OWMB-505020S-40-12D
OWMB-505020S-40-12D
    OLEWOLFF
    BUZZER-3P_5.5X5MM_SM
    磁性 蜂鸣器 传感器,外部驱动 3 V 100mA 4kHz 80dB @ 3V,10cm 表面贴装型 焊盘
OWMB-505020S-40-12D 数据手册
Date 13-Oct-2021 Page 1/8 CN SPECIFICATION P/N: OWMB-505020S-40-12D OLE WOLFF www.owolff.com Revision: 02 SPECIFICATION FOR APPROVAL SMD Electro-Magnetic Transducer OWMB-505020S-40-12D This item is in compliance with the following requirements : 1. RoHS directive 2. REACH Part Number Note Customer P/N Prepared Checked Approved Signature / Date Ole Wolff Confirmation Signature / Date Customer REVISION NOTES: Date Rev. 01.03.2019 00 Initial Release 24.09.2021 01 Update drawing. 13.10.2021 02 Coding: change year and month to year and week. OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 1525 McCarthy Blvd, Suite 1093 Milpitas, Ca 95035 USA TEL : +1 408 888 8413 Description of Revision OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLE WOLFF ELEKTRONIK Yliopistonkatu 26 (P.O.BOX 257) FI-40101 Jyväskylä Finland TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. TEL: +852 2424 3274 FAX: +852 2424 2219 OLE WOLFF LTD. 5 Floor, Block G, WenTao Industrial Park, YingRenShi, Bao'an District, Shenzhen , PRC TEL: +86 755 82612542 TEL: +86 755 26406156 Date 13-Oct-2021 Page 2/8 CN SPECIFICATION P/N: OWMB-505020S-40-12D OLE WOLFF www.owolff.com Revision: 02 1. SCOPE THIS SPECIFICATION IS APPLIED TO OLE WOLFF SMD ELECTRO-MAGNETIC TRANSDUCER UNIT OF MODEL: OWMB-505020S-40-12D 2. GENERAL REQUIREMENTS OPERATING TEMPERATURE RANGE: -40℃  +105℃ STORAGE TEMPERATUR RANGE: -40℃  +120℃ 3. MECHANICAL LAYOUT & DIMENSIONS DIMENSIONS: SHOWN IN FIGURE 3. WEIGHT:0.12g 4. ELECTRICAL CHARACTERISTICS NO. ITEM SPECIFICATION 1 RATED VOLTAGE 3Vo-p 2 OPERATING VOLTAGE 3 RESONANT FREQUENCY 4000Hz 4 COIL RESISTANCE 12±2Ω 5 *RATED CURRENT ≤100mA 6 * SOUND OUTPUT AT 10cm 7 HOUSING MATERIAL 2~5Vo-p ≥80dB LCP *Applying rated voltage (Resonant frequency, 1/2 duty, Square wave) OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 1525 McCarthy Blvd, Suite 1093 Milpitas, Ca 95035 USA TEL : +1 408 888 8413 OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLE WOLFF ELEKTRONIK Yliopistonkatu 26 (P.O.BOX 257) FI-40101 Jyväskylä Finland TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. TEL: +852 2424 3274 FAX: +852 2424 2219 OLE WOLFF LTD. 5 Floor, Block G, WenTao Industrial Park, YingRenShi, Bao'an District, Shenzhen , PRC TEL: +86 755 82612542 TEL: +86 755 26406156 Date 13-Oct-2021 Page 3/8 CN SPECIFICATION P/N: OWMB-505020S-40-12D OLE WOLFF www.owolff.com Revision: 02 RELIABILTY TEST 5. - After Test All specifications must be satisfied after the test. 5.1 High temperature Test Temperature: +120±2℃ Duration: 120HRS 5.2 Low temperature Test Temperature: -40±2℃ Duration: 120HRS 5.3 Humidity Test Temperature: +40±2℃ Humidity: 90~95%RH Duration: 120HRS 5.4 Temperature cycling Test Temperature: -40±2℃ Duration: 30min Cycle: 5 cycles room temp. 15min +120±2℃ 30min room temp. 15min 5.5 Vibration Test Input power: 10Hz(a period is 1 minute) Amplitude: 1.52mm(9.3g) Duration: 2 hours per plane in each three mutually perpendicular planes for a total time of 6 hours. 5.6 Shock Test Sounder shall be measured after being applied shock (980m/s²) for each three mutually perpendicular directions to each of 3 times by half sine wave. 5.7 Drop Test Dropped naturally from 700mm height onto the surface of 10mm thick wooden board. 2 directions-upper and side of the part are to be applied. 5.8 Lead pull The part shall be pulled/push with a force of 15N for 10±1 seconds behind the part. After the test part shall meet specifications without any degradation in appearance and performance. Warranty:For a period of one year from date of manufacture under normal operations. OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 1525 McCarthy Blvd, Suite 1093 Milpitas, Ca 95035 USA TEL : +1 408 888 8413 OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLE WOLFF ELEKTRONIK Yliopistonkatu 26 (P.O.BOX 257) FI-40101 Jyväskylä Finland TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. TEL: +852 2424 3274 FAX: +852 2424 2219 OLE WOLFF LTD. 5 Floor, Block G, WenTao Industrial Park, YingRenShi, Bao'an District, Shenzhen , PRC TEL: +86 755 82612542 TEL: +86 755 26406156 Date 13-Oct-2021 Page 4/8 CN SPECIFICATION P/N: OWMB-505020S-40-12D OLE WOLFF www.owolff.com Revision: 02 6. TEST METHOD (Figure 1) 7. FREQUENCY RESPONSE (Figure 2) OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 1525 McCarthy Blvd, Suite 1093 Milpitas, Ca 95035 USA TEL : +1 408 888 8413 OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLE WOLFF ELEKTRONIK Yliopistonkatu 26 (P.O.BOX 257) FI-40101 Jyväskylä Finland TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. TEL: +852 2424 3274 FAX: +852 2424 2219 OLE WOLFF LTD. 5 Floor, Block G, WenTao Industrial Park, YingRenShi, Bao'an District, Shenzhen , PRC TEL: +86 755 82612542 TEL: +86 755 26406156 Date 13-Oct-2021 Page 5/8 CN SPECIFICATION P/N: OWMB-505020S-40-12D OLE WOLFF www.owolff.com Revision: 02 8. DIMENSIONS (Figure 3) Unit: mm Tolerance: ±0.5mm Except Specified Coplanarity: Respect to A plane as stand, B&C have the tolerance 0~0.1mm. OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 1525 McCarthy Blvd, Suite 1093 Milpitas, Ca 95035 USA TEL : +1 408 888 8413 OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLE WOLFF ELEKTRONIK Yliopistonkatu 26 (P.O.BOX 257) FI-40101 Jyväskylä Finland TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. TEL: +852 2424 3274 FAX: +852 2424 2219 OLE WOLFF LTD. 5 Floor, Block G, WenTao Industrial Park, YingRenShi, Bao'an District, Shenzhen , PRC TEL: +86 755 82612542 TEL: +86 755 26406156 Date 13-Oct-2021 Page 6/8 CN SPECIFICATION P/N: OWMB-505020S-40-12D OLE WOLFF www.owolff.com Revision: 02 9. Recommended Temp. Profile for Reflow Oven (Figure 4) Profile Feature Pb-Free Assembly Average ramp-up rate(TL to Tp) 3℃/second max. Preheat -Temperature Min.(Tsmin) 150℃ -Temperature Min.(Tsmax) 200℃ -Temperature Min.(ts) 60~180 seconds Tsmax to TL -Ramp-up Rate 3℃/second max. Time maintained above: - Temperature(TL) 217℃ -Time(TL) 60~150 seconds Peak temperature(Tp) 250℃+0/-5℃ Time within 5℃of actual Peak temperature (tp) 6 seconds max. Ramp-down Rate 6℃/second max. 8 minutes max. Time 25℃ to Peak Temperature OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 1525 McCarthy Blvd, Suite 1093 Milpitas, Ca 95035 USA TEL : +1 408 888 8413 OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLE WOLFF ELEKTRONIK Yliopistonkatu 26 (P.O.BOX 257) FI-40101 Jyväskylä Finland TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. TEL: +852 2424 3274 FAX: +852 2424 2219 OLE WOLFF LTD. 5 Floor, Block G, WenTao Industrial Park, YingRenShi, Bao'an District, Shenzhen , PRC TEL: +86 755 82612542 TEL: +86 755 26406156 Date 13-Oct-2021 Page 7/8 CN SPECIFICATION P/N: OWMB-505020S-40-12D OLE WOLFF www.owolff.com Revision: 02 10. PACKAGE INFORMATION (Figure 5) OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 1525 McCarthy Blvd, Suite 1093 Milpitas, Ca 95035 USA TEL : +1 408 888 8413 OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLE WOLFF ELEKTRONIK Yliopistonkatu 26 (P.O.BOX 257) FI-40101 Jyväskylä Finland TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. TEL: +852 2424 3274 FAX: +852 2424 2219 OLE WOLFF LTD. 5 Floor, Block G, WenTao Industrial Park, YingRenShi, Bao'an District, Shenzhen , PRC TEL: +86 755 82612542 TEL: +86 755 26406156 Date 13-Oct-2021 Page 8/8 CN SPECIFICATION P/N: OWMB-505020S-40-12D OLE WOLFF www.owolff.com Revision: 02 11. PACKAGE INFORMATION (Figure 6) NOTES: 1. 2500 PCS per box 2. 10 boxes / carton 25000 PCS 3. 4 boxes / carton 10000 PCS OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 1525 McCarthy Blvd, Suite 1093 Milpitas, Ca 95035 USA TEL : +1 408 888 8413 OLEWOLFF ELEKTRONIK GmbH Schulstrasse 15A. DE-25451 Quickborn. Germany TEL: +49 (0) 4106 765900 FAX: +49 (0) 4106 627297 OLEWOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLE WOLFF ELEKTRONIK Yliopistonkatu 26 (P.O.BOX 257) FI-40101 Jyväskylä Finland TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Unit B, 19/F., Bold Win Ind. Bldg., No. 16-18 Wah Sing St., Kwai Chung, N.T., H.K. TEL: +852 2424 3274 FAX: +852 2424 2219 OLE WOLFF LTD. 5 Floor, Block G, WenTao Industrial Park, YingRenShi, Bao'an District, Shenzhen , PRC TEL: +86 755 82612542 TEL: +86 755 26406156
OWMB-505020S-40-12D 价格&库存
很抱歉,暂时无法提供与“OWMB-505020S-40-12D”相匹配的价格&库存,您可以联系我们找货
