The Best LED Retrofit
Solutions on Planet Earth
RKS SERIES LED RETROFIT KIT
Lasts
200,000
hours
7-Year
Warranty
Uses Up
to 70%
Less
Energy
• Converts outdated 4 ft. and 8 ft. T5/T8/T12 fluorescent fixtures into a fully-integrated
“like-new” LED fixture
• Installs in less than 5 minutes with no tools in 3 easy steps
• High-efficiency retrofit kit uses 75% less energy; saving you money
Model
Number*
Nominal Power
LED
Strips Qty Listed
Ambient
Lumens**
DLC reported
Lm/w
RKS1420-X
20W
1 x 42”
3000
150
RKS2420-X
20W
2 x 42”
3000
150
RKS2430-X
30W
2 x 42”
>4489
148
RKS3430-X
30W
3 x 42”
>4621
152
RKS2440-X
40W
2 x 42”
5900
148
RKS3440-X
40W
3 x 42”
>6082
156
RKS2450-X
50W
2 x 42”
>6458
138
RKS3450-X
50W
3 x 42”
>6835
145
RKS Universal Fluorescent Fixture Retrofit Kit. Easily converts most all your
existing residential and commercial 4 and 8-foot T5, T8 and T12 linear
fluorescent light fixtures into an integrated LED light fixture. This retrofit kit
works with the earliest to the latest versions of ceiling mount, 4-foot and
8-foot fluorescent light fixtures, regardless of the style, manufacturer or
existing ballast type including linear highbay, strip or wrap fixtures and even
chain suspended shop lights.
Since the retrofit kit contains the LED driver, there is no guess work to
determine if it is compatible with your existing fixtures’ magnetic or
electronic ballast.
Super simple installation in 3 easy steps: 1). Remove existing bulbs and
ballast. 2). Attach magnetically backed driver and connect to AC power
source. 3). Attach magnetically-backed LED strips and quick connect to
Y-harness.
If your fixture isn't steel, no worries, the kit is predrilled and comes with
mounting screws
Converts 4 ft. and 8 ft. fixtures
• Each kit includes the listed number of LED magnetic
strips, (1) driver, (1) quick-connect output harness
and optional mounting screws
• Perfect for cold start applications down to -49°F and
as high as 158°F
• LED strips and driver are backed with rare earth
magnetic tape, attaches to the existing steel light
fixture in seconds
• For non-steel fixtures and high vibration
applications, the kit is predrilled and comes with
mounting screws
• Thermally conductive rare earth magnetic tape
maintains its extraordinary strength across wide
temperature variations; it also acts as a heat sink
which increases the life of the LEDs and driver
• CRI of 82
• Accepts 90 to 277-volt and 50 to 60 Hertz input
• Power factor of up to .989
• Dimming not standard, optional upgrade
• Optional Accessories: Clear and frosted lenses,
adhesive backing and extended harnesses
• Suitable or damp locations
* X suffix in model number denotes CCT, ie: RKS2440-3 = 3500K, RKS2440-4 = 4000K, RKS2440-5 = 5000K
** Test results verified by UL Verification Services Inc., in accordance with DLC guidelines. Results shown are at 5000K, tested in Linear Ambient luminaire without lens. Lumen output of other
CCT and/or different luminaire may have different lumen outputs.
www.optilumen.com | 844.438.5444
很抱歉,暂时无法提供与“RKS2440-50-B”相匹配的价格&库存,您可以联系我们找货
