CG9103-2RS232-1USB
User Manual
Document Revision: 1.02
Document Date: 29 October 2014
© 2014 by BiPOM Electronics, Inc. All rights reserved.
CG9103-2RS232-1USB User Manual. No part of this work may be reproduced in any manner without written
permission of BiPOM Electronics, Inc.
All trademarked names in this manual are the property of respective owners.
WARRANTY:
BiPOM Electronics warrants CG9103-2RS232-1USB for a period of 3 years. If the board becomes defective
during this period, BiPOM will at its option, replace or repair the board. This warranty is voided if the product is
subjected to physical abuse or operated outside stated electrical limits. BiPOM Electronics will not be
responsible for damage to any external devices connected to CG9103-2RS232-1USB. BiPOM Electronics
disclaims all warranties express or implied warranties of merchantability and fitness for a particular purpose. In
no event shall BiPOM Electronics be liable for any indirect, special, incidental or consequential damages in
connection with or arising from the use of this product. BiPOM Electronics’ liability is limited to the purchase
price of this product.
www.bipom.com
Page 2
Overview
CloudGate is an intelligent 3G or LTE M2M gateway and wireless Linux
computer from Option®. CloudGate provides cell modem, LAN to WWAN
routing and GPS functionality in a single basic unit for remote monitoring and
control applications.
On top of the basic functionality, CloudGate can be tailored to meet specific
industrial requirements by adding additional software and peripheral boards.
CG9103-2RS232-1USB is one such peripheral board for CloudGate.
CG9103-2RS232-1USB is a miniature interface board, containing dual channel RS-232 line driver / receiver,
and USB Host and OTG interface circuit. The combination of CG9103-2RS232-1USB and CloudGate offers
unmatched connectivity to a wide variety of external devices. CG9103-2RS232-1USB is fully backed by a 3year warranty, technical support and application assistance from BiPOM.
www.bipom.com
Page 3
Specifications
One 4-wire RS-232 port: TXD,RXD,CTS,RTS
One 2-wire RS-232 port: TXD,RXD
TIA / EIA –232-F compliant
One USB Host interface with software controlled power management.
One MicroSD socket with software controlled power management.
5VDC/1A power available to external devices
Powers from CloudGate
Low power consumption: Under 1mA when idle
Protected against Electrostatic Discharge (ESD)
FCC Certified
Target Applications:
Oil and Gas Monitoring
Irrigation Generator Set Monitoring
Energy Monitoring
Utility Meter Remote Monitoring
Factory Automation
Vibration Monitoring
Sensor Networks
Medical Devices
Asset Tracking
Ordering Information
CG9103-1USB ( Single USB Host )
CG9103-2RS232-1USB ( Dual RS232 plus single USB Host )
Both models have microSD socket.
www.bipom.com
Page 4
Board Layout
CloudGate
Connector
Power Select
Jumper
microSD Card
Socket
RS232-2
Connector
USB
Connector
RS232-1
Connector
Figure 1
www.bipom.com
Page 5
RS-232 ports and USB
The placement of USB and RS232 connectors at the front panel is shown on Figure 2:
Figure 2
MicroSD Card Holder
CG9103-2RS232-1USB has a socket for a microSD card operation for data storage and other purposes.
MicroSD card is accessible from CloudGate Linux.
www.bipom.com
Page 6
Power Select Jumper
CG9103-2RS232-1USB can be powered either from its on-board power supply, or from CloudGate 3.4V.
Figure 2 shows how Jumper X1 is used to switch between these two options:
Internal Power Supply
Power supply from CloudGate 3.4V
Figure 2
RS232 Power Jumpers
When installed, jumper X6 connects +5V power supply to Pin #4 (DTR) of RS232-0 connector.
When installed, jumper X7 connects +5V power supply to Pin #4 (DTR) of RS232-1 connector.
www.bipom.com
Page 7
Software
CG9103-2RS232-1USB can be accessed using the serial framework for CloudGate.
BiPOM also provides a test developer image that enables the Linux drivers for CG9103-2RS232-1USB. After
installing the developer image through the CloudGate provisioning web interface:
1. From Linux command shell, microSD card can be mounted to /tmp/mmc using:
mkdir /tmp/mmc; mount /dev/mmcblk0 /tmp/mmc; cd /tmp/mmc
2. From Linux command shell, an external USB flash drive on USB port cane be mounted to /tmp/usb using:
mkdir /tmp/usb; mount /dev/sda /tmp/usb; cd /tmp/usb
3. A built-in terminal program allows RS232 loopback testing (without handshake lines) when a NULL modem
cable is connected between the two RS232 connectors. Terminal can be started using:
For RS232-1 port:
/rom/mnt/cust/bin/terminal -d /dev/ttySP0
For RS232-2 port:
/rom/mnt/cust/bin/terminal -d /dev/ttySP4
4. A built-in terminal program allows RS232 loopback testing (using the handshake lines RTS and CTS on
RS232-1 port) when a NULL modem cable is connected between the two RS232 connectors. Two separate
sessions of the terminal program can be started in two separate Linux shell windows using:
/rom/mnt/cust/bin/terminal_handshake -d /dev/ttySP0
If RTS-0 and CTS-0 are not connected, it is not possible to send data from SP0 to SP4.
SP4 can still send and SP0 will receive.
To send data from SP0 to SP4 necessary to connect RTS-0 and CTS-0 externally so handshake lines will be
used to control RS232 traffic.
www.bipom.com
Page 8
很抱歉,暂时无法提供与“CG9103-2RS232-1USB”相匹配的价格&库存,您可以联系我们找货
