A64-OLINUXINO-1G4GW
A64-OLINUXINO-1G4GW
    OLIMEX
    OLINUXINO A64 EVAL BRD
A64-OLINUXINO-1G4GW 数据手册
    A64‐OLINUXINO‐1G4GW    There are three models:    A64-OLinuXino-1G0G with 1GB RAM but NO flash and NO WiFi/BLE connectivity A64-OLinuXino-1G4GW with 1GB RAM and 4GB extra flash and extra WiFi/BLE module A64-OLinuXino-2G16G-IND with 2GB RAM and 16GB extra flash but NO WiFi/BLE connectivity; with components that work in the industrial -40+85C temperature range FEATURES        Allwinner A64 - 1.2 GHz Quad-Core ARM Cortex-A53 64-bit Memory: 1GB or 2GB RAM DDR3L @ 672Mhz 0/4/16GB eMMC flash memory for storage and boot MicroSD card connector for cards up to 32GB Debug: serial UART debug header with 0.1" pins Wired connectivity: 10/100/1000Mbps GbE Ethernet Wireless connectivity: popular on-board WIFI and bluetooth 4.0 BLE module with built-in antenna (only available in the A64OLinuXino-1G4GW version)       Monitor output: HDMI output Display output: LCD output on 40-pin ribbon cable connector and MIPI DSI with 20-pin ribbon connector Audio: headphone output and microphone input with phone jacks (can be changed to Line-in and Line-out via jumpers) External power: power jack for 5V exeternal power supply Battery power: 3.7 Li-Po battery with charger and connector USB connectivity: USB-OTG support on microUSB connector; USB host on USB type A connector; USB HSIC signals available on 4-pin header drills @ 0.1" step           LEDs: power indication LED, battery charging status LED, user-programmable LED GPIO expansion: provided 40-pin header drills @ 0.1" step with useful signals (like CSI camera interface and GPIOs) UEXT expansion: provided 10-pin header drills @ 0.1" step for UEXT expansion optional SPI Flash on SO8 connector RTC battery expansion: pad provided for powering the RTC of AXP803 Buttons: UBOOT button; RESET button; POWER button Four mounting holes PCB dimensions: (90.0 x 62.5)mm ~ (3.5 x 2.5)"
A64-OLINUXINO-1G4GW 价格&库存
很抱歉,暂时无法提供与“A64-OLINUXINO-1G4GW”相匹配的价格&库存,您可以联系我们找货
