SL-405-35-S-B-30-5V
SL-405-35-S-B-30-5V
    OSELA
    Module
    UNIFORM LASER LINE, MACHINE VISI
SL-405-35-S-B-30-5V 数据手册
Rev. DESCRIPTION DATE RESP ECO SOCKET SET SCREW #2-56 ( USE AN ALLEN WRENCH 0.35 [0.9] TO LOCK THE FOCUS ) ISOMETRIC VIEW 0.750 +0.000 -0.002 O +0.00 19.05 -0.05 EXTERNAL FOCUS 3.46 ±0.020 87.9 ±0.5 1.850 REF. 47.0 ADJUSTMENT POT LED 0.745 +0.000 -0.004 +0.00 FRONT SECTION 18.92 -0.10 0.630 CLAMPING AREA 16.0 FRONT SECTION RED = 5V BLACK = COMMON GROUND WHITE = MODULATION SHIELD = CHASSIS CABLE LENGTHS 18" STANDARD AND CUSTOM AVAILABLE NOTE : PART TO BE FREE OF BURRS AND SHARP CORNERS This print or drawing shall be used only with reference to contracts or proposals of Nothing disclosed herein not publicly available shall be used without written permission from UNLESS OTHERWISE SPECIFIED : 1. DIMENSIONS ARE IN : INCH 2. TOLERANCES : FRACTIONS DECIMALS XXX XX X ANGLES + + + + + - 3. SURFACE FINISH : COPYRIGHT C MATERIAL: 1/64 0.005 0.010 0.015 30' 32 DESIGNER L.DIONNE APPVL FINISH SCALE : N/A SHEET: 1=1 1 DE 1 TITLE STREAMLINE LASER ASSEMBLY REF. DRAWING REF DWG DATE 2011/05/19 B DRAWING NO. 300-0052-REFREV.: 0
SL-405-35-S-B-30-5V 价格&库存
很抱歉,暂时无法提供与“SL-405-35-S-B-30-5V”相匹配的价格&库存,您可以联系我们找货
