SFH 5701
SFH 5701
    AMSOSRAM(艾迈斯半导体)
    SMD2
    SENSOR OPT 600NM AMBIENT SMD
SFH 5701 数据手册
2018-01-22 Ambient Light Sensor Preliminary Version 0.2 SFH 5701 Features: • Analog output current is proportional to Ambient Light Intensity • Spectral response close to human eye sensitivity • Integrated dark current suppression • Built in thermal compensation • Linear response over 6 decades of illumination range Applications • Control of display backlighting • Mobile devices • Home automation/ smart speakers • Smart TV • Industrial displays • Smart lighting control Ordering Information Type: Output current Ordering Code IOUT [µA] VDD = 5 V, EV = 100 lx (white LED) SFH 5701 Note: typ. 135 Q65112A5752 Only one bin within one packing unit, see characteristics. 2018-07-09 1 Preliminary – For Reference only. Subject to change. Preliminary Version 0.2 SFH 5701 Maximum Ratings (TA = 25 °C) Parameter Symbol Values Unit Operation temperature range Top -40 ... 100 °C Storage temperature range Tstg -40 ... 100 °C Supply voltage Vddmax 6 V Supply current (internally limited) Iddmax 15 mA Forward voltage VF 0.56 V Forward current IF 0.5 mA ESD withstand voltage (acc. to ANSI/ ESDA/ JEDEC JS-001 - HBM) VESD 2000 V ESD withstand voltage (acc. to ANSI/ ESDA/ JEDEC JS-002 - CDM) VESD 750 V ESD withstand voltage (acc. to ANSI/ ESDA/ JESD22-A115-MM) VESD 400 V Operating Conditions Parameter Symbol Values min typ Unit max Supply voltage (for the choice of RLOAD refer to Appnote AN132) Vdd 1.45 5.5 V Supply current (VDD = 5 V, for the choice of RLOAD refer to Appnote AN132) Idd 0.01 10k µA Illuminance range EV 0.01 10k lx Characteristics (TA = 25 °C) Parameter Symbol Values Unit 1 µA/ lx Spectral sensitivity (VDD = 5 V, EV = 100 lx, white LED) (typ) S Wavelength of max. sensitivity (typ) λS max 600 nm Spectral range of sensitivity (min) (max) λ10% λ10% 450 705 nm nm Dimensions of radiant sensitive area (typ) LxW 0.33 x 0.33 Half angle (typ) ϕ Output impedance (typ) ZOUT Forward voltage ( IF = 200 µA, E = 0) (typ) VF 2018-07-09 2 Preliminary – For Reference only. Subject to change. ± 60 10 0.52 mm x mm ° MΩ V Preliminary Version 0.2 SFH 5701 Parameter Symbol Values Unit Supply current ( VDD = 5 V, EV = 100 lx (white LED)) (typ) Idd 135 µA Output dark current (VDD = 5 V, EV = 0 lx ) (typ) (max) IOUT_dark IOUT_dark 3.4 50 nA nA Rise time (RL = 33 kΩ, EV = 100 lx, for different testing conditions refer to the Appnote AN132) (typ) tr 14 ms Temperature coefficient (typ) TC IOUT Relative Spectral Sensitivity 1) page 12 Photodiode Srel = f(λ) -0.07 %/ K Output Current 1) page 12 IOUT = f(EV); white LED; VDD = 5 V 100 10 5 90 10 V 80 human eye sensitivity 10 70 [µA] S rel 50 I S OUT [%] 60 rel 4 40 30 10 10 10 3 2 1 0 20 10 -1 10 0 400 10 500 600 700 800 900 1000 1100 -2 10 -2 10 -1 [nm] 2018-07-09 10 0 E 10 V 3 Preliminary – For Reference only. Subject to change. 1 [lx] 10 2 10 3 10 4 Preliminary Version 0.2 SFH 5701 Dark Current 1) page 12 Idark = f(VDD) 1.2 -7 1.1 [a.u.] 10 -6 -8 1.0 I I dark [A] 10 IOUT(T) / IOUT(25°C)= f(TA); Ev = 100lx; white LED; VDD = 5 V OUT 10 Output Current 1) page 12 10 0.9 -9 100° 80° 25° 10 0.8 -10 1 2 3 V 4 DD 5 -40 6 20 T A 40 60 80 100 [°C] Forward Current 1) page 12 IF = f(VF) -7 10 10 10 0 [V] Dark Current 1) page 12 Idark = f(TA) 10 -20 4 3 -8 2 I I F dark [µA] [µA] 10 10 10 -9 10 10 -40 0 -1 -10 -20 0 20 T 2018-07-09 1 A 40 60 80 10 0.30 100 0.35 0.40 [°C] 0.45 0.50 V F 4 Preliminary – For Reference only. Subject to change. 0.55 [V] 0.60 0.65 0.70 Preliminary Version 0.2 SFH 5701 Directional Characteristics (Horizontal) 1) page 12 Photodiode Srel = f(ϕ) 40 30 20 10 ϕ 0 OHF01402 1.0 50 0.8 60 0.6 70 0.4 80 0.2 0 90 100 1.0 0.8 0.6 0.4 0 20 40 60 Package Outline Dimensions in mm. 2018-07-09 5 Preliminary – For Reference only. Subject to change. 80 100 120 Preliminary Version 0.2 SFH 5701 Pinning Pin Description 1 anode (OUT) 2 cathode (VDD) Approximate Weight: 3.8 mg Recommended Solder Pad Dimensions in mm. 2018-07-09 6 Preliminary – For Reference only. Subject to change. Preliminary Version 0.2 SFH 5701 Reflow Soldering Profile Product complies to MSL Level 4 acc. to JEDEC J-STD-020E OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 s 300 250 t OHA04612 Profile Feature Profil-Charakteristik Symbol Symbol Pb-Free (SnAgCu) Assembly Minimum ) Ramp-up rate to preheat* 25 °C to 150 °C Time tS TSmin to TSmax tS 60 Ramp-up rate to peak*) TSmax to TP Recommendation Maximum 2 3 100 120 2 3 Unit Einheit K/s s K/s Liquidus temperature TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 s 3 6 K/s 10 Ramp-down rate* TP to 100 °C 480 Time 25 °C to TP All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 2018-07-09 °C 7 Preliminary – For Reference only. Subject to change. s Preliminary Version 0.2 SFH 5701 Taping Dimensions in mm. Tape and Reel 8 mm tape with 3000 pcs. on ∅ 180 mm reel W1 D0 P0 A N F W E 13.0 ±0.25 P2 Label P1 Direction of unreeling Direction of unreeling W2 Leader: min. 400 mm * Trailer: min. 160 mm * *) Dimensions acc. to IEC 60286-3; EIA 481-D OHAY0324 2018-07-09 8 Preliminary – For Reference only. Subject to change. Preliminary Version 0.2 SFH 5701 Tape dimensions [mm] Tape dimensions in mm W P0 P1 P2 D0 E F 8 + 0.3 / -0.1 4 ± 0.1 2 ± 0.05 or 4 ± 0.1 2 ± 0.05 1.5 ± 0.1 1.75 ± 0.1 3.5 ± 0.05 Reel dimensions [mm] Reel dimensions in mm A W Nmin W1 W2max 180 8 60 8.4 + 2 14.4 Barcode-Product-Label (BPL) Dry Packing Process and Materials Moisture-sensitive label or print L VE el LE see . lab e H) nk, (R bla cod If y bar . dit RH mi % hu e /60 ve ed ag ˚C ati rar ck rel 30 _ < inf pa % of to ak 90 urs d ). < ns (pe or urs d Ho de , cte itio urs Ho an bje ing co ˚C 72 nd Ho urs 5 te 48 ˚C su ss e Ho co ± ce 24 6 da e y 40 be tim ˚C e th < tor ll pro tim or ). 23 tim e at t wi nt˚C or l wi fac Flo tim s at or ca at re. Flo d tha ale el or nth nti Flo uiv du if: rea es l 4 5 Flo lab mo ide ce eq low g, l ve vic is be or de 24 tin en l 5a6 pro ve Le de , e te co , ve l un wh Le ke r se da ure ba ed low ba Le ve mo % ba e al d ure Le ist en ref e e 10 tim ure se for ist ale op se for > , Mo se 3 ist ure is or . , is ha se Mo nk be ist nk g rd -03 Mo in n Flo r-p RH g, bla Mo ba TD po If blathi % kin Ca life s (if ar t. wi 10 ba tor J-S thi, va p. elf Ye ar ks _ < e icat me , C 1 Ye ee urs Sh terlow tem ted at ed uir > 1 W Ho un Af Indno uir DE 1. d e 4 8 ref dy reqy is 2. JE bo e Mo ore tim 16 req : C/ e es dit2b a) St tim or mi IP ed or g is tim e vic b) or e Hu Flo en tim or De 2a kin nc te Flo a) op or 3. b) baere Flo da e l 1 2 Flo If al ref tim ve l 4. se d l 2a3 ve Le g an ve l Le Ba te ure Le ve ure Le ist Da ure ist Mo ist ure Mo ist Mo Mo Barcode label N s VE RS ainITI TO ntNSUC TIO U g coSEND CO Ais baRE TU MI CThIS SE MO TO OP g: M RA OS Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 AM Desiccant OSR OHA00539 Note: Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card. Regarding dry pack you will find further information in the internet. Here you will also find the normative references like JEDEC. 2018-07-09 9 Preliminary – For Reference only. Subject to change. Preliminary Version 0.2 SFH 5701 Transportation Packing and Materials Barcode label el . H) 8 D) Y DE M R 18 + Q -1 -1 P P: OU GR D/ C: 00 21 99 8 (9 21 20 : TY : (Q 5 14 2 T LO T) (1 : NO M DE + Q -1 R 18 P -1 G RO UP : (G ) C: 99 D/ (Q )Q TY : SR AM 20 00 O 21 u M 00 (9 D) n d 21 o : 34 NO 5 14 2 em H 12 S TC H O D (X ) PR NO O : (1 T) 11 00 LO T (6 P) NO : 12 BA 3G O S R ic A 01 ct pto o rs 44 Muster Y Bi n2 : P- n3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R0 ditio 0 C R PA 77 na RT l TE CK VA XT R: (X ) PR OD C M u L lt S iT Y O T67 P L 6 E Bi D Bi n1 )Q on M du O ct pto or s R A 34 ic O S NO NO (6 P) : 12 S 3G BA TC H em H 12 . RH 0% /6 ˚C 01 44 (R ty idi m e ag _ < s ur s ). ur s Ho de ur s Ho co 72 Ho ur te 48 e Ho 24 6 da e 40 be ry tim ˚C e Th STSE r th < ll pr tim cto ). r OI oo 23 wi nt tim e at l wi fa r M TO Fl oo tim s at at ale ˚C at e. ica Fl th oo r th ur el OP nt Fl oo on es uiv if: read ed l 4 5 Fl , lab m ide eq low l oc ve vic is ingen be or de 24 l 5a6 pr ve Le de nt wh e te co , w, g: ve l Le ke r re ou se da ba ed flo Le ve tu re m % ba e ba al d Le r en re tu re e re 10 ois tim se fo tu re ale op se fo > , M r se ois 3 is , is ha se M ois tu nk be oo . 03 nk g rd M ois in r-p bla in Fl RH g, DM ba po If blath % kin Ca life is (if . ar ST p. wi 10 baator et Jelf r th va Ye ar ks s m _ < m ed 1 Ye ee ur d, C iredic t Sh te w, te at nt > 1 W Ho Af flody qu In no ire DE 1. e 4 8 ou re ed is re qu JE ty 2. bo e M or tim 16 re C/ : e es idi 2b r a) St tim mor is IP ed r oo tim e vic b) g e r Hu Fl en oo tim De 2a kin nc te Fl oo r a) op 3. b) ba re Fl oo da e fe l 1 2 Fl If al re tim ve l 4. se d l 2a3 ve Le g an ve l Le re Ba te Le ve tu re Le tu Da ois re tu re M ois M ois tu M ois M 11 00 bla r ba d re lat ra ck re 30 Nns IVEORS inf pa % k ai IT of to 90 ea d ntNS CT < ns (p TIO or d , cteg DU itio U g EcoSE an bje ˚C sin nd ON 5 ˚C su es Ais ba IC co ± UR M oc 00 see lab e nk, cod If hu ive ) L E V LE (G M u L lt S iT Y O T67 P L 6 Muster E Bi D Bi n1 Bi n2 : Pn3 : Q- 1: 1- 20 M 20 2 L Te 2a 22 m 3 24 0 p ST Ad 26 0 C R 0 C R0 dit ion C R PA 77 al RT CK TE VA XT R: Barcode label Packing Sealing label Dimensions of transportation box in mm Width Length Height 200 ± 5 195 ± 5 30 ± 5 2018-07-09 10 Preliminary – For Reference only. Subject to change. OHA02044 Preliminary Version 0.2 SFH 5701 Disclaimer OSRAM OS assumes no liability whatsoever for any use of this document or its content by recipient including, but not limited to, for any design in activities based on this preliminary draft version. OSRAM OS may e.g. decide at its sole discretion to stop developing and/or finalising the underlying design at any time. Language english will prevail in case of any discrepancies or deviations between the two language wordings. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization.?If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. ?By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2018-07-09 11 Preliminary – For Reference only. Subject to change. Preliminary Version 0.2 SFH 5701 Glossary 1) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg ww.osram-os.com © All Rights Resered. 2018-07-09 12 Preliminary – For Reference only. Subject to change.
SFH 5701 价格&库存
很抱歉,暂时无法提供与“SFH 5701”相匹配的价格&库存,您可以联系我们找货
