CM0126-12161
CM0126-12161
    OPTION
    2G 802.15.4b/g/n,EDGE,GPRS,GPS,LTE 网关 AT&T 以太网,RJ-45,RS-232,RS-485
CM0126-12161 数据手册
LTE CAT M1/NB1 nano AVAILABLE WITH OPTIONAL WiFi, LoRaWAN or BATTERY The ideal Smart Building & Smart Metering Gateway • CloudGate with LTE CatM1/NB1 modem • Ethernet, M-Bus and serial (RS232/RS485) interface • Optional WiFi or LoRaWAN or Battery backup Feature Superior indoor performance, ideal for smart building and smart energy WWAN Modem LTE CloudGate nano was created with smart buildings in mind. The use of a LTE Cat M1/NB1 modem with high-power chipset ensuring better indoor coverage compared to traditional 2G/3G/4G modems, allows to connect devices deep inside buildings. By adding a Modbus and M-Bus connector it is possible to connect electricity, gas, water or calorie meters but also wired sensors that need to send data to a Cloud platform. WWAN Modem 2G With the powerful LuvitRED program on CloudGate it is very straightforward to create the required data flow on the gateway or to perform edge processing on the data before it is sent to the Cloud. Data reduction through edge processing is vital in case of low bandwith (and higher cost per bit) protocols such as CAT-M or NB-IoT to improve data performance and reduce connectivity cost. M-Bus interface LTE Cat-M or NB-IoT NB-IoT supports ultra-low complexity devices with very narrow bandwidth of 180 kHz. Due to its narrow bandwidth, the data rate peaks at around 60 kbps (for NB1). On the other hand, Cat-M1 operates at 1.08 MHz bandwidth with higher device complexity/cost than NB-IoT. The wider bandwidth allows Cat-M1 to achieve greater data rates (up to 1 Mbps for cat M1) and lower latency (10 to 15ms vs 1.6s to 10s). The link budget (coverage) for NB-IoT is also higher (164dB) than for LTE Cat M1 (155.7dB) and much higher than LTE Cat 4 (142.7dB) which means that coverage under difficult circumstances (like indoor) is best in Cat-NB1 mode. Most common use cases of NB-IoT include utility meters and sensors. Typical use cases for Cat-M1 include connected vehicles and alarm panels. Cat-M1 and NB-IoT are considered future-proof and are viewed as 5G technologies. Sub Feature Supported frequency bands Max. Connectivity speeds Supported frequency bands Max. Connectivity speeds WWAN antenna Antenna connector SIM Type • 850/900/1800/1900Mhz • EDGE: Max. 296Kbps (DL), Max. 236.8Kbps (UL) • GPRS: Max. 107Kbps (DL), Max. 85.6Kbps (UL) • 1x SMA (WWAN Main) • microSIM (3FF) Location • Behind back cover plate Speed • 10/100Mbps (IEEE 802.3) Connector • 1x RJ45, SW selectable as LAN or WAN Type • Master only Max # slaves • 4 Connector Serial interface • Cat M1: Max. 375Kbps (DL), Max. 375Kbps (UL) • Cat NB1: Max. 32Kbps (DL), Max. 70Kbps (UL) • USIM/SIM, class B and class C Dimension Ethernet interface Description • FDD-LTE : B1/ B2/ B3/ B4/ B5/ B8/ B12/ B13/ B18/ B19/ B20/ B25/ B26/ B28 • TDD-LTE : B39 (for Cat M1 only) • 2-pin RS232 mode • RX, TX, CTS, RTS, GND RS485 mode • Full duplex (RB+, RA-, TB+, TA-, GND) or • Half duplex (TB+, TA-, GND) Connector • 5-pin LED 3 multi-color • System • WWAN state • WWAN signal MicroSD card holder Available • On main PCB Location • Behind back cover plate Optional • 802.15.4 b/g/n. 2.4GHz or 5GHz. Client or access point mode • Max 32 clients can be connected WLAN (*) Connector LoRaWAN(*) • 1x RP-SMA (back -side) Optional • software-configurable as 8xxMHz or 9xxMHz Connector • 1x RP-SMA (back -side) Battery (*) Optional • Li-ion battery for last-gasp function (up to 1h) • Capacity 980mAh Power control Available • Timed wakeup. Ignition sensing (with extra 3rd pin on DC power connector) Programming Available • LuvitRED (graphical drag & drop) or SDK (C code) Aluminum case Dimension • 102 x 97 x 26 mm • 4 x 3.8 x 1 in Weight • 220 g/7.7 oz (excl. optional cards) Front/back plate mounting • 5x Torx T10 front, 5x Torx T10 back CloudGate mounting Environmental • Bulkhead: 2x4mm front, 2x4mm back • DIN rail: with optional adapter Operating temperature • -30°C to 70°C (-22°F to 158°F) Storage temperature • -40°C to 85°C (-40°F to 185°F) Certification • CE, FCC, PTCRB, ISED, AT&T, Verizon, US Cellular, Telus Compliance • RoHS, REACH, WEEE Accessories • LTE antenna • AC power supply or DC power cable • DIN rail mount • Battery (not for versions with WLAN card or LoRaWAN card) (*) Either the LoRa or WLAN or Battery can be mounted in production ex-factory as optional card on the main card (*) Order numbers differ per model Product PN CloudGate nano CM0126-12161 CloudGate nano with battery (WLAN & LoRaWAN not possible) CM0126-12195 CloudGate nano with WLAN (battery back-up & LoRaWAN not possible) CM0126-12162 CloudGate nano with LoRaWAN (battery back-up & WLAN not possible) CM0126-12202
CM0126-12161 价格&库存
很抱歉,暂时无法提供与“CM0126-12161”相匹配的价格&库存,您可以联系我们找货
