GB QSSPA1.13-HYJX-35-1-350-R18 数据手册
www.osram-os.com
Produktdatenblatt | Version 1.1
GB QSSPA1.13
GB QSSPA1.13
OSCONIQ ® P 3030
The OSCONIQ P 3030 Colors family LED comes
with well known superior robustness, high reliability,
long lifetime, low thermal resistance. Compact and
proven 3mm x 3mm package and established footprint. Perfectly addressing applications that demand
for high efficiency and long lifetime.
Applications
——Stage Lighting (LED & Laser)
——Accent (BAR)
——Architecture
Features:
——Package: SMD epoxy package
——Typ. Radiation: 120° (Lambertian emitter)
——Corrosion Robustness Class: 3B
——Lumen maintenance: Test results according to IESNA LM-80 available
——ESD: 8 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 3B)
——Luminous Flux: typ. 41 lm
——Luminous Efficacy: typ. 41 lm/W
1 Version 1.0 | 2019-04-23
GB QSSPA1.13
Ordering Information
Type
Luminous Flux 1)
IF = 350 mA
ΦV
33.0 ... 52.0 lm
2 Version 1.0 | 2019-04-23
Ordering Code
Q65112A8533
GB QSSPA1.13
Maximum Ratings
Parameter
Symbol
Operating Temperature
Top
min.
max.
-40 °C
125 °C
Storage Temperature
Tstg
min.
max.
-40 °C
125 °C
Junction Temperature
Tj
max.
135 °C
Forward current
IF
min.
max.
100 mA
1300 mA
Surge Current
t ≤ 10 µs; D = 0.005 ; TJ = 25 °C
IFS
max.
2000 mA
Reverse voltage 2)
VR
ESD withstand voltage
VESD
3 Version 1.0 | 2019-04-23
Values
Not designed for
reverse operation
8 kV
GB QSSPA1.13
Characteristics
IF = 350 mA; TJ = 25 °C
Parameter
Symbol
Peak Wavelength
λpeak
typ.
465 nm
Dominant Wavelength 3)
IF = 350 mA
λdom
min.
typ.
max.
464 nm
470 nm
476 nm
Spectral Bandwidth at 50% Irel,max
∆λ
typ.
25 nm
Viewing angle at 50% IV
2φ
typ.
120 °
Forward Voltage 4)
IF = 350 mA
VF
min.
typ.
max.
2.70 V
2.93 V
3.20 V
Reverse current 2)
IR
Electrical thermal resistance junction/solderpoint
with efficiency ηe = 54 %
RthJS elec.
4 Version 1.0 | 2019-04-23
Values
Not designed
for reverse
operation
typ.
4.1 K / W
GB QSSPA1.13
Brightness Groups
Group
Luminous Flux 1)
IF = 350 mA
min.
ΦV
Luminous Flux 1)
IF = 350 mA
max.
ΦV
HY
33.0 lm
39.0 lm
HZ
39.0 lm
45.0 lm
JX
45.0 lm
52.0 lm
Forward Voltage Groups
Group
Forward Voltage 4)
IF = 350 mA
min.
VF
Forward Voltage 4)
IF = 350 mA
max.
VF
K2
2.70 V
2.80 V
L1
2.80 V
2.90 V
L2
2.90 V
3.00 V
M1
3.00 V
3.10 V
M2
3.10 V
3.20 V
5 Version 1.0 | 2019-04-23
GB QSSPA1.13
Wavelength Groups
Group
IF = 350 mA
min.
λdom
IF = 350 mA
max.
λdom
3
464 nm
468 nm
4
468 nm
472 nm
5
472 nm
476 nm
6 Version 1.0 | 2019-04-23
GB QSSPA1.13
Group Name on Label
Example: HY-3-K2
Brightness
Wavelength
HY
3
7 Version 1.0 | 2019-04-23
Forward Voltage
K2
GB QSSPA1.13
Relative Spectral Emission
5)
Irel = f (λ); IF = 350 mA; TJ = 25 °C
Irel
GB QSSPA1.13
1,0
: Vλ
: blue
0,8
0,6
0,4
0,2
0,0
350
400
Radiation Characteristics
450
500
550
600
650
700
750
800
λ / nm
5)
Irel = f (ϕ); TJ = 25 °C
GB QSSPA1.13
ϕ/°
-40°
-50°
-20°
-10°
0° 10° 20° 30° 40° 50° 60° 70° 80° 90°
1,0
-30°
0,8
0,6
-60°
-70°
0,4
-80°
0,2
-90°
0,0
-100°
8 Version 1.0 | 2019-04-23
Irel
GB QSSPA1.13
Forward current
Relative Luminous Flux
5)
IF = f(VF); TJ = 25 °C
IF / mA
5), 6)
Φv/Φv(350 mA) = f(IF); TJ = 25 °C
GB QSSPA1.13
1300
ΦV
GB QSSPA1.13
2,5
ΦV(350mA)
1200
2,0
1000
800
1,5
600
1,0
400
Dominant Wavelength
5)
Δλdom = f(IF); TJ = 25 °C
∆λ dom / nm
GB QSSPA1.13
8
6
4
2
-4
13
00
10
00
80
IF / mA
9 Version 1.0 | 2019-04-23
13
00
3,4
VF / V
80
00
3,2
60
40
2,7 2,8
10
200
IF / mA
GB QSSPA1.13
Forward Voltage
5)
ΔVF = VF - VF(25 °C) = f(Tj); IF = 350 mA
∆VF / V
0,2
GB QSSPA1.13
5)
Φv/Φv(25 °C) = f(Tj); IF = 350 mA
Φv
1,2
GB QSSPA1.13
Φv(25°C)
0,1
1,1
0,0
1,0
-0,1
0,9
-0,2
-40 -20 0
20 40 60 80 100 120
Tj / °C
Dominant Wavelength
5)
Δλdom = λdom - λdom(25 °C) = f(Tj); IF = 350 mA
∆λ dom / nm
6
4
2
GB QSSPA1.13
-4
20 40 60 80 100 120
Tj / °C
-6
-40 -20 0
10 Version 1.0 | 2019-04-23
0,8
-40 -20 0
20 40 60 80 100 120
Tj / °C
GB QSSPA1.13
Max. Permissible Forward Current
IF = f(T)
GB QSSPA1.13
IF / mA 1300
1200
1100
1000
900
800
700
600
500
400
300
200
100
Do not use below 100 mA
60
11 Version 1.0 | 2019-04-23
80
100
120
Ts / °C
GB QSSPA1.13
Dimensional Drawing
7)
Further Information
Approximate Weight:
24.0 mg
Package marking:
Anode
Corrosion test:
Class: 3B
Test condition: 40°C / 90 % RH / 15 ppm H2S / 14 days (stricter than IEC
60068-2-43)
ESD advice:
The device is protected by ESD device which is connected in parallel to the
Chip.
12 Version 1.0 | 2019-04-23
GB QSSPA1.13
Recommended Solder Pad
7)
For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not
suitable for ultra sonic cleaning.
13 Version 1.0 | 2019-04-23
GB QSSPA1.13
Reflow Soldering Profile
Product complies to MSL Level 3 acc. to JEDEC J-STD-020E
OHA04525
300
˚C
T 250
Tp 245 ˚C
240 ˚C
tP
217 ˚C
200
tL
150
tS
100
50
25 ˚C
100
150
200
250
s 300
t
Profile Feature
Symbol
Pb-Free (SnAgCu) Assembly
Minimum
Recommendation Maximum
Ramp-up rate to preheat*)
25 °C to 150 °C
tS
Time tS
TSmin to TSmax
Ramp-up rate to peak*)
TSmax to TP
Liquidus temperature
60
2
3
100
120
2
3
Unit
K/s
s
K/s
TL
217
Time above liquidus temperature
tL
80
100
s
Peak temperature
TP
245
260
°C
Time within 5 °C of the specified peak
temperature TP - 5 K
tP
3
6
Ramp-down rate*
TP to 100 °C
10
Time
25 °C to TP
All temperatures refer to the center of the package, measured on the top of the component
* slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range
14 Version 1.0 | 2019-04-23
°C
480
s
K/s
s
GB QSSPA1.13
Taping
7)
15 Version 1.0 | 2019-04-23
GB QSSPA1.13
Tape and Reel
8)
Reel Dimensions
A
180 mm
W
Nmin
12 + 0.3 / - 0.1 mm
16 Version 1.0 | 2019-04-23
W1
60 mm
W2 max
12.4 + 2 mm
18.4 mm
Pieces per PU
600
GB QSSPA1.13
Barcode-Product-Label (BPL)
Dry Packing Process and Materials
7)
Moisture-sensitive label or print
L
E
E
V
l
e be
sela
k,
H
de
L
If
an
bl r co
ba
(R
id
m
ity
H
R
hu
0%
e
e
/6
tiv
˚C
la ared ag
ck
re
fr
30
_
in pa
k
of
to
90
rs
ea
s
d
rs
ou
or
te (p
on
rs
H
de
ou
iti
H
an bjec ng
ou rs
co
˚C
72
si
nd
H ou
5
te
48
˚C su es
e
H
co
24 6
da
e
y
40 be oc
tim
˚C
e
or
ith
tim
ill pr).
or
ct
w
O
w nt
23
tim e
at
lo
or
fa
M TO
F
s
al
tim
at le ˚C at
lo
at
or
e.
P
th
F
l
tic
th va
lo or
ur
O
F lo
s ui
on
be
if: read
en
w
ed
l 4 5
F
m
la
ce eq
id
lo
g, n
oc
l
ve
vi
5a
is
in
or
be
24
de
pr
ve l
6
Le
de ,
nt whe
e
te
co
g:
, w
e
Le ve l
ke
r
ou
se
da
ba ed flo
ur
e
Le ve
m %
ba
e
ba
al
st
ur e
Le
r
en re
ed
e
re> 10
oi
st
e
e
fo
tim
ur
se
al
op
fo
M
se
oi st ur
as
k,
is
or .
33
se
is
M oi st
bed
k,
lo H
an
g ph
-0
M oi
in
an in F R ng ar
rbl
D
M
e
ba
T
r
po If bl ith
lif
ki r C.
(if
S
is
p.
w
ea r ks
lf
J10 ba to et
th va
Y ea
m
rs
m
_
r w,
he
ed
1
ee
te
Y
d, EC
iredicat
S
fte
at
nt
1
W Hou
D
A flody
qu In no ire
1.
d
e
ou
4 8
re
reity is
qu/JE
re
2.
bo
e
M
tim
to es id 2b
re C
16
e
a)
S
tim
is IP
ic
ed loor
tim e
b) ev Humor
or
e
en
F
tim
lo
or
D
2a king
nc
te
F
op
a)
lo or
3.
b) ba re
F lo
da
e
fe
l 1 2
F
If
al
re
tim ve
l
4.
se
d
l 2a
ve
Le
3
an
ve l
ag
e
Le
e
B
ve
ur
e
Le
at
st
ur
e
Le
D
oi
st
ur e
M
oi
st ur
M
oi st
M oi
M
N
E RS
s
in IV O
IT T
S C
nta
N U
TIO
U coSEND
Ais bUagRMEICO
T E
CThIS
S
d
Barcode label
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
Desiccant
AM
OSR
OHA00539
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033.
17 Version 1.0 | 2019-04-23
GB QSSPA1.13
Schematic Transportation Box
7)
Barcode label
N
O
(Q
)Q
TY
:2
00
D
D
/C
:0
(X
Packing
Sealing label
Length
195 ± 5 mm
195 ± 5 mm
18 Version 1.0 | 2019-04-23
M
Y
DE
-1
+Q
-1
R
18
P
OHA02044
Dimensions of Transportation Box
Width
RO
UP
M
RA
OS
PR
O
D
5
14 2
110 0
G
4
01
4
C:
D/
(9
D)
(Q
)Q
TY
O
TC
P)
(6
T
LO
(1
T)
O
D
PR
D
EM
Y
18
R
-1
Q
P
-1
G
R
O
U
P:
u L
lt S
iT Y
O T6
P 7
L 6
M
14
4
(G
E Bi
D Bi n1
Bi n2 : Pn3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R ditio 0 C R
07
PA 7 na RT
l TE
C
KV
XT
AR
Muster
A
o M
n O
d
u p
cto to
rs
R
34
ic
N
O
O
S
H
12
G
BA
TC
H
(1
T)
LO
T
N
O
:1
(6
P)
23
em
8
2199
2100
5
14 2
110 0
(X
O
M O
PT
O
M
998
NO
CThISTU
SE
S
21
2100
BA
_
s
ur s
Ho ururs s
de
Ho
co
72
Ho ur
te
48
e
Ho
24 6
da
40 be
tim e e
˚C
or
th
r
pr
ll
tim
ct
23
oo r
wi nt
tim e
at
l wi
fa
r
Fl oo
tim
s
at
at le ˚C at
e.
ica
l
Fl
th
oo r
th va
ur
nt
Fl oo
s ui
be
on
if: read
w
ed
l 4 5
Fl
la
m
ide
ce eq
lo
g,
oc
ve l
vi
is
in en
de
be
24 de or
l 5a6
pr
Le ve
nt wh
e
te
co
, w,
g:
ve l
Le
ke
r
re
ou
se
da
ba ed flo ba
Le ve
tu re
m %
ba
e
al
e
Le
r
en re
e
ed
re 10
ois stu ur e
tim
se
fo
al
op se
fo >
M oi
r
se
st ur
3
is
is ha
se
M
oi st
nk
be
k,
oo .
03
rd
g
M oi
in
an in Fl RH g,
r-p
bla
DM
ba
Ca
po If bl th
kinr
life is
(if
ar
ST
f
p.
wi
10 ba to et
Jel r th va
Ye ar ks s
m
_
cat m d, C
ed
1
Ye ee ur
ire
Sh te w, te
di
at
nt
1
W Ho
Af flody
qu In no ire DE
1.
e
ou
4 8
re
ed re
qu JE
2.
bo
ity is
M
or
tim e e
16
re C/
es id 2b
r
a)
St
tim
mor
is IP
ed
oo r
tim e
vic
b)
g e
r
Hu
Fl oo
en
tim
De
2a kin nc
te
Fl oo r
a)
op
3.
b) ba re
Fl oo
da
e
fe
l 1
Fl
If
al
re
tim ve l 2
4.
se
d
l 2a3
Le ve
g
an
ve l
e
Le
Ba
te
ur e
Le ve
Le
Da oist stur e
ur e
M
oi
st ur
M
oi st
M oi
H
12
34
RH
0%
/6
˚C
L
e el
selab
H)
nk de
co
(R
bla
r
S S
em R
ic AM
o
n O
d
u p
ct to
o
H
rs
NO
If
23
G
E
V
E
ba
ity
id
m
hu
e
e
d
tiv
re ag
NO
:1
L
la
re
fra ck
30
Nns IVE RS
in pa
k
of
ai IT TO
to
90
ea
d
ntNS
ns
UC
or
TIO
te (p
d
g
itio
ND
U g coSE
an bjec
˚C
sin
nd
O
5
˚C su es
Ais baRE
co
IC
y
M
oc
(G
M
u L
lt S
iT Y
O T6
P 7
L 6
E
D
Muster
Bi
Bi n1
Bi n2 : P-
n3 : Q 1: -1 20
M
-2
2 L
Te
2a
22 m
3
24 0 p ST
Ad 26 0 C R
C
R0 ditio 0 C R
PA 77 na RT
l TE
CK
VA
XT
R:
Barcode label
Height
30 ± 5 mm
GB QSSPA1.13
Notes
The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of
lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this
data sheet falls into the class moderate risk (exposure time 0.25 s). Under real circumstances (for exposure
time, conditions of the eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources
have a high secondary exposure potential due to their blinding effect. When looking at bright light sources
(e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation.
Subcomponents of this device contain, in addition to other substances, metal filled materials including silver.
Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage,
production, and use. Devices that showed visible discoloration when tested using the described tests above
did show no performance deviations within failure limits during the stated test duration. Respective failure
limits are described in the IEC60810.
This device is designed for specific/recommended applications only. Please consult OSRAM Opto
Semiconductors Sales Staff in advance for detailed information on other non-recommended applications
(e.g. automotive).
Change management for this component is aligned with the requirements of the lighting market.
For further application related information please visit www.osram-os.com/appnotes
19 Version 1.0 | 2019-04-23
GB QSSPA1.13
Disclaimer
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version on the OSRAM OS website.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest
sales office.By agreement we will take packing material back, if it is sorted. You must bear the costs of
transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we
shall have to invoice you for any costs incurred
Product and functional safety devices/applications or medical devices/applications
OSRAM OS components are not developed, constructed or tested for the application as safety relevant
component or for the application in medical devices.
OSRAM OS products are not qualified at module and system level for such application.
In case Buyer – or Customer supplied by Buyer – considers using OSRAM OS components in product safety devices/applications or medical devices/applications, Buyer and/or Customer has to inform the local sales
Partner of OSRAM OS immediately and OSRAM OS and Buyer and /or Customer will analyze and coordinate the customer-specific request between OSRAM OS and Buyer and/or Customer.
20 Version 1.0 | 2019-04-23
GB QSSPA1.13
Glossary
1)
Brightness: Brightness values are measured during a current pulse of typically 10 ms, with a tolerance
of +/- 7%.
2)
Reverse Operation: Not designed for reverse operation. Continuous reverse operation can cause migration and damage of the device.
3)
Wavelength: The wavelength is measured at a current pulse of typically 10 ms, with a tolerance of ±
0.5 nm.
4)
Forward Voltage: The Forward voltage is measured during a current pulse duration of typically 1 ms
with a tolerance of ± 0.05V .
5)
Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures.
These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g.
because of technical improvements, these typ. data will be changed without any further notice.
6)
Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit.
7)
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
8)
Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.
21 Version 1.0 | 2019-04-23
GB QSSPA1.13
Revision History
Version
Date
Change
1.0
2019-04-23
Initial Version
22 Version 1.0 | 2019-04-23
GB QSSPA1.13
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
23 Version 1.0 | 2019-04-23
