3G
Americas
CONNECTING THINGS
to the Cloud
• Simple, value priced WWAN M2M IP connectivity
• Automatic connection monitoring and error recovery
• Secure, redundant firmware and configuration images
• Unique software and hardware configuration flexibility
• Automatic provisioning of custom middleware
CONNECTING THINGS
to the Cloud
The CloudGate provides competitively priced LAN to WWAN routing and
GPS functionality in a single basic unit certified on all major US cellular
operators. The CloudGate is simple to configure locally or remotely from
your PC, tablet or SmartPhone.
Features
Sub Feature
WWAN Modem
Supported frequency
bands
Max. Connectivity
speeds
Reliable and secure
CloudGate automatically resolves common problems associated with
wireless M2M connectivity. Built in software and hardware watchdogs
continuously monitor each component of the product and the product’s
connectivity to home servers. In the event an issue is detected, the product
proactively takes steps to re-establish connectivity. All software and
configuration images are protected with digital signatures and have dual
rollback images that allow the product to revert to previous working settings
if an issue is detected. All management functions are protected by certificate
and/or password based security mechanisms and all management actions
take place over hardware assisted encrypted links.
Flexible and cost effective to integrate and deploy
CloudGate provides unique flexibility that allows customers and system
integrators to tailor the product to their solution or even site specific
requirements. CloudGate incorporates two hardware expansion slots that
allow the CloudGate to be enhanced with additional radio and/or wired
interfaces. The expansion cards are simple and quick to install, allowing
the field upgrade of the device when new functionality is required. All the
design details of the expansion card are available to partners allowing you
to add value with your own hardware products. CloudGate allows simple
integration and provisioning of customer or third party middleware and
applications. The automated cloud provisioning system means that each
device can be set with its own custom configuration and image that is
automatically loaded from the cloud when it initially connects to the internet.
• 1 x SMA: WWAN Main
• 1 x SMA: WWAN Div/GPS
Assisted/Standalone
GPS
USIM/SIM connection
Industrial serial card
Ethernet switch
Telematics card
SDK
HDK
Developer card
Breadboard card
• Expansion board for IO functions such as serial, USB, GPIO,
WiFi
Power
DC Power in
Connector type
• 9-33 V DC
• Micro-Fit 3.0™, Dual Row, 4 Circuits
Current consumption
• All measurements at 12V DC
• CloudGate attached to 2G network, no Ethernet: 121mA.
• CloudGate attached to 2G network, Ethernet connected:
136mA
• CloudGate attached to 2G network, no Ethernet, 2G call (2Tx,
32dBm): 270mA, peak = 772mA
• CloudGate attached to 3G network, no Ethernet,
3G call @ 2100MHz (band I): 341mA
Dimensions (w x d x h)
• 115 mm × 105 mm × 45 mm
Weight
Operating temperature
• 294 g
• 6 through holes for M4 bolts - 2 x 2 compatible with VESA Mount
MIS-D 75 (Optional standard DIN rail mounting interface)
• -30°C to 70°C
Storage temperature
• -40°C to +85°C
Humidity operational
• 5% - 95% non condensing
Certification
• FCC
• IC
• PTCRB
• IFETEL
Standards
compliance
• ROHS, Reach
SDK + HDK
As part of the continual product improvement process, OPTION reserves the right to alter the specifications of this product.
© 2014 OPTION. Option and the Option logo are registered trademarks of OPTION. All third-party trademarks are the property of the respective owners.
Option nv - Gaston Geenslaan 14 - 3001 Leuven Belgium - T +32 16 317 411 - F +32 16 207 164
1. Configure CloudGate
provisioning server
• USIM/SIM connection – Class B and Class C
2. Configuration & middleware
are automatically installed
www.option.com
3. Device is ready to connect
things to the Cloud!
DataSheet_v1.1
WLAN expansion card Low cost serial card
• Standalone GPS, Assisted GPS, gps OneXTRA™
• Wideband GPS processing (20MHz) for improved
measurement accuracy
• 10/100 Mbps RJ45 Connector
Expansion Slot
1&2
Enviromentals
• Seven 3 color LEDs showing system status and signal strength
• ARM926EJ-S @ 450MHz
• Memory available for customer applications:
- 30 Mb R/O flash for executables
- 30 Mb R/W flash shared with system
- 40 Mb free RAM
- 1 Mb Configuration data
Mounting
Also available
CloudGate
Connectors
Ethernet
(IEEE 802.3)
Case
• HSPA+: 14.4 Mbps (Cat 10) down 5.76 (Cat 6) up
• EV-DO RevA mode: 3.1 Mbps FL/1.8 Mbps RL
• Simultaneous Equalization and Rx Diversity on all bands,
except for GSM/GPRS/EDGE
CPU
SIM
• GSM/GPRS/EDGE: 850/900/1800/1900 MHz
• UMTS/HSDPA/HSUPA/HSPA+: 800-850/900/1900/2100
MHz and AWS band (1700/2100 MHz) (B1, B2, B4, B5,
B6, B8)
• CDMA 1xRTT/EV-DO rev0/EV-DO revA: 800/1900 (BC0,
BC1)
Rx Diversity
Visual feedback
GPS
Description
很抱歉,暂时无法提供与“CG0192-11897-D”相匹配的价格&库存,您可以联系我们找货
