CG0102-11955-A
CG0102-11955-A
    OPTION
    ROUTER 3G GLOBAL
CG0102-11955-A 数据手册
CONNECTING THINGS to Each Other Secure Features Features All of CloudGate’s software and configuration images are protected with digital signatures and have dual rollback images that allow the product to revert to previous working settings if an issue is detected. All management functions are protected by certificate and/or password based security mechanisms and all management actions take place over hardware assisted encrypted links. Flexible and cost effective to integrate and deploy CloudGate provides unique flexibility that allows customers and system integrators to tailor the product to their solution or even site specific requirements. CloudGate also allows simple integration and provisioning of customer or system integrator middleware and applications on the device. The automated cloud provisioning system means that each device can be set with its own custom configuration and image. Sub Feature Ethernet (IEEE 802.3) • Expansion board for IO functions such as serial, USB, GPIO, WiFi DC Power in Connector type Case Dimensions (w x d x h) Weight Mounting Enviromentals ARM926EJ-S @ 450MHz Memory available for customer applications 30 Mb R/O flash for executables 30 Mb R/W flash shared with system 40 Mb free RAM 1 Mb Configuration data Linux 2.6.35 Open WRT Stack • 10/100Mb/s RJ45 Connector Expansion Slot 1&2 Power Description • • • • • • • CPU CloudGate incorporates two hardware expansion slots that allow the CloudGate to be enhanced with additional radio and/or wired interfaces. The expansion cards are simple and quick to install, allowing the field upgrade of the device when new functionality is required. A range of accessory cards including wireless LAN Access Point and Client, RS-232 and RS-485, and a 4-port Ethernet switch are available from Option. All the design details of the expansion card can be licensed free of charge to partners allowing them to add value with their own hardware products. Sub Feature • 9-33 V DC • Micro-Fit 3.0™, Dual Row, 4 Circuits • 115 mm × 105 mm × 45 mm • 180 g • 6 through holes for M4 bolts - 2 x 2 compatible with VESA Mount MIS-D 75 (Optional standard DIN rail mounting interface) Operating temperature • -30°C to 70°C Storage temperature • -40°C to +85°C Humidity operational • 5% - 95% non condensing • ROHS, Reach • FCC/CE Standards compliance Industrial Serial Expansion Card Summary The Option CloudGate M2M Gateway has the basic, simple to use functionality for most applications along with the unique flexibility for meeting specific requirements that makes it the ideal choice for use with custom solutions. Serial Expansion Card WiFi Expansion Card As part of the continual product improvement process, OPTION reserves the right to alter the specifications of this product. © 2012 OPTION. Option and the Option logo are registered trademarks of OPTION. All third-party trademarks are the property of the respective owners. Option nv - Gaston Geenslaan 14 - 3001 Leuven Belgium T +32 16 317 411 - F +32 16 207 164 www.option.com CONNECTING THINGS to Each Other DataSheet_v1.9 4-Port Ethernet Expansion Card
CG0102-11955-A 价格&库存
很抱歉,暂时无法提供与“CG0102-11955-A”相匹配的价格&库存,您可以联系我们找货
