Series quiescent supply specs. tightened to be the same as other grades. 14 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL710 Datasheet Limitations The information and data provided in datasheets shall define the specification of the product as agreed between NVE and its customer, unless NVE and customer have explicitly agreed otherwise in writing. All specifications are based on NVE test protocols. In no event however, shall an agreement be valid in which the NVE product is deemed to offer functions and qualities beyond those described in the datasheet. Limited Warranty and Liability Information in this document is believed to be accurate and reliable. However, NVE does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall NVE be liable for any indirect, incidental, punitive, special or consequential damages (including, without limitation, lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Right to Make Changes NVE reserves the right to make changes to information published in this document including, without limitation, specifications and product descriptions at any time and without notice. This document supersedes and replaces all information supplied prior to its publication. Use in Life-Critical or Safety-Critical Applications Unless NVE and a customer explicitly agree otherwise in writing, NVE products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical devices or equipment. NVE accepts no liability for inclusion or use of NVE products in such applications and such inclusion or use is at the customer’s own risk. Should the customer use NVE products for such application whether authorized by NVE or not, the customer shall indemnify and hold NVE harmless against all claims and damages. Applications Applications described in this datasheet are illustrative only. NVE makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using NVE products, and NVE accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the NVE product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customers. Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. NVE does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customers. The customer is responsible for all necessary testing for the customer’s applications and products using NVE products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customers. NVE accepts no liability in this respect. Limiting Values Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the recommended operating conditions of the datasheet is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and Conditions of Sale In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. NVE hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of NVE products by customer. No Offer to Sell or License Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export Control This document as well as the items described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Automotive Qualified Products Unless the datasheet expressly states that a specific NVE product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. NVE accepts no liability for inclusion or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without NVE’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond NVE’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies NVE for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond NVE’s standard warranty and NVE’s product specifications. 15 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com IL710 An ISO 9001 Certified Company NVE Corporation 11409 Valley View Road Eden Prairie, MN 55344-3617 USA Telephone: (952) 829-9217 www.nve.com e-mail: iso-info@nve.com ©NVE Corporation All rights are reserved. Reproduction in whole or in part is prohibited without the prior written consent of the copyright owner. ISB-DS-001-IL710-AH November 2020 16 NVE Corporation 11409 Valley View Road, Eden Prairie, MN 55344-3617 (952) 829-9217 www.nve.com YouTube.com/NveCorporation iso-apps@nve.com
IL 710-1E 价格&库存
很抱歉,暂时无法提供与“IL 710-1E”相匹配的价格&库存,您可以联系我们找货
