OWR-0860T-16
OWR-0860T-16
    OLEWOLFF
    16 Ohms 耳机驱动器 扬声器 5 mW 20 Hz ~ 20 kHz 顶部 圆形
OWR-0860T-16 数据手册
Date Page 2017.07.29 UK P/N: OWR-0860T-16 1/7 SPECIFICATION OLE WOLFF www.owolff.com Revision: 06 SPECIFICATION FOR APPROVAL Receiver unit Part Number OWR-0860T-16 This item was compliance with the following requirements: 1. RoHS directive 2. REACH Note Customer P/N Signature / Date Ole Wolff Prepared Checked Approved 张亚平 2017.08.15 Nathan Chen 2017.08.15 2017.08.15 Confirmation Signature / Date Customer REVISION NOTES: Date Rev. 2016.04.18 00 Initial Release 2016.04.19 01 Changed SPL grouping info and updated weight tolerance on P.2 2016.06.29 02 Corrected FR curve, changed FR and THD mask; driver drawing updated. 2016.07.06 03 Updated FR and THD mask. 2016.12.01 04 Added center value of FR, added group marking. 2017.08.10 05 Change SPL grouping information in P2, add 2 dimensions in P6, and update the FR limits. 2017.08.15 06 Change SPL definition at 1KHz, and change f0 center value back to 3100Hz. OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 Description of Revision OLE WOLFF ELECTRONICS INC. 6046 Cornerstone Ct.West Suite 105 San Diego, CA 92121 USA TEL: +1 858 45 00 555 FAX: +1 858 45 00 508 OLE WOLFF ELEKTRONIK GmbH Schnackenburgallee 14 D-22525 Hamburg GERMANY OLE WOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLE WOLFF ELEKTRONIK Yliopistonkatu 34 P.O. Box 257 FIN-40101 Jyväskylä FINLAND TEL: +49 (0) 407669070 FAX: +49 (0) 40772929 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Room 4, 16/F, Charm Centre 700 Castle Peak Road, Lai Chi Kok, Kowloon HONG KONG TEL: +852 2424 3274 FAX: +852 2424 2219 OLE WOLFF LTD. 5 Floor, Block G, WenTao Industrial Park, YingRenShi, Bao'an District, Shenzhen City, Guangdong Province,PRC. TEL: +86 755 82612542 TEL: +86 755 26406156 Date Page 2017.07.29 UK P/N: OWR-0860T-16 SPECIFICATION 2/7 OLE WOLFF www.owolff.com Revision: 06 1. SCOPE THIS SPECIFICATION IS APPLIED FOR RECEIVER UNIT FOR AN EARPHONE. 2. TEST CONDITIONS TEMPERATURE : 18° 22°C HUMIDITY : 60° 70°C (R.H.) ATMOSPHERE : 860  1060 hPa 3. GENERAL REQUIREMENTS OPERATING TEMPERATURE RANGE: -20° 55°C STORAGE TEMPERATUR RANGE: -25° 60°C 4. MECANICAL LAYOUT & DIMENSIONS DIMENSIONS : SHOWN IN FIGURE 3. UNIT WEIGHT : 0.7g +/-0.2g 5. ELECTRICAL AND ACOUSTICAL CHARACTERISTICS 1. 16   15% (at 126mV 1KHz) IMPEDANCE 2.A SOUND PRESSURE LEVEL 99.7dB  3 dB at 1mW/2CC Coupler @ 1000Hz 2.B SPL - SPECIAL SORTING at 200Hz 3. RESONANCE FREQUENCY Group A: 103 ~ 104.99dB dot marking = Red Group B: 105~ 106.99dB dot marking = Blue Group C: 107 ~ 108.99dB dot marking = Yellow Group D: 109 ~ 110dB dot marking = White 3100Hz ±15% 4. FREQUENCY RANGE 20Hz  20 KHz. Figure 2. 5. RATED INPUT POWER (Nominal /Maximum): 6. DISTORTION Please see below under point: FREQUENCY RESPONSE & THD CURVES (FIG. 2) 7. BUZZ AND RATTLES MUST BE NORMAL BY SINE WAVE FROM 50Hz TO 10kHz. Rated input power 5mW(0.28V). Hearing test, speaker is in vertical position in free air. OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 6046 Cornerstone Ct.West Suite 105 San Diego, CA 92121 USA TEL: +1 858 45 00 555 FAX: +1 858 45 00 508 5mW / 10mW, 0.28V / 0.4V OLE WOLFF ELEKTRONIK GmbH Schnackenburgallee 14 D-22525 Hamburg GERMANY OLE WOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLE WOLFF ELEKTRONIK Yliopistonkatu 34 P.O. Box 257 FIN-40101 Jyväskylä FINLAND TEL: +49 (0) 407669070 FAX: +49 (0) 40772929 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Room 4, 16/F, Charm Centre 700 Castle Peak Road, Lai Chi Kok, Kowloon HONG KONG TEL: +852 2424 3274 FAX: +852 2424 2219 OLE WOLFF LTD. 5 Floor, Block G, WenTao Industrial Park, YingRenShi, Bao'an District, Shenzhen City, Guangdong Province,PRC. TEL: +86 755 82612542 TEL: +86 755 26406156 6 Date Page 2017.07.29 UK P/N: OWR-0860T-16 3/7 SPECIFICATION OLE WOLFF www.owolff.com Revision: 06 QUALIFICATION TESTS - AFTER TEST Sensitivity difference at 1.0 KHz shall be with  3 dB from initial value. - LOAD TEST Signal test : White noise Power test : 5m W (0.28V) Duration : 96 Hrs - HIGH TEMPERATURE TEST High temperature : 55°C  3°C Duration : 96 Hours then left 6 hours in a room - LOW TEMPERATURE TEST Low temperature : -20°C  3°C Duration : 96 Hours then left 6 hours in a room HUMIDITY TEST Temperature : 40  2°C Humidity : 90 % (R.H.) Duration : 96 Hours then left 6 hours in a room - - VIBRATION TEST Vibration : 10 ~ 55 Hz / min Amplitude : 1.5 mm Duration : 1 hour each plan - DROP TEST Height Drop face Duration - : 1m : Hardwood Floor : 10 cycles TEMPERATURE CYCLE TEST Temperature : -20°C  2°C (2 hours)  + 55°C  2°C (2 hours) Cycles : 5 cycles Maximum power test 10 mWatts (at least 10 minutes without damage but not guarantee for no rattling) OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 6046 Cornerstone Ct.West Suite 105 San Diego, CA 92121 USA TEL: +1 858 45 00 555 FAX: +1 858 45 00 508 OLE WOLFF ELEKTRONIK GmbH Schnackenburgallee 14 D-22525 Hamburg GERMANY OLE WOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLE WOLFF ELEKTRONIK Yliopistonkatu 34 P.O. Box 257 FIN-40101 Jyväskylä FINLAND TEL: +49 (0) 407669070 FAX: +49 (0) 40772929 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Room 4, 16/F, Charm Centre 700 Castle Peak Road, Lai Chi Kok, Kowloon HONG KONG TEL: +852 2424 3274 FAX: +852 2424 2219 OLE WOLFF LTD. 5 Floor, Block G, WenTao Industrial Park, YingRenShi, Bao'an District, Shenzhen City, Guangdong Province,PRC. TEL: +86 755 82612542 TEL: +86 755 26406156 Date Page 2017.07.29 UK P/N: OWR-0860T-16 4/7 SPECIFICATION OLE WOLFF www.owolff.com Revision: 06 MEASUREMENT METHOD FOR DYMANIC SPEAKER (FIG. 1) 7 Fig 1A NO 1. 2. 3. 4. 5. 6. EQUIPMENT TEST JIG MICROPHONE MICROPHONE HOLDER DAMPING MATERIAL BOX Test distance measured from front of speaker frame to front of test microphone REMARKS FIG. 1A ½ INCH Microphone FOAM RUBBER 2CC Coupler ` OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 6046 Cornerstone Ct.West Suite 105 San Diego, CA 92121 USA TEL: +1 858 45 00 555 FAX: +1 858 45 00 508 OLE WOLFF ELEKTRONIK GmbH Schnackenburgallee 14 D-22525 Hamburg GERMANY OLE WOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLE WOLFF ELEKTRONIK Yliopistonkatu 34 P.O. Box 257 FIN-40101 Jyväskylä FINLAND TEL: +49 (0) 407669070 FAX: +49 (0) 40772929 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Room 4, 16/F, Charm Centre 700 Castle Peak Road, Lai Chi Kok, Kowloon HONG KONG TEL: +852 2424 3274 FAX: +852 2424 2219 OLE WOLFF LTD. 5 Floor, Block G, WenTao Industrial Park, YingRenShi, Bao'an District, Shenzhen City, Guangdong Province,PRC. TEL: +86 755 82612542 TEL: +86 755 26406156 Date Page 2017.07.29 UK P/N: OWR-0860T-16 SPECIFICATION 5/7 OLE WOLFF www.owolff.com Revision: 06 8. FREQUENCY RESPONSE & THD CURVES (FIG. 2) FR mask 50 100 200 315 500 800 1k 1.4k 2k Hz Center value 114.9 111.2 106.5 103.6 101.2 99.6 99.7 100.2 102.8 dB Upper Limits 4 4 3.5 3 3 3 3 3 4 dB Lower Limits -4 -4 -3.5 -3 -3 -3 -3 -3 -4 dB Frequency 2.8k 3.15k 3.55k 4k 5k 5.6k 6.3k 7.1k 8k Hz Center value 110.1 110.4 106.3 102.4 98.2 97.4 98.1 101.6 104.7 dB Upper Limits 5 5 5 5 5 5 5 6 6 dB Lower Limits -5 -5 -5 -5 -5 -5 -5 -6 -6 dB Frequency OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 6046 Cornerstone Ct.West Suite 105 San Diego, CA 92121 USA TEL: +1 858 45 00 555 FAX: +1 858 45 00 508 OLE WOLFF ELEKTRONIK GmbH Schnackenburgallee 14 D-22525 Hamburg GERMANY OLE WOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLE WOLFF ELEKTRONIK Yliopistonkatu 34 P.O. Box 257 FIN-40101 Jyväskylä FINLAND TEL: +49 (0) 407669070 FAX: +49 (0) 40772929 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Room 4, 16/F, Charm Centre 700 Castle Peak Road, Lai Chi Kok, Kowloon HONG KONG TEL: +852 2424 3274 FAX: +852 2424 2219 OLE WOLFF LTD. 5 Floor, Block G, WenTao Industrial Park, YingRenShi, Bao'an District, Shenzhen City, Guangdong Province,PRC. TEL: +86 755 82612542 TEL: +86 755 26406156 Date Page 2017.07.29 UK P/N: OWR-0860T-16 SPECIFICATION 6/7 OLE WOLFF www.owolff.com Revision: 06 THD mask Frequency 50 2k 3k 5k 7k Hz Upper limit 3 3 4 4 3 % 9. DIMENSIONS (FIG. 3) +polarity Unit: mm, tolerances: +/-0.3mm. OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 6046 Cornerstone Ct.West Suite 105 San Diego, CA 92121 USA TEL: +1 858 45 00 555 FAX: +1 858 45 00 508 OLE WOLFF ELEKTRONIK GmbH Schnackenburgallee 14 D-22525 Hamburg GERMANY OLE WOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLE WOLFF ELEKTRONIK Yliopistonkatu 34 P.O. Box 257 FIN-40101 Jyväskylä FINLAND TEL: +49 (0) 407669070 FAX: +49 (0) 40772929 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Room 4, 16/F, Charm Centre 700 Castle Peak Road, Lai Chi Kok, Kowloon HONG KONG TEL: +852 2424 3274 FAX: +852 2424 2219 OLE WOLFF LTD. 5 Floor, Block G, WenTao Industrial Park, YingRenShi, Bao'an District, Shenzhen City, Guangdong Province,PRC. TEL: +86 755 82612542 TEL: +86 755 26406156 Date Page 2017.07.29 UK P/N: OWR-0860T-16 7/7 SPECIFICATION OLE WOLFF www.owolff.com Revision: 06 10. PACKAGING (FIG.4) OLE WOLFF ELEKTRONIK A/S Roedengvej 25 4180 Soroe Denmark TEL: +45 57833830 FAX: +45 57820019 OLE WOLFF ELECTRONICS INC. 6046 Cornerstone Ct.West Suite 105 San Diego, CA 92121 USA TEL: +1 858 45 00 555 FAX: +1 858 45 00 508 OLE WOLFF ELEKTRONIK GmbH Schnackenburgallee 14 D-22525 Hamburg GERMANY OLE WOLFF ELECTRONICS 3 Bedford Street, Woburn, Bedfordshire MK17 9QB, ENGLAND OLE WOLFF ELEKTRONIK Yliopistonkatu 34 P.O. Box 257 FIN-40101 Jyväskylä FINLAND TEL: +49 (0) 407669070 FAX: +49 (0) 40772929 TEL: +44 (0) 1525 290755 FAX: +44 (0) 1525 290855 TEL: +358 14 338 3050 FAX: +358 14 338 3059 OLE WOLFF (ASIA) LTD. Room 4, 16/F, Charm Centre 700 Castle Peak Road, Lai Chi Kok, Kowloon HONG KONG TEL: +852 2424 3274 FAX: +852 2424 2219 OLE WOLFF LTD. 5 Floor, Block G, WenTao Industrial Park, YingRenShi, Bao'an District, Shenzhen City, Guangdong Province,PRC. TEL: +86 755 82612542 TEL: +86 755 26406156
OWR-0860T-16 价格&库存
很抱歉,暂时无法提供与“OWR-0860T-16”相匹配的价格&库存,您可以联系我们找货
