SU CULBN2.VC-AGAM-67-4F4G-30-R18 数据手册
www.osram-os.com
SU CULBN2.VC
DATASHEET
SU CULBN2.VC
Datasheet
Published by ams-OSRAM AG
Tobelbader Strasse 30, 8141 Premstaetten, Austria
Phone +43 3136 500-0
ams-osram.com
© All
reserved
| Version
1.0 | 2022-05-12
1 rights
SU CULBN2.VC
DATASHEET
OSLON® UV 3535
SU CULBN2.VC
This compact UV-C LED is part of the OSLON UV series.
It allows a flexible design for any application which requires
UV-C radiation.
Applications
- Horticulture Treatment
- UV-C Treatment
- Sensing
Features
- Package: Ceramic package with integrated glass cover
- Chip technology: AlGaN based flip chip
- Typ. Radiation: 120° (Lambertian emitter)
- Color: λpeak = 275 nm (● ultraviolet (UV-C))
- ESD: 5 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM)
- Radiant Flux: typ. 5.2 mW
- Radiant Efficiency: typ. 2.9 %
2 | Version 1.0 | 2022-05-12
SU CULBN2.VC
DATASHEET
Ordering Information
Type
Total radiant flux 1)
IF = 30 mA
ΦE
4.0 ... 7.0 mW
Ordering Code
Q65113A4848
3 | Version 1.0 | 2022-05-12
SU CULBN2.VC
DATASHEET
Maximum Ratings
Parameter
Symbol
Operating Temperature
Top
min.
max.
-40 °C
60 °C
Storage Temperature
Tstg
min.
max.
-40 °C
100 °C
Junction Temperature
Tj
max.
85 °C
Forward current
TS = 25 °C
IF
min.
max.
1 mA
40 mA
Surge Current
TS = 25 °C
IFS
max.
50 mA
ESD withstand voltage
VESD
Reverse voltage 2)
VR
4 | Version 1.0 | 2022-05-12
Values
5 kV
Not designed for
reverse operation
SU CULBN2.VC
DATASHEET
Characteristics
IF = 30 mA; TS = 25 °C
Parameter
Symbol
Peak Wavelength 3)
λpeak
min.
typ.
max.
Viewing angle at 50% IV
2φ
typ.
120 °
Forward Voltage
IF = 30 mA
VF
min.
typ.
max.
5.50 V
5.80 V
6.50 V
Reverse current 2)
IR
Real thermal resistance junction/solderpoint 5)
RthJS real
typ.
40 K / W
Electrical thermal resistance junction/solderpoint
with efficiency ηe = 2.72 %
RthJS elec.
typ.
38 K / W
4)
5 | Version 1.0 | 2022-05-12
Values
270 nm
275 nm
280 nm
Not designed
for reverse
operation
SU CULBN2.VC
DATASHEET
Brightness Groups
Group
IF = 30 mA
min.
ΦE
IF = 30 mA
max.
ΦE
AG
4.0 mW
4.5 mW
AH
4.5 mW
5.0 mW
AJ
5.0 mW
5.5 mW
AK
5.5 mW
6.0 mW
AL
6.0 mW
6.5 mW
AM
6.5 mW
7.0 mW
Forward Voltage Groups
Group
Forward Voltage 4)
IF = 30 mA
min.
VF
Forward Voltage 4)
IF = 30 mA
max.
VF
4F
5.50 V
6.00 V
4G
6.00 V
6.50 V
Wavelength Groups
Group
6
Peak Wavelength 3)
max.
λpeak
270 nm
275 nm
275 nm
280 nm
7
Peak Wavelength 3)
min.
λpeak
6 | Version 1.0 | 2022-05-12
SU CULBN2.VC
DATASHEET
Group Name on Label
Example: AG-6-4F
Brightness
Wavelength
AG
6
7 | Version 1.0 | 2022-05-12
Forward Voltage
4F
SU CULBN2.VC
DATASHEET
Relative Spectral Emission
6)
Irel = f (λ); IF = 30 mA; TS = 25 °C
Irel
SU CULBN2.VC
1,0
: ultra violet
0,8
0,6
0,4
0,2
0,0
200 210 220 230 240 250 260 270 280 290 300 310 320 330 340 350
λ / nm
Radiation Characteristics
6)
Irel = f (ϕ); TS = 25 °C
SU CULBN2.VC
ϕ/°
-40°
-50°
-20°
-10°
0° 10° 20° 30° 40° 50° 60° 70° 80° 90°
1,0
-30°
0,8
0,6
-60°
-70°
0,4
-80°
0,2
-90°
0,0
-100°
8 | Version 1.0 | 2022-05-12
Irel
SU CULBN2.VC
DATASHEET
Forward current
Relative Radiant Power
6)
IF = f(VF); TS = 25 °C
IF / mA
6), 7)
ΦE/ΦE(30 mA) = f(IF); TS = 25 °C
SU CULBN2.VC
Φe
SU CULBN2.VC
40
Φe(30mA)
35
1,2
30
1,0
25
0,8
15
0,4
10
0,2
Peak Wavelength
6)
λpeak = f(Tj); IF = 30 mA
SU CULBN2.VC
∆λ peak / nm
4
2
40
35
30
25
10
2
5
-4
IF / mA
9 | Version 1.0 | 2022-05-12
40
35
30
6,0
VF / V
25
5,8
15
5,4
10
2
5,1 5,2
2
5
5
IF / mA
SU CULBN2.VC
DATASHEET
Forward Voltage
6)
ΔVF = VF - VF(25 °C) = f(Tj); IF = 30 mA
6)
ΦE/ΦE(25 °C) = f(Tj); IF = 30 mA
SU CULBN2.VC
Φe
∆VF / V
SU CULBN2.VC
1,2
Φe (25°C)
0,6
1,0
0,4
0,8
0,2
0,6
0,0
0,4
-0,2
0,2
-0,4
-40
-20
Peak Wavelength
60 80
Tj / °C
6)
∆λ peak / nm
SU CULBN2.VC
6
4
2
-4
-20
10 | Version 1.0 | 2022-05-12
40
60 80
Tj / °C
0,0
-40
-20
60 80
Tj / °C
SU CULBN2.VC
DATASHEET
Max. Permissible Forward Current
IF = f(T)
IF / mA
SU CULBN2.VC
45
40
35
30
25
10
5
11 | Version 1.0 | 2022-05-12
40
50
60
Ts / °C
SU CULBN2.VC
DATASHEET
Dimensional Drawing
8)
Further Information:
Approximate Weight:
81.0 mg
Package marking:
Cathode
ESD advice:
LED is protected by ESD device which is connected in parallel to LED-Chip.
12 | Version 1.0 | 2022-05-12
SU CULBN2.VC
DATASHEET
Recommended Solder Pad
8)
For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Further information can be found in our Application Note: “Handling and Processing Details for Ceramic LEDs”. Package not suitable for any
kind of wet cleaning or ultrasonic cleaning.
13 | Version 1.0 | 2022-05-12
SU CULBN2.VC
DATASHEET
Reflow Soldering Profile
Product complies to MSL Level 3 acc. to JEDEC J-STD-020E
OHA04525
300
˚C
T 250
Tp 245 ˚C
240 ˚C
tP
217 ˚C
200
tL
150
tS
100
50
25 ˚C
100
150
200
250
s 300
t
Profile Feature
Symbol
Pb-Free (SnAgCu) Assembly
Minimum
Recommendation Maximum
Ramp-up rate to preheat*)
25 °C to 150 °C
tS
Time tS
TSmin to TSmax
Ramp-up rate to peak*)
TSmax to TP
Liquidus temperature
60
2
3
100
120
2
3
Unit
K/s
s
K/s
TL
217
Time above liquidus temperature
tL
80
100
s
Peak temperature
TP
245
260
°C
Time within 5 °C of the specified peak
temperature TP - 5 K
tP
3
6
Ramp-down rate*
TP to 100 °C
10
Time
25 °C to TP
All temperatures refer to the center of the package, measured on the top of the component
* slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range
14 | Version 1.0 | 2022-05-12
°C
480
s
K/s
s
SU CULBN2.VC
DATASHEET
Taping
8)
15 | Version 1.0 | 2022-05-12
SU CULBN2.VC
DATASHEET
Tape and Reel
9)
Reel Dimensions
A
180 mm
W
Nmin
12 + 0.3 / - 0.1 mm
16 | Version 1.0 | 2022-05-12
W1
60 mm
W2 max
12.4 + 2 mm
18.4 mm
Pieces per PU
500
SU CULBN2.VC
DATASHEET
Barcode-Product-Label (BPL)
Dry Packing Process and Materials
8)
Moisture-sensitive label or print
L
E
E
V
l
e be
sela
k,
H
de
L
If
an
bl r co
ba
(R
id
m
ity
H
R
hu
0%
e
e
/6
tiv
˚C
la ared ag
ck
re
fr
30
_
in pa
k
of
to
90
rs
ea
s
d
rs
ou
or
te (p
on
rs
H
de
ou
iti
H
an bjec ng
ou rs
co
˚C
72
si
nd
H ou
5
te
48
˚C su es
e
H
co
24 6
da
e
y
40 be oc
tim
˚C
e
or
ith
tim
ill pr).
or
ct
w
O
w nt
23
tim e
at
lo
or
fa
M TO
F
s
al
tim
at le ˚C at
lo
at
or
e.
P
th
F
l
tic
th va
lo or
ur
O
F lo
s ui
on
be
if: read
en
w
ed
l 4 5
F
m
la
ce eq
id
lo
g, n
oc
l
ve
vi
5a
is
in
or
be
24
de
pr
ve l
6
Le
de ,
nt whe
e
te
co
g:
, w
e
Le ve l
ke
r
ou
se
da
ba ed flo
ur
e
Le ve
m %
ba
e
ba
al
st
ur e
Le
r
en re
ed
e
re> 10
oi
st
e
e
fo
tim
ur
se
al
op
fo
M
se
oi st ur
as
k,
is
or .
33
se
is
M oi st
bed
k,
lo H
an
g ph
-0
M oi
in
an in F R ng ar
rbl
D
M
e
ba
T
r
po If bl ith
lif
ki r C.
(if
S
is
p.
w
ea r ks
lf
J10 ba to et
th va
Y ea
m
rs
m
_
r w,
he
ed
1
ee
te
Y
d, EC
iredicat
S
fte
at
nt
1
W Hou
D
A flody
qu In no ire
1.
d
e
ou
4 8
re
reity is
qu/JE
re
2.
bo
e
M
tim
to es id 2b
re C
16
e
a)
S
tim
is IP
ic
ed loor
tim e
b) ev Humor
or
e
en
F
tim
lo
or
D
2a king
nc
te
F
op
a)
lo or
3.
b) ba re
F lo
da
e
fe
l 1 2
F
If
al
re
tim ve
l
4.
se
d
l 2a
ve
Le
3
an
ve l
ag
e
Le
e
B
ve
ur
e
Le
at
st
ur
e
Le
D
oi
st
ur e
M
oi
st ur
M
oi st
M oi
M
N
E RS
s
in IV O
IT T
S C
nta
N U
TIO
U coSEND
Ais bUagRMEICO
T E
CThIS
S
d
Barcode label
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
Desiccant
AM
OSR
OHA00539
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card according JEDEC-STD-033.
17 | Version 1.0 | 2022-05-12
SU CULBN2.VC
DATASHEET
Notes
The evaluation of eye safety occurs according to the standard IEC 62471:2006 (photo biological safety of
lamps and lamp systems). Within the risk grouping system of this IEC standard, the device specified in this
data sheet falls into high risk group – RG 3. WARNING - UV emitted from this product. Avoid eye and skin
contact to unshielded product.
Subcomponents of this device contain, in addition to other substances, metal filled materials including silver.
Metal filled materials can be affected by environments that contain traces of aggressive substances. Therefore, we recommend that customers minimize device exposure to aggressive substances during storage,
production, and use. Devices that showed visible discoloration when tested using the described tests above
did show no performance deviations within failure limits during the stated test duration. Respective failure
limits are described in the IEC60810.
For further application related information please visit www.osram-os.com/appnotes
18 | Version 1.0 | 2022-05-12
SU CULBN2.VC
DATASHEET
Disclaimer
Attention please!
The information describes the type of component and shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved. Due to technical requirements components may
contain dangerous substances.
For information on the types in question please contact our Sales Organization.
If printed or downloaded, please find the latest version on our website.
Packing
Please use the recycling operators known to you. We can also help you – get in touch with your nearest
sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of
transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we
shall have to invoice you for any costs incurred.
Product and functional safety devices/applications or medical devices/applications
Our components are not developed, constructed or tested for the application as safety relevant component
or for the application in medical devices.
Our products are not qualified at module and system level for such application.
An entire (100%) testing shall be performed after assembly of our product to the final product. Our products
are not qualified at module and system level for such application. Customer is fully responsible and accountable for detection capability in case of sudden changes in electro-optical characteristics at component level.
In case buyer – or customer supplied by buyer – considers using our components in product safety devices/
applications or medical devices/applications, buyer and/or customer has to inform our local sales partner
immediately and we and buyer and/or customer will analyze and coordinate the customer-specific request
between us and buyer and/or customer.
Please carefully read the below instructions.
WARNING: Each user bears full responsibility for making their own determination as to the suitability of our
products, recommendations or advice for its own end use. Each user must identify and perform all tests and
analyses necessary to ensure that its finished application incorporating our products will be safe and suitable for use under end-use conditions. We make no warranty or guarantee, express or implied, as to results
obtained in end-use, nor of any design incorporating its products, recommendations or advice.
WARNING: High intensity ultraviolet-C (UV-C) radiation is emitted from this product, which is harmful to skin
and eyes. Take appropriate protective measures to avoid any exposure to direct or reflected UV-C radiation.
WARNING: During operating lifetime of our UV-C product different aging mechanisms can cause failures.
This may lead to a significant deviation of the function in the final product and application. Please contact us
in advance for further information.
19 | Version 1.0 | 2022-05-12
SU CULBN2.VC
DATASHEET
Glossary
1)
Brightness: Brightness groups are tested at a current pulse duration of 10 ms and a tolerance of
±10 %.
2)
Reverse Operation: Not designed for reverse operation. Continuous reverse operation can cause migration and damage of the device.
3)
Peak Wavelength: Wavelengths are tested at a current pulse duration of 10 ms and a tolerance of
±3 nm.
4)
Forward Voltage: Forward voltages are tested at a current pulse duration of 1 ms and a tolerance of
±0.1 V.
5)
Thermal Resistance: Rth max is based on statistic values (6σ).
6)
Typical Values: Due to the special conditions of the manufacturing processes of semiconductor devices, the typical data or calculated correlations of technical parameters can only reflect statistical figures.
These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g.
because of technical improvements, these typ. data will be changed without any further notice.
7)
Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single devices within one packing unit.
8)
Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
9)
Tape and Reel: All dimensions and tolerances are specified acc. IEC 60286-3 and specified in mm.
20 | Version 1.0 | 2022-05-12
SU CULBN2.VC
DATASHEET
Revision History
Version
Date
Change
1.0
2022-05-12
Initial Version
21 | Version 1.0 | 2022-05-12
SU CULBN2.VC
DATASHEET
ams-osram.com
© All rights reserved
22 | Version 1.0 | 2022-05-12
