OP TAN® 3535
Data Sheet Updated October, 2022
F E AT U R E S
BENEFITS
• Lifetime capacity to generate over 36
Billion spectroscopic measurements
• High power output stability with low
pulse-to-pulse variation
• Minimal power consumption at 20mA
• Compact package built for PCBA
realtime
monitoring
• Measurement data at orders of magnitude
lower cost than other techniques
• Simple UVC source ideal for compact
sensors
• On-demand power output and low power
requirements
• Wavelength ranges aligned directly with
most industrial and water quality
processes
swarm
sensoring
digitize
water
Regardless of your critical compound or parameter, Optan UVC LEDs can provide the right solution.
S U G G E S T E D WAV E L E N G T H R A N G E F O R C O M M O N PA R A M E T E R S
Parameter
Nitride
Nitrate
Capillary Flow
Turbidity
EPA UV 254/SAC
COD
Ozone
TOC
BOD
Oil-in-Water
Protein
Uric Acid
250nm
nm- -237
260nm
nm
231
250 nm - 260 nm
270 nm - 280 nm
1 | optanled.com
O P TA N 3 5 3 5
Data Sheet
P R O D U C T N O M E N C L AT U R E
Optan LEDs are binned by peak wavelength and total power output (P t).
Part Number
Peak Wavelength
Min
Max
Optical Power output at 20 mA
Min
Optical Power output 100 mA
Min
Max
Not Applicable1
OP235-02N-SM
OP255-10P-SM
231 nm
250 nm
237 nm
260 nm
0.05 mW
0.5 mW
4 mW
8 mW
OP275-10P-SM
270 nm
280 nm
0.5 mW
4 mW
8 mW
Typical
Max
Notes:
1. Max operating current of 50mA for OP235-02N-SM.
L E D C H A R AC T E R I S T I C S
OP235-02N-SM Characteristics
Unit
Min
Viewing Angle
Forward voltage at 20 mA
Thermal resistance, junction-to-case
degrees
V
ºC/W
5
Power dissipation
W
OP255-10P-SM and OP275-10P-SM Characteristics
Unit
Viewing Angle
Forward voltage at 100 mA
degrees
V
ºC/W
Power dissipation
W
120
6
10
9
0.18
Min
Typical
Max
120
8
10
0.8
A B S O LU T E M A X I M U M R AT I N G S
Unit
Min
Max
Forward Current (continuous)
Reverse Voltage
Operating temperature range
Storage temperature
mA
V
ºC
ºC
-40
50
-5
50
85
Unit
Min
Max
Reverse Voltage
Storage temperature
mA
V
ºC
ºC
-5
55
100
Junction temperature
ºC
-5
-40
115
2 | optanled.com
O P TA N 3 5 3 5
Data Sheet
T Y P I CA L R A D I AT I O N PAT T E R N
Optan 3535 LEDs have a nominal viewing angle of 120°.
T Y P I CA L E L E C T R I CA L C H A R AC T E R I S T I C S
100
The typical
forward voltage is less than 8 V at an operating
current of 100 mA.
80
-15
15
-30
0.8
30
-45
C U R R E N T,
1.0
N O R M A L I Z E D I N T E N S I T Y. A . U .
m A C U R R E N T,
mA
Electrical Characteristics
45
0.6
60
-60
0.2.
40
80
0.4
1
2
3
4
5
6
7
8
9
10
7
8
9
10
V O LT A G E , V
-75
60
100
90
-90
2
3
4
5
6
100
1.0
V O LT A G E , V
80
T Y P I CA L S P E C T R A L C H A R AC T E R I S T I C S
OV E R 0C U R R E N T
1 shows
2
3 stability
4
5 of the
6
7
8
9
10
The plot 0below
the
peak
wavelength
V Ochange
LT A G E , in
V drive current from
in the peak wavelength with
20 mA to 100 mA.
Spectrum over Current
100 mA
60 mA
WAVELENGTH OFFSET FROM PEAK,
0.2
0.0
-20
100
100 mA
60 mA
20 mA
0.6
0.4
0.2
-10
Test Conditions: Solder temperature (Ts) = 35 °C
Pulse mode operation. Please note, this graphic does not
depict the characterization of OP235-02N-SM which
operates at a lower current.
nm
R E L A T I V E L I G H TR EOLUATTPI U
V ET , L%
I G H T O U T P U T, %
a.u.
I N T E N S I T Y,
0.4
0.8
nm
Light Output over Current
0.8
20 mA
1.0
T Y P I CA L L I G H T O U T P U T C H A R AC T E R I S T I C S
0.2
20 mA
OV E R C0.6
URRENT
The plot below shows the typical variation in light output
0.0
with forward
data is 10
normalized 20
to
-10The light output
0.4-20 current.
the light output at 100 mA.
1.0
100
60 mA
a.u.
a . uI .N T E N S I T Y,
40
I N T E N S I T Y,
C U R R E N T,
60
0.0
-20
100 mA
Test Conditions:
0.8
Pulse mode operation from 1 mA to 100 mA. Please note,
this graphic does not depict the characterization of
OP235-02N-SM
which operates at a lower current.
0.6
mA
Test Conditions: I (CW) = 100 mA, CW=Continuous Wave Mode
-10
nm
80
60
100
OPxxx-10P-SM
OP235-02N-SM
40
80
60
FORWARD CURRENT (
60
FORWARD CURRENT (
100
80
100
mA)
0 operation
Pulse mode
mA)
80
60
3 | optanled.com
O P TA N 3 5 3 5
Data Sheet
M E C H A N I CA L D I M E N S I O N S
1
0.15
0.40
3
3.20
2.48
3.50
3.50
1
0.60
0.15
Cathode
3.20
0.50
0.50
Anode
0.86
Anode
0.6 0
0.60
Cathode
0.50
0.5 0
Thermal Pad
1.28
All dimensions are in millimeters. Unless noted otherwise, all dimensions have a tolerance of ± 0.05 mm.
RECOMMENDED SOLDERING GUIDELINES
The recommended solder reflow profile for Optan UVC LEDs follows the JEDEC standard J-STD-020D. Hand soldering is not
recommended for these devices.
Figure 1
tp
Tp
T c : -5 °C
M AX RAM P U P RAT E = 3 ° C/s
M AX RAM P D OWN R AT E = 6 °C /s
R E F E R E N C E T E M P E R AT U R E
TL
Temperature 1
Temperature 2
tL
T smax
PREHEAT ARE A
T smin
25° C
ts
TIME 2 5 ° C TO PEAK
TIME
4 | optanled.com
O P TA N 3 5 3 5
Data Sheet
GUIDELINES
Profile Feature
Pb-Free Assembly
Preheat/Soak
Temperature Min (Tsmin)
150 °C
Temperature Max (Tsmax)
200 °C
Maximum Time (ts) from Tsmin to Tsmax
Ramp-up rate (TL to Tp)
Liquidous Temperature (TL)
Time (tL) maintained above TL
Maximum peak package body temperature (Tp)
Time (tp) within 5 °C of the specified temperature (T C)
Ramp-down rate (Tp to TL)
60-120 seconds
3 °C/second max.
217 °C
60~150 seconds
260 °C
30 seconds
6 °C/second max.
Maximum Time 25 °C to peak temperature
8 minutes max.
5 | optanled.com
O P TA N 3 5 3 5
Data Sheet
EYE SAFET Y GUIDELINES
During operation, the LED emits high intensity ultraviolet
(UV) light, which is harmful to skin and eyes. UV light is
hazardous to skin and may cause cancer. Avoid exposure to
UV light when LED is operational. Precautions must be taken
to avoid looking directly at the UV light without the use of
UV light protective glasses. Do not look directly at the front
of the LED or at the LED’s lens when LED is operational.
RoHS COMPLIANCE
The levels of environmentally sensitive, persistent
biologically toxic (PBT), persistent organic pollutants (POP),
or otherwise restricted materials in this product are below
the maximum concentration values (also referred to as the
in an exempted application, in accordance with EU Directive
2011/65/EU on the restriction of the use of certain hazardous
substances in electrical and electronic equipment (RoHS), as
adopted by EU member states on July 22, 2019.
H A N D L I N G P R E CAU T I O N S
LEDs are sensitive to static electricity. When handling,
proper ESD protection is required, including:
• Eliminating static charge
• Using grounded wriststrap,
ESD footwear, clothes, and floors
• Grounded workstation and tools
DISCLAIMER
The specifications, characteristics, and
technical data presented in this datasheet
are subject to change without prior notice.
It is recommended that the most updated
specifications, characteristics, and technical
data be used in your application.
The information in this document has been
compiled from reference materials and other
sources believed to be reliable, and given in
good faith. No warranty, either expressed or
implied, is made, however, to the accuracy
and completeness of the information, nor is
any responsibility assumed or implied for any
loss or damage resulting from inaccuracies or
omissions. Each user bears full responsibility
for making their own determination as
to the suitability of Crystal IS products,
recommendations or advice for its own
particular use. Crystal IS makes no warranty
or guarantee, express or implied, as to results
obtained in end-use, nor of any design
incorporating its Products, recommendation
or advice. Each user must identify and perform
all tests and analyses necessary to ensure
that it’s finished application incorporating
Crystal IS’ products will be safe and suitable
for use under end-use conditions. Each user of
devices assumes full responsibility to become
educated in and to protect from harmful
irradiation. Crystal IS specifically disclaims
any and all liability for harm arising from
buyer’s use or misuse of UVC devices either in
development or end-use.
AT TAC H T H E F O L LOW I N G WA R N I N G L A B E L S O N
P R O D U C T S/SYS T E M S T H AT U S E U V L E D :
Crystal IS, Inc.,
an Asahi Kasei Company
70 Cohoes Avenue
Green Island, NY 12183
U.S.A.
sales@cisuvc.com
(518) 271–7375
www.cisuvc.com
© 2022 Crystal IS, Inc. All rights reserved.
Crystal IS, Optan and the Crystal IS logo
are trademarks of Crystal IS, Inc.and/or
its affiliates. All other trademarks are the
property of their respective owners.
1066-1801
6 | optanled.com
